1990’s Schwinn MTB Stem
Quoted: 41 Post(s)
Liked 26 Times
I have a 1995 Schwinn High Plains with a flat handlebar, installed in a basic stem where the handlebar slides through.
I would like to replace this handlebar with one that has a 50 mm rise.
Will I be able to slide the new handlebar through or will I need to order a new quill stem, adapter, etc.?
Many Thanks
Many Thanks
Likes For HarryPotter69:
Quoted: 140 Post(s)
Liked 163 Times
Many Thanks
Many Thanks
Likes For well biked:
Quoted: 6199 Post(s)
Liked 4,816 Times
If you go with the old stem you might need to spread the clamp open a little bit to give enough room to get any bends in the bar through. Not too much though. Some bars with compound bends can be challenging.
I wouldn't buy a new stem unless there is something you don't like about the old stem or it is broken or worn out. But be sure they are the correct size. Bikes don't all use the same size stuff..
Likes For Iride01:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
when you slide your new bars in, rotating the "bend" to a position that has it pointing Down in relation to the Stem clamp will help!... Most, if not all, one bolt stem clamps are shaped to be narrower on their low side.... Once the bar bend is past the clamp, any orientation can be slid through easily................ no extra-wide spread needed.
Likes For maddog34:
Quoted: 41 Post(s)
Liked 26 Times
My question is on the older stem since the 50° has a sharp angle bend will I be able to simply slide that handlebar through the stem once I remove the existing handlebar?
Really Old Senior Member
Do you mean like this?
"scuse the mess....
"scuse the mess....
Likes For Bill Kapaun:
