The Colnago and Saronni Pair
Bikes: 89 Centurion Carbon, 91 Peugeot Izoard, 90s Giant Cadex 980c
Liked 6 Times
I've never been too into European steel. I just reckon it's all overpriced stuff, where you're paying for the name more than the frame quality. Aussie steel can be just as good.
But nonetheless, I still ended up with a pair.
First is the road Colnago. I believe it is a mid 80s(possibly 1985) Colnago Super. That would mean Columbus SL. I believe it has non original paint and decals. Smithy78 has an almost identical one here: Australian Cycling Forums - Colnago Appreciation Society
Dual TT cable guides
Colnago club cutout on lower HT lug
BB shell cutout with cable guides
Club panto on the brake bridge
Colnago cast(?) seat stay caps
Colango engraving/stamping on both chainstays
C with the club inside external sloping crown with Brevetto Colnago fork tips.
Campagnolo dropouts with 0738 stamped into it
Pinning
It only has bidon mounts on the DT.
Like I said, I don't know too much about Colnagos. What is it, and what year?
It definitely needs new chrome on the fork, and probably will get new paint too. Probably put on a Sante groupset. But I also do have a 7400 and a Mavic SSC(starfish) groupset lying around too.
Pinning
Liked 6 Times
This is the other one, a Saronni pista frame missing the original fork. I believe it is a Colnago built one. Dodgiebros, has an identical frame: Australian Cycling Forums - Project SARONNI
Single club cutout on the lower HT lug
Saronni engraved seatstay cap
Slotted BB shell
Pinning very similar to the Colnago above
It is stamped S8 on the right side track end. Or 8S if it's stamped upside down like on the Colnago.
It is only Columbus Aelle, but it doesn't make a huge difference on the track. The paint around the BB is dead as I was soaking the BB shell to get rid of the rust which was quite bad(couldn't screw in a BB cup). Does anyone happen to have a Saronni track fork lying around? Or one similar to the original(flat crown) I could be interested. And what is the story behind these Colnago made Saronni frames? There's not too much info about these frames at all.
Here's the pair together. Both the same size, and I'll be building a sort of matching pair. Both will be painted in the matching paint which is known as 'Saronni Red'. What's the closest paint that I could get? The red on the Saronni is pretty poor, so I don't know how accurate it would be to take a colour reading off that.
[/quote]
Slotted BB shell
[/quote]
Quoted: 1609 Post(s)
Liked 2,216 Times
Check this site out for changes in the frame over time. the Colnago can't be older than 1982 and the Saronni can't be newer than 1982.
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
The Super(?) fork crown matches my '83, as do most other details. Neat pair, too bad about the missing fork for the track frame. What did you use around the BB shell area to deal with the rust? It sure took a liking to the paint as you mention (not a problem for you, but could be for others not planning on a repaint).
I don't have recommendations on paint that will get you close to Saronni red, but I'm guessing it'll take a good amount of work. Maybe a two stage process to get close to the cromovelato-like finish. Maybe some flavor of candy red? There's got to be some info out there from someone else who tried to recreate that finish in the past.
And sure, the name can play into the price on most anything, but Colnagos ride beautifully. It's lifetime bike for me. Good score!
Liked 6 Times
Chansd5
Classic & Vintage
30
03-11-12 01:47 PM
mainducoyote
Classic & Vintage
24
02-04-11 08:35 AM
blaise_f
6
01-31-11 02:18 PM
