12s chain wear
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
12s chain wear
Hello. After how many kilometers should i change my chain? (this for me sound weird since i always use a gaige to determine the wear itself and not judging by kms).
Also is i don't own a 12s wear indicator , is correct to measure with a gauge and replace when the measure hit +.5?
for example a new chain will measure 134.4mm (6 chainmail i belive), after the chain it's worn out must measure 134,9. is it correct?
ps. i have an ultegra di2 12s
Quoted: 1821 Post(s)
Liked 1,697 Times
The pitch of your 12 speed chain is no different than any 11 speed, 10 speed, 9 speed, etc chain. It is very simple to measure chain wear using a ruler. Don't overthink things
Likes For alcjphil:
Quoted: 6199 Post(s)
Liked 4,816 Times
On a new chain with no wear, the pin would be at 12 inches or 304.8mm. 306.3 mm would be the same as the 12-1/16 inches that most consider worn out . Make sure your origin and point you measure to are either the center of the pin or the same side of the pin.
Likes For Iride01:
Quoted: 682 Post(s)
Liked 453 Times
Liked 4,816 Times
I read something a while back that some 12 speed chains have different roller diameters than 11 speed or less chains. That'd make a lot of chain checkers useless for them.
I haven't seen this discussed much, so I could be wrong.
Liked 1,697 Times
What brand of chain? I have heard the same thing about SRAM 12 speed chains that may not work with anything else, effectively locking the consumer into using their stuff
Liked 4,816 Times
alcjphil we must have seen the same thing. It was about SRAM's chains. There are various blogs and such about it if you google 12 speed chain roller size
Likes For Iride01:
Quoted: 5793 Post(s)
Liked 2,593 Times
There's no formula for chain life. Light riders in the plains will get long life, while heavier riders in hill country will eat chains. Other factors like gear selection (smaller spockets increase chain wear), chain lube, and riding style all make a difference.
As for wear indicators; since the chain's have the same 1/2" pitch, the same rules for measuring with a ruler would apply, as would the when to replace guidelines.
Note. I said "guidelines" because that's all that they are. For my part, I use a sliding scale, being conservative with replacing the 1st chain on a new cassette, and moving to allowing more wear as the cassette is aging.
IMO folks tend to overly obsess over this, and don't allow themselves realistic fudge room. By analogy, do you stop and seek out a service station for an oil change the minute your odometer ticks off 2,500 miles, or just make a note to change oil at your next convenience?
FB
Chain-L site
FB
Chain-L site
Quoted: 682 Post(s)
Liked 453 Times
So then I guess as long as it’s not one of those SRAM chains as above which seem to have bigger rollers, you should be able to rely on that.
Maybe it would be ok anyway, the delta would be about 0.15mm on the AXS one according to google.
1% stretch would be 1.5mm over about 6 inches are the tools that long? 12 links? Close enough I reckon
.75% would be 1.125mm
add on the 0.15mm of the bigger rollers gives approx 0.85% at 6 inches
so I reckon you could treat the .75% side (net .85% real stretch on one of those chains) as a useful marker.
Quoted: 504 Post(s)
Liked 437 Times
* The great thing about standards, of course, is that there are so many to choose from.
