Trek 614 rusty stays
Bikes: '71 Raleigh Inter, '98 Tommasini, '83 Trek 500, 83 Trek 720 '
Quoted: 118 Post(s)
Liked 199 Times
Well just for giggles I thought I’d post my findings… backstory … a purchased a pair of Trek, Treks, Trekii, hmmm a while ago, mainly for the smaller bike, it has been re-commissioned and is ready to go it’s in fantastic shape, however the larger frame did not fare so well, I saw pretty early that it had bubbly paint on the bottom of the chain stays… also it had one of those bolt on stands which has made a mess of the paint and well I tried too show the results in the attached pictures..
Any thoughts? I don’t mind a little rust prevention but I have plenty of bikes… so I don’t need this frame but the running gear is going to be used on a Trek 500 that needs it.
there is a small dimple likely caused by over tightening of that stupid bike stand on the right chainstay non- drive side…… anyone know if that dimple will compromise the chainstay?
comments are invited
Gary
Gary
Quoted: 809 Post(s)
Liked 1,023 Times
I don't see any issues with the frame. On sections like this, I like to brush paint on Rustoleum rusty metal primer before the color coat.
Likes For Velo Mule:
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
No more than a factory dimple for tire/chainring clearance.
https://www.bikeforums.net/classic-v...hey-works.html
Likes For dedhed:
Likes For Jeff Neese:
Quoted: 118 Post(s)
Liked 199 Times
650b frame maybe
I have 5 frames ahead of it so I’ll likely never get to it…
Quoted: 1639 Post(s)
Liked 829 Times
Looks like you caught it in time and it was just mostly surface rust.
Was there a folding side stand mounted on this bike? Asking cause it looks like a stand clamp might have caused most of the paint damage right behind the BB.
Likes For Chombi1:
Bikes: Frequently
Quoted: 158 Post(s)
Liked 252 Times
FWIW: My Trek 614 had the Ishiwata fork, which was considered by some to be badly designed and prone to failure, especially when rust was involved.
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
How’s that Trek coming along?
Edumacator
Liked 3,128 Times
Quoted: 118 Post(s)
Liked 199 Times
long term plan..
Yes i like the blue and although its 501 and not 531 for teh type of riding i do it will be fine...I got that 500 frame in anticipation of this red frame being more than i wanted to take on, its not a huge amount of work to de-rust and paint, but i liked the blue frame and i will transfer everything over and it will look period correct, i believe the Blue 500 is a 1983, the Red 614 is from 1982, but i measured the stays and they appear to be the same length, also the bottom bracket appears at least superficially to have the same outside measurement on the frame BB itself, so i think the triple front chainset will work also, the brake reach is the next issue, will the 27 inch wheels and brakes work, we shall see.
G
G
Quoted: 118 Post(s)
Liked 199 Times
good point ill check for markings when i take the fork out.
Edumacator
Liked 3,128 Times
G
G
Quoted: 118 Post(s)
Liked 199 Times
getting there
The blue 500 is absolutely an '83. Made sometime in spring I think by the serial number? I think I had figured that out. Plenty of spacing for big tires with 700C. I had long reach tectros ready for it had I decided to sell locally. Those remain ready for another project.
chrome on that dark blue looks great.
all the chrome has cleaned up with minimal effort.
The Triple spins nicely and doesn't impact the chain stay hopefully the chain will do the same.
same BB threads
27 inch with Dia Compe "G" brakes
That foam on those handlebars yukk
Edumacator
Liked 3,128 Times
Jdawg.... have been tinkering a few pictures to show what iv'e been up to...
same BB threads
same BB threads
And I definitely didn’t send those foam grips!!!
Might still have the Sun Tour ARX derailleurs from it...probably the wheels and crankset too. Who knows!
Let us see the finished product when you get done with it!
Quoted: 118 Post(s)
Liked 199 Times
The Suntour Cyclone mk II of the 613 should do well, and its all a matched set, that where the foamy bars came from, however i'm unsure whther of the black label Rigida rims will take my not inconsiderable weight of 210 LBS and that's not "Local Bike Store'... i got a 720 and a 937 waiting in the wings and just completed my wife's 613.. what the heck am i doing...
Edumacator
Liked 3,128 Times
Disraeli Gears
I had a Trek 614 for about a week, and got rid because the paint job was a horror show, like that one. Really brittle, and corrosion happening in various places (I think the bike had been used as an indoor trainer -- lotsa sweat and no wind). The damage in your first photo is from an over-tightened kick stand, I'll bet.
Quoted: 118 Post(s)
Liked 199 Times
kickstand
