When you want to use Campy but you're a tad weak...
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
24-42-45
Likes For 52telecaster:
Quoted: 809 Post(s)
Liked 1,024 Times
Ok, that is neat as heck. I think I know how this connects the big to the small. I'll let you reveal what it is whenever you would like. You got my interest.
I see you have been exploring triples @52telecaster and coming up with wicked good things.
I'm already anticipating the gearing on this. It look like a half step plus granny. Brilliant again. And the nice thing is that the 42 is no problem to find.
Likes For Velo Mule:
Quoted: 5888 Post(s)
Liked 3,471 Times
You don't need to be a tad weak to know that a quality cold forged 110/74 bcd crank beats the heck out of 144/whatever bcd your campy has any day of the week . . .
That said, the design on this looks interesting and it's a good way to repurpose all those campy cranks you may have stashed away somewhere . . .
Likes For bikemig:
ambulatory senior
Liked 3,661 Times
Red clover triplizer with a 45 on the outside. This gives a 7+% half step which works nice with a 13-15-17-21-24-28 freewheel. I wish the 21 was a 20 but it's close enough to turn a grand record into touring bike territory.
Likes For nomadmax:
ambulatory senior
Liked 3,661 Times
Quoted: 809 Post(s)
Liked 1,024 Times
ambulatory senior
Liked 3,661 Times
That is a Red Clover triplizer, is it not?
Likes For Bad Lag:
Quoted: 355 Post(s)
Liked 345 Times
Nice work. Could you show the back side with the chainring bolts in place on the granny? Did you have to get a longer / wider spindle and what length? How much clearance to the chain stay?
Italvega and Torpado Enthusiast
Likes For mech986:
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Very cool. I did something very similar with the Stronglight 93 on my PX-10. 45-42-30, with a 13-28 7sp freewheel. My first 'half-step + granny' setup, and I really like it. How does the Cyclone FD handle getting from the granny to the middle ring? The SLJ double FD on mine can do it, but it isn't always exactly smooth- I often end up over-shifting up onto the big ring then dropping it back down...
I've got a Holdsworth to build up with a Cyclone set and Campy crank, so it's very good to see a 45t 'inner' will work as the big ring (going to see if I can get away with 42/46 double and a 13-32 FW on it, but likely will end up triplizing eventually). Red Clover is great stuff, breathing new & useable life into old gear and saving aging knees at the same time!
Likes For ehcoplex:
Quoted: 874 Post(s)
Liked 2,290 Times
I LOVE Campy cranks but they are limited and pose a problem for a lot of us.The tripilizer is a solution but unless you have something like a Phil BB where you can set the crank out for the chain line, then you need a different spindle. I have a couple with the rare TA 41 small ring but that doesn't help that much, especially when the NR/SR rear derailleur only handles a 28 tooth low on the FW. I am going with a Sugino 110BCD crank for my touring bike and putting a Cyclone GT RD with a 32 tooth low FW . I have the parts so why not?
This was my "donor bike " I bought just for the wheels for my Raleigh Pro and now a source for getting low gearing on my touring bike
Likes For Kabuki12:
Old fart
Quoted: 3589 Post(s)
Liked 3,400 Times
I triplized a Stronglight 93 as well, 48-42-28. Campagnolo Record (pre-CSPC) front derailleur handles it fine.
Likes For JohnDThompson:
Quoted: 1104 Post(s)
Liked 1,825 Times
Please tell me about the device you're using to keep the bars/front wheel straight.
Quoted: 809 Post(s)
Liked 1,024 Times
A really nice progression from 20 to 93 gear inches with an off the shelf freewheel or cluster and the trick here being the Triplizer to get that small front chainring.
Quoted: 874 Post(s)
Liked 2,290 Times
Likes For Kabuki12:
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
BTW, the Red Clover 144BCD triplizer was modeled directly from the TA one I have installed on my 1971 Schwinn Super Sport. Jon borrowed it when he was developing his with his machine shop. So glad it is serving you well!
Bob
Bob
Likes For pastorbobnlnh:
ambulatory senior
Liked 3,661 Times
ambulatory senior
Liked 3,661 Times
Very tight clearance. But it clears.
I'm not averse to sanding the bolt heads but it wasn't necessary here.
ambulatory senior
Liked 3,661 Times
ambulatory senior
Liked 3,661 Times
ambulatory senior
Liked 3,661 Times
If your freewheel is a Suntour Perfect (not always marked as such), I have plenty of 20T sprockets I can provide. If it is something else, let me know the make and model and I'll do my best to assist.
ambulatory senior
Liked 3,661 Times
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
I bought at a bike swap a TA tripilizer with the intent of perhaps using it on a pretty 144 bcd Superbe I have. Turns out the TA is for an odd 135bcd Campy. I guess I will have to keep an eye out to purchase a bike using that crank to put it on. Good reason for a purchase.
Quoted: 809 Post(s)
Liked 1,024 Times
I screwed up. This has 20 usable gear ratios, not the 17 I posted above. Duh! I seemed to have left a few combinations out and the graph still looked good! Here is the correct one:
The nice thing about half step gearing like @52telecaster 's project is the even steps that allow fine tuning to conditions and and to make a bigger jump, you just need to shift the rear derailleur. I am hoping that the spreadsheet below illustrates the beauty of this system.
Compare this to a standard 13 - 28 rear cog with 42 - 52 chainrings:
You will notice that although there are 14 combinations available, there are some ratios that are so close to each other that we would consider then to be functionally the same. This standard gearing gives us 10 distinct ratios.
This is not bad, many of us use this or something similar. Both my Traveler and LeTour have this type of set up with a 5 speed freewheel. We get used to it and even me, the gearhead that I am, just learn to live with it.
Half-step gearing is what many touring cyclists use, you can see why.
