How To Clear A Gunked Up / Blocked Internal Cable Sleeve
Quoted: 288 Post(s)
Liked 330 Times
I inherited a rusty, crusty French frame with internal cable routing. The brake housing was frozen inside the top tube. With great difficulty I managed to pull out the wound steel wire and inner liner, but the outer plastic liner (and possibly other gunk) is stuck inside (the walls of) the internal cable sleeve in the frame.
I figure I'll seal up the holes and use top tube clamps, but I'm curious if anyone has any ideas about how I might be able to clean out the inner cable sleeve. I tried to jam a good brake housing in there and it wouldn't budge. Chemical solutions are off the table for me.
Quoted: 334 Post(s)
Liked 748 Times
I have an old GT MTB frame with a similar issue. Haven’t really tried much yet, but I am considering pouring boiling water into the holes to see if that softens up the housing. Maybe followed by compressed air to dry it out, and some oil or frame saver. I’m curious to see what advice others chime in with.
Likes For bboy314:
Quoted: 1952 Post(s)
Liked 2,013 Times
Heat. If it doesn’t mess with the paint. I’ve used a heat gun to remove various stickers and got the frame tubes mighty hot with no ill effects to the paint. Maybe the internal sleeve is close to the wall of the top tube?
Likes For Classtime:
Quoted: 1106 Post(s)
Liked 1,328 Times
What's likely happened is that the inner surface of the tube has rusted; rust being bigger than iron it has forced its way into the sheath all along the length, locking it in place.
Try a strong solution of oxalic acid poured down the tube - plug one end and give it a day.
(Or dip the whole bloddy thing, sounds like you might as well.)
Likes For oneclick:
Quoted: 1372 Post(s)
Liked 1,752 Times
So, if I understand this, the outer cover of the cable casing is stuck inside the frame cable tube? If that is the case, get a coat hanger, the old metal kind, and cut off a foot or so. Using a hammer and an anvil (another hammer will work), flatten one end of the coat hanger piece. Flatten and then test to see if it enters the hole. If so, flatten a bit more, until it just fits. Now, gently push the fabricated tool into the hole, twisting back and forth while doing so. Now, try inserting a transmission cable, carefully. If it does not go, repeat the insertion/twist program, and try again.
Anyway, that's the sort of thing I would try.
Likes For unworthy1:
Don't use heat, use the absence of heat (cold) - freeze spray. Get it super cold.
Plastics shrink hugely when they are cold. They also get stiffer. Silicone oils do not freeze when cold - spray some in the tube to minimize friction..
You can try pushing it out but most long, thin push rods will bend when you try to push them in.
You can also try pulling it out. Feed string or solid steel wire through the hole. Attach an appropriate sized fitting to the end, then, pull it back through.
Likes For Bad Lag:
small ring
Quoted: 438 Post(s)
Liked 925 Times
I don't know about the entry angle, but maybe a long thin screw, might grab the housing so you could pull it out
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
Quoted: 1084 Post(s)
Liked 687 Times
Would the end of a shifter cable fit through the tube, maybe with a little grinding or filing? If so you could feed a shifter cable through until it catches on the end of the housing, and pull.
Likes For Jeff Neese:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
I‘d be tempted to try to push it out rather than pull it out. Get the entire top tube as cold as possible to stiffen the housing, then push from ether end using a piece of stiff wire hanger inserted until it can’t go any further. All you need is anninch or so of housing to emerge, then you can pull/twist the rest out.
Likes For rccardr:
Quoted: 4513 Post(s)
Liked 6,389 Times
I would sharpen a spoke and carefully try to force it between the casing and the rusty wall at both ends to start an ingress, then dribble some penetrant in, wait and repeat the probing.
Likes For merziac:
Steel shrinks very little. Plastics shrink a LOT.
Likes For Bad Lag:
Likes For Bad Lag:
Let me go one further, which is probably overkill, ream it out.
Even a braided steel cable (brake cable) can be spun by a drill motor. If the little fitting has cutting edges on it, it will obliterate the plastic housing as you pull it through.
Quoted: 413 Post(s)
Liked 109 Times
Slide a new inner wire through… then push each end and alternates ends until it breaks loose. A lot times the outer plastic is tore and is catching on the inside.
once it’s lose slide it out over the wire.
Likes For miamijim:
Quoted: 753 Post(s)
Liked 737 Times
Technically Goo-Gone is a chemical, but if the issue is stick degraded plastic, I'd at least test it.
Quoted: 792 Post(s)
Liked 1,785 Times
Oh, I've got it! Melt it out. Oh,... no,.... wait a minute, don't do that.
If you get it hot enough, it will expand but lose all its strength. You should be able to do a pull through.
Likes For Bad Lag:
Liked 2,013 Times
I still think heat to soften the plastic. Cinch the end of a brake cable nipple into a drill chuck and feed the cable into the tube and spin that drill. I predict the cable flapping around in there will chew up the softened housing cover. Maybe even fray part of the cable. After a bunch of this, file that; cable end to just fitting in the tube and feet the cable through and putl out the chewed up plastic.
Alternative: "make" a ferrule fit in each end of the tube to act as cable stops.
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Cut the plastic cover off of a long piece of spiral wound brake housing, make a ragged cut on one end, stick the other end in a drill chuck and use that at low speed like a plumber’s snake. Bad Lag mentioned something like this a few posts up. Make sure to spin your drill in the direction that your housing snake spiral will tighten, as if it snags and expands rapidly inside the tube it’s all for naught. Good luck and keep us posted!
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 57 Times
I would spray some PBlaster down into the tube and let it sit overnight. Then use a copper twist brush like you would use for cleaning a small bore shotgun or long gun/rifle barrel and try to twist and push all the gunk out of the tube. I would be wary of using a heat gun or similar if you care about the paint.
I had an internal cable tube like the one described by the OP on an old Raleigh and that's what I used.
The brushes can be had for $15 or $20, and may come in handy for other cleaning tasks.
Likes For Keefusb:
