Things we do that don't really have a practical purpose
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Over at the Classic Rendevous site I sometimes read what a "proper" bike should be like. Sometimes they just strike me as stylish with no real useful purpose other than to set one apart from the "unknowing". I'll start:
Your thoughts?
- Building a wheel so that when you look down the valve hole, the hub logo is centered - typically done when building on vintage Campy hubs. "It shows that the wheel builder cares." What if I really cared that I build the wheel to last a long time, but didn't center the logo?
- Perfectly horizontal top tubes. "They look right". They look right because that's what we all grew up seeing on vintage bikes...I get this one often when doing a 650b conversion and rerake the fork for lower trail. It typically drops the front end by a few mm. Did that ruin the bike?
- Lugged frames only, please. He Who Shall Not Be Named declared that lugged frames are stronger. Hmm, lots of fillet brazed frames from Jack Taylor, Ritchey, Jeff Lyons, and others aren't falling apart at the joints...not to mention the numerous TIG welded frames out there are holding up just fine. There's a bit of a tail wagging the dog here, where you're forced to design a frame around available lug angles.
Your thoughts?
Likes For gugie:
Quoted: 2588 Post(s)
Liked 4,824 Times
Lugged frames only for sure; it's an aesthetic question AFAIC. Tig welding or fillet brazing just doesn't pump my nads the way lugged construction does
DD
DD
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I'm with you on all three of those and I do them all as well. The biggest item that is not practical for me is building frames and forks. I'm 5' 10" and common proportions, don't really need anything built for me. An off the shelf 55-56 fits me well. That being said, I'm replacing most of my bikes with framesets that I build.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
One of the things I do that has no practical purpose is dig way in and adamantly defend myself for mounting the front skewer lever on the drive side.
Likes For SurferRosa:
Quoted: 3811 Post(s)
Liked 6,717 Times
Yeah, those fixie hipsters and their sloping top tubes!
Likes For nlerner:
Quoted: 1952 Post(s)
Liked 2,013 Times
Some folks replace cups and cones when there is some pitting. Pretty silly where big bottom bracket balls (BBBB) are concerned. And sometimes we just do what we're told-- Like with practically slick Continental GP#000s and the little rotation arrow--I remount them if I get it wrong the first time.
Likes For Classtime:
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
I've built a ton of wheels and never even thought about the hub logo. I must not care. Good thing the folks I built them for don't know.
Likes For 52telecaster:
Quoted: 188 Post(s)
Liked 997 Times
Wearing white socks on a racing bike, beautiful but absolutely not practical.
Likes For fabiofarelli:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,612 Times
It's a hobby, not a religion. For me, anyway.
Quoted: 3015 Post(s)
Liked 3,805 Times
Large flange hubs - they do look sweet though
Wrapping bar tape a particular way.
Twisting toe straps
Photos of the drive side
Even brake cables
High brake cables
Twisting toe straps
Even brake cables
High brake cables
Likes For iab:
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,099 Times
Neal, I always suspected your knickers used to be white…
Roger Musson insists on the hub label, valve hole trick and even though he comes across as a bit of a crank in his book, I do what I’m told.
Quick release lever angles - There’s a friend of ours who tells the story of Francesco Moser demonstrating to him the proper angle, which is pointing aft parallel to the ground. I admit to trying this on some of my racier bikes and it feels right and maybe even I go a little faster.
Quoted: 1088 Post(s)
Liked 1,205 Times
If I accidentally build a wheel without the logo visible through the valve hole, I won’t redo it, but I will make sure it doesn’t appear in pics I post here…
One thing I’ll admit to having done is trim my cable ends very short, but I won’t do that anymore, since I like to tinker too much. A piece of lingo I picked up when I made a couple of short films long ago was to shoot a few seconds on either end of the scene to facilitate splicing — “give me some handle.” I like to do this with my cables.
