Pump head keeps slipping off smooth Presta valves
Bikes: 2015 CAAD 10 Ultegra; 2012 CAAD 8 Tiagra
Ive had to change both front and rear tubes and only had smooth Presta valve tubes on hand. My pump head wont lock on. Works fine with threaded valves but I dont want to change the tubes unless they get punctured or need to be rerplaced. Is there any easy, simple fix to get the pump to lock onto a smooth valve??
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
Just Plain Slow
Bikes: Lynskey R230
Quoted: 297 Post(s)
Liked 5 Times
Oh how I miss Junior High.
I've got a Blackburn pump that does that. Pretty much the only solution is to not use the smooth valves or use a pump that threads onto the valve.
Portland, OR, USA
Bikes: kona paddywagon, trek 2.1, lemond nevada city, gt zrx
two quick fixes if you are using a floor pump.
fix a) use saran wrap on the tube valve to increase its diameter and make an airtight seal with pump head.
fix b) the one foot method. use one foot to balance and the other to hold down the pump head to keep it from slipping off. sounds dumb but it works.
Refrigerator Raider Hater
Bikes: 2008 Sequoia
I have to opposite problem, threaded stems are way too tight for my pump. I have to sand off the first half inch of thread.
In your case I would also sand the the first half inch of stem, but use a coarse grit, perhaps it will give your rubber just enough grip.
Rolling along
I use presta but Tufo tyres, they want 220psi, I like 180ish;psi, the pump always pops off around 160psi so I attach the pump, and use whatever's on hand to secure it, vettape is good but only one use, multi strand electric fence wire is good, many uses, just a loop around the tyre and it stays,jmho,ymmv
Retired USAF, C-130 Guy
Bikes: Shopping
Quoted: 11 Post(s)
My head broke and my LBS owner told me to remove the head and just push the hose over my smooth valves. Auto blows off at around 115-120psi...
Roadkill
Bikes: 2002 Lightspeed Classic; 2010 Pedalforce RS
If replace your existing pump head with a Silca style head ($15 on Ebay) and install with zip ties or a radiator hose clamp, it will work perfectly. As a bonus, you will extend the life of your pump twenty years.
What pump are you using? My Joe Blow Pro locks onto smooth valves no problem. Same with Lezyne, but it screws on. Smooth valves shouldn't give you trouble - get a better pump, or pump head.
'11 Time NXR Instinct / '79 Paris Sport by Moulton
Experienced
Quoted: 16 Post(s)
Sometimes the rubber piece in the pump head dries and hardens a little, and then won't grip. Unscrew the cap on the head and put a thin rubber O ring in there. That'll tighten it up.
Bikes: 1984 Miyata 710, 2010 Scott CR! Team
I wrap teflon tape around my threaded stem. Works great and I don't swear near as much.
Buffalo
I wrapped a small strip of duct tape around the stem near the bottom of the dust cap threading and the pump seems to grab onto this real well.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
