Carbon Wheels Optimized for 28mm tires?
Quoted: 18883 Post(s)
Liked 10,646 Times
But you don't know what the tire will actually measure on the rim until you mount it, no? OK for a person who can experiment with wheels and tires to get the perfect 105, but seems that a guess, or a calculation based on the marketed tire size is the only practical way to do it.
I don't know that I believe them, but Zipp claims their dimples make you faster by shedding vortices as they form such that you fight less turbulent air flow. Clearly the 105% guess is a massive oversimplification of a very complex topic.
Likes For Seattle Forrest:
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
It's actually the opposite from my observations. That's the design of the rim to give the optimized 28mm more aero properties. Same for my 2 different wheels. The final width measurement for mine is what I stated, which means the wider the internal width, the wider the tire casing will measure.The FFWD rim is 31mm ext width wide and 21mm internal width. The poster is not posting the tire casing width measurement.
Quoted: 20810 Post(s)
Liked 9,456 Times
Quoted: 102 Post(s)
Liked 55 Times
Depending on "a" or "the", the sentence would mean different things. But I'm perhaps being pedantic! My apologies.
On the note of external widths, I actually messed up! My road wheel, the Enve 4.5 is 32mm external width, not 29mm. The 29mm is my commuter OHR wheels, which is for my Pinion. So I should really shut up about correct other people's mistakes! haha
Quoted: 1109 Post(s)
Liked 1,200 Times
Still a guess. I'm not pooh-poohing the 105 rule or even the concept of "ideal" aerodynamics (although neiher make any difference to me). But it's just a guess, and really, is it more practically effective or meaningful than just putting a tire on a rim and riding?
Liked 9,456 Times
If a tire manufacturer has published WAM/RAM for a particular model and size, then no, it's not guess - you should know what to expect when you mount and inflate the tires. Most manufacturers aren't going to publish WAM/RAM for every rim width under the sun, but they should have enough that you can interpolate.
As far as the 105% "rule," yeah, I'm not worrying about it too much, personally. As long as I have a nice transition between tire and rim, I'm happy.
