Shining a chrome fork...
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I just picked up a 73 Raleigh competition in pretty original if kind of rough shape. I was worried about the rusty forks and used what I learned here at bike forums. Aluminum foil and wd40. Holy crap did that work good.
As picked up, and the brooks is in excellent shape.
Nearer fork leg treated with wd40 and scrubbed with aluminum foil then wiped down with a rag.
Both legs treated.
Both legs treated.
Likes For BFisher:
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
Yeah, when I got my Circuit with chrome stays and fork, I wondered how I'd ever get them looking decent. I read about aluminum foil and I thought, "That'll never work!"
But it did!
But it did!
Likes For genejockey:
ambulatory senior
Liked 3,661 Times
Likes For 52telecaster:
ambulatory senior
Liked 3,661 Times
Beautiful! I should get busy on my chrome bits with that.
Question, for OP and all: Afterwards, should one car-wax or otherwise treat the chrome bits? Or just rely on the WDisplacement effect?
Thanks.
Thanks.
Likes For tgot:
ambulatory senior
Liked 3,661 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Nice looking Raleigh.
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 872 Times
52telecaster Congrats on your good fortune with that bike. Especially since you had a bit of a drive to rescue it.
Likes For daverup:
Likes For BFisher:
ambulatory senior
Liked 3,661 Times
Quoted: 811 Post(s)
Liked 1,024 Times
I use an automotive wax to protect the chrome after cleaning/de-rusting. While WD-40 provides some protection, it doesn't seem to last more than a few weeks. Automotive wax will also need to be reapplied. My opinion is that the wax lasts longer than WD-40.
I am also waxing many of my tools now, rather than oiling. How long the wax last depends upon conditions of storage and use. I figure that in my garage, maybe a year?
Likes For Velo Mule:
Quoted: 1303 Post(s)
Liked 1,911 Times
52,
Now that you have it cleaned up a bit, get a tub of Quick Glow chrome cleaner and go over it. it leaves a light coat of protectant on the chrome and removes the light pitting of the steel underneath the chrome. Smiles, MH
Likes For Mad Honk:
Quoted: 1372 Post(s)
Liked 1,752 Times
I have been using the aluminum foil chrome cleaning procedure for many years and am usually totally impressed with the result...
Same fork cleaned up...
The only thing that I do to help preserve the shine is keep the chrome dry and waxed (I use Mother's Cleaning Wax cause that's all I have). So far, so good and the cleaned chrome on my Legnano has been like this for ten years or more...
However, if you want to be extra sure about oxidation prevention, coat the chrome with some clear lacquer as I did on my late fifties Rabeneick...
Likes For randyjawa:
ambulatory senior
Liked 3,661 Times
Wow you guys are awesome. I typically enjoy riding my bikes looking a little rough but I might try to be nicer to this one. I changed cranks and now have a rear wheel with a 6 speed 14-28 freewheel on it. My derailleurs are happier. It's ridable now but I will continue improving.
Btw, 700x38 paselas fit in back with a bunch of clearance. I love this bike!
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I remember reading about this trick a few years ago when I was working on an old Nishiki, and there were some people saying that it's just an illusion because the aluminum foil flakes off onto the metal and gives the appearance of chrome but will soon fall away. But I figured the total investment in finding out (including the initial cost of the Nishiki) was about $25, so why not try it?
As you can see, I was left with some pitting. I'm not sure if you avoided that on the Raleigh or the photo just doesn't show it. I don't really notice it on the Nishiki looking directly at it. I didn't do anything to it afterwards and three years later (including a couple of rides in the rain), it still looks good.
My Bikes
My Bikes
Likes For Andy_K:
ambulatory senior
Liked 3,661 Times
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 166 Post(s)
Liked 348 Times
There was a super simple (MS Paint level) graphic I saw once, probably on this forum, which made the process very clear. Basically, when a small hole occurs, for whatever reason, in the chrome, the steel below oxidizes. This results in the rust blooming up through the hole in the chrome. When you use the aluminum foil on the chrome, the foil is harder than the rust but softer than the chrome. The rust is removed while the chrome is unaffected.
Likes For Rooney:
