Anyone use an electric air pump in the garage?
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
Was wondering if anyone uses an electric air compressor for their bike tires. I have a good floor pump, but it doesn't work great on my motorcycle so I was thinking of getting a small air compressor for the garage. I like that the compressors can be programmed to a specific psi which would be nice for the bike. Would appreciate any recommendations. Thanks.
Likes For hayden52:
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 94 Post(s)
Liked 1,308 Times
I have a 240 volt air compressor I use for stuff, including filling a portable air tank that I use to fill car and bike tires.
Mark
Mark
I would get a 6gallon porter-cable compressor (on-sale at HD for $99 right now). Then buy the air hose and tire pressure gauge at Amazon. You are looking at maybe $150ish in total expense. You can use the compressor for DIY around the house and so much more.
I have one but I basically bought it to air dry my bike when I clean it . I use it for other stuff around the house once in awhile and to inflate car tires as well. However, I still use a pump for my bikes.
Thread Killer
Quoted: 3147 Post(s)
Liked 1,711 Times
I use a 4.5 Husky twin-tank “silent air” compressor, yeah, and it’s sweet with a retractable hose reel and a Park Tool INF2 head unit. Unfortunately, the INF2 is $135, but really, it’s so much better than any other inflator head I’ve used, I consider it virtually indispensible (for presta).
Quoted: 94 Post(s)
Liked 1,308 Times
I should have included a link to the air tank. It's aluminum so I don't have to worry about it rusting from moisture, and it is lighter: https://www.jegs.com/i/JEGS/555/8100...RoCCYIQAvD_BwE
Then I replaced the hose with a coil hose and an inflator with a gauge: https://www.amazon.com/AstroAI-Infla...7D3PVBJ4&psc=1
Mark
Mark
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Husky 120-Volt Inflator-HY120 - The Home Depot
Fred "The Real Fred"
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Yeah, 15 CFM, maybe a little overkill for bike tires.
Results matter
Results matter
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Since riding my bikes is just about my only exercise, using the floor pump to inflate their tires is just about my only upper body exercise. So the compressor is only for inflating car tires and blow drying or dusting things.
Compressor for cars and motorcycles, floor pump for bicycles. Its just too fast and easy to use the floor pump for bicycles. I don't leave the compressor running all the time, so my bicycle tires are filled long before the compressor is ready. Now, if I had to use the floor pump for my motorcycle or car, I would probably pass out before I was done.
Quoted: 696 Post(s)
Liked 910 Times
I have a Husky compressor that Ive used almost exclusively in the garage. I do worry about moisture in the tubes/tires from the condensation inside the tank, but its never been a verified problem (unless the moisture in my tubeless tires prevents the sealant from reacting the way it should). I had the compressor from a home renovation and just naturally used it for my bike tires.
Quoted: 229 Post(s)
Liked 119 Times
https://www.homedepot.com/p/RYOBI-ON...
Likes For pgjackson:
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
I have one of these for floaties. Use it on the boat all the time. Absolute game changer.
https://www.homedepot.com/p/RYOBI-ON...ger-P737D-P163
The inflator by itself w/o a battery and charger on Amazon makes it seem like a pretty good deal.