Likes For noobinsf:
aged to perfection
Quoted: 840 Post(s)
Liked 1,261 Times
the things you describe are little touches that show experience and attention to detail
nobody mentioned the tire label at the valve stem. Or proper orientation of the QR lever.
these things are done as a matter of habit, rather than an end in themselves
/markp
/markp
Quoted: 4513 Post(s)
Liked 6,389 Times
The QR levers pointing rearward parallel to the ground is technical, safety, common sense, they are far less likely to be opened by debris, vegetation and errant contact.
Having them both on the same (NDS) is aesthetic common sense, no brainer.
Many "rules", guidelines, traditions, etc. have some technical basis that was relevant at the time.
Some of those become irrelevant with time and advances, then they are tradition.
Likes For merziac:
Liked 6,389 Times
Liked 5,803 Times
Tire label orientation at the valve stem is very practical. Many a time I've had a flat tire and couldn't initially find the culprit. Finding where the hole is in the tube, and referencing the location on the tire relative to the tire label has allowed me to focus my attention and find the tiny bit of glass, or metal wire that caused the flat. Without that knowledge it can be like finding a needle in a haystack.
Likes For gugie:
Liked 5,803 Times
Except rule #12
Likes For gugie:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
Wut, you didn't mention his sloppy sloped bag too? That's a bigger faux pas IMO. The frame is crazy short too.
In other news, I never used bar tape in my life, or drops for that matter.
Never used shoe binders either. Pfffft to those.
It's hard to tell which label or where on my hubs, they go all around. I mark the tire holes with the pen I always carry.
I sure won't leave rim advertising labels on. They ain't paying me. LOL.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I still buy bikes I don't need because of my skewed, inferred value of them.
I still build or repair old (and some newer) bikes for people who don't appreciate it.
I still abhor modern frames even though they're often 'gateway bikes' to C&V
I still covet too many items on our sales thread.
I still drive my car too much in the winter.
The list tells me to ride more, if only to counterbalance whatever hellfire we receive in 2022. I'll go to the basement for my trainer shortly.
Likes For clubman:
Liked 6,389 Times
I still have to set up the trainer after I clear out the space that is being held up by a frame up build that is almost done but dragging on way too long for no good reason.
Then will be taken up by the present wrapping station.
I hate that effen trainer.
Likes For merziac:
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
45 years ago I built wheels for a fairly prestigious bike shop that sold a lot of high end bikes. I never knew about lining up the valve hole with the hub label, nor did it ever occur to me since I never attempted to examine my hub label through the valve hole. I never had a complaint about this from any of our customers, maybe because this was during the time when our "vintage" bikes were modern bikes and folks bought them to ride and to race. Now that these bikes have accrued some status as collectible items perhaps this attention to tiny aesthetic details is a bigger part of owning one of these bikes. No problem with that.
A few on the CR list have postulated that lining up the stem with the label shows some superior attention to detail on the part of the wheel builder. The problem with this reasoning is that anyone who has built a few wheels can easily perform this trick. It does nothing to differentiate the hack from the expert. I'm quite sure that I would have quickly adopted this non-functional detail if it would have labeled me as a superior wheel builder and allowed me to raise my rates. In hindsight I'm rather glad however that my wheel building reputation was based on the quality of my wheels not on my "attention to detail."
Brent
Brent
Likes For obrentharris:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I never considered this until just now, but your method would let you consistently work the QR lever and nut with the same hands...
Quoted: 1829 Post(s)
Liked 3,380 Times
As far as stylish with no real purpose... is that a bad thing? Sometimes it's just fun.
actually, it does add a bit of flair to a monochromatic fillet brazed bike.
Steve in Peoria
Likes For steelbikeguy:
Liked 5,803 Times
My take has always been that some places had certain practices or traditions, and these practices never spread broadly. Naturally, folks like to preserve these traditional practices, but I don't recall any/many saying that other practices were inherently wrong.
Steve in Peoria
Steve in Peoria
Getting a bike set up just right, yeah, makes me feel good. Feeling good helps me go faster and longer.
Nothing wrong with being stylish, it's probably what draws most of us to vintage bikes. Modern bikes look soulless to me.
