Quick question about chainline and bottom bracket length
Quoted: 800 Post(s)
Liked 753 Times
I'm planning to purchase some cranks, "Dimension Cyclocross". Linky here: https://www.treefortbikes.com/Dimens...t-110-74mm-BCD
Anyways, my intention is to use it as a triple on a bike with a 68mm bb shell and 126mm OLD. If it helps, the specific bike model in question is a 1982 Miyata 1200. I'm assuming the cranks were made for a bike with a 73mm bb shell, and 130mm OLD.
According to the website linked, they recommend 113mm or 118mm as spindle lengths. I'm assuming that's for if they're set up as a triple or a double, respectively.
Given the differences between my bike and the bike that the cranks were made for...do I purchase cranks longer or shorter than 113mm? I feel like the smaller bottom bracket would mean I would want a longer spindle, but the shorter OLD would mean I would want a shorter spindle...leaving us where we started. 113mm spindle length for a triple. Am I correct? Or way off?
Thanks.
P.S. Any verdict on the Shimano un300 as a replacement to the un55? Or should I look elsewhere?
Thanks.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,470 Times
Thanks.
Thanks.
Converting Trek FX2 to 1x - Bike Forums
The crank arms seem to be designed for the current standard road bike having a 130 mm OLD:
110 Crankset | Dimension Bike Products
So we are working on essentially the same problem but going in opposite directions. From what I have learned online regarding bottom bracket spindle length vs. chain line, the consensus seems to be: (a) the actual results may not work out exactly as calculated, so expect some trial and error, and (b) you have about a +/- 2mm margin of error, maybe less in your case if you are aiming for a perfectly setup triple crank. You have a tougher task than I do because you have to account for both (1) the movement range of the front derailleur, and (2) spindle length vs. chain line, whereas I only have to account for the latter.
I have also researched whether the readily available BB-UN300 is the same quality wise as the no longer available in many sizes BB-UN55, and only found one article theorizing that the latter is better:
BB-UN55 vs BB-UN300; which is the better square taper bottom bracket? - restoration.bike
Liked 1,470 Times
The Dimension Cyclocross crank arms are actually Andel RSC6 triple crank arms; the inside of each arm is stamped as such. I have read about others installing these crank arms on both 68 mm and 73 mm JIS square taper bottom brackets.
Quoted: 1944 Post(s)
Liked 2,164 Times
Other than a response to a question on the Treefort site, I don’t see anything about being a triple. The Dimension site shows it as a double; it looks like the same one.
John
John
Liked 1,470 Times
That is true. Dimension is apparently marketing an Andel RSC6 triple crankset (110/74 BCD) as a cyclocross double, presumably by omitting the 74 BCD granny chain ring.
Liked 2,164 Times
The dimension site shows a CR2330 and CR2331 as a 110/74 double.
I’d contact Treefort and find out if it has a middle ring position.
John
John
Liked 1,470 Times
I have ordered and received the same crank arms from another vendor. The drive side crank arm has a 110 BCD 5 arm carrier for installing the outer and middle chain rings on either side thereof, and additional "nubs" on the back of the carrier onto which a 74 BCD chain ring can be bolted thereafter. I would take a picture to settle this debate, but OP is not even concerned about this debate.
Liked 2,164 Times
There is no debate. I only brought up what was on Dimension’s website. I honestly don’t care.
If you already have the same crank, why not just measure it to get the chainline? It doesn’t matter if it is 126mm or 130mm dropouts, you just have to make the adjustment for the 68 road/73 “traditional” mtb.
John
John
Randomhead
Liked 3,698 Times
It really doesn't matter what the OLD of the bike is, the chain rings just have to clear the chain stays. The crank arms don't determine this, you have to get the right bb. A bike shop should be able to help you with that.
Liked 1,470 Times
Liked 1,470 Times
But in addition to just clearing the chain stays, the middle chain ring of the crank set should ideally line up with the center of the cassette, for smoother shifting overall and to minimize the chain angle in any cross-chaining gear combinations.
Likes For SoSmellyAir:
Liked 2,164 Times
If you have set up a 1x with 68mm BB and 135mm dropouts, what BB spindle length did you use?
Just take 5mm off that and it should work for the OP.
John
John
Liked 1,470 Times
2. Even if I figure out all of the above, I am not sure this is applicable to the OP. He has different OLD and potentially different cassette width (I am on a Shimano 8 speed). But I will report back so he can hopefully use the information.
Liked 2,164 Times
I’m sure your findings will be helpful.
John
John
Quoted: 800 Post(s)
Liked 753 Times
edit...I am wrong, 68mm is still the norm for road. But more for external bearing bottom brackets and other newer standards? Rather than bikes outfitted with internal bearing bottom brackets + square taper.
Yes, I did some googling prior to posting after getting momentarily confused by Dimensions' own specs.
1. I don't know the spindle length on the BB of my bike. I am about to install the right crank arm, and if the chain line looks bad, remove the BB to look for and/or measure the spindle length, and order a new BB accordingly. (Depending on chain stay clearance, I may even order one with a shorter spindle so I can use the outer chain ring position rather than the middle chain ring position.)
SO, since my bike has a 126mm OLD, and a 68mm shell we have: 118 - 9 + 5 = 114mm. Or, in other words, pretty damn close to the 113mm spindle length recommended by Dimensions if using the cranks as a triple on a 73mm bb shell/130mm OLD bike frame. Now, if only some vendor sold the silver version in the states...Oh Surly and their ridiculous fascination with black components.
Quoted: 1562 Post(s)
Liked 1,734 Times
The Treefort site listed two spindle lengths: 113 and 118. These are for the 68 and 73mm BB shells respectively. Wider spindle for wider BB. Narrower spindle for narrower BB. It’s that simple.
Likes For icemilkcoffee:
Liked 1,470 Times
Liked 1,470 Times
Randomhead
Liked 3,698 Times
Perhaps I'm wrong, but I was under the assumption no one was mass producing frames with 68mm bb shells anymore, since the 90s or so? I thought most everything had shifted to 73mm for square taper crank-destined frames these days.
I you were really worried about the chainline, you could get something like a Phil Wood bb with an adjustable chainline.
Quoted: 800 Post(s)
Liked 753 Times
Sorry for the double post!
Liked 1,470 Times
Bike Forums - View Single Post - All Silver Chain Rings on Black Crank Arms
Liked 2,164 Times
While it may seem hard to believe, it is possible to buy a square taper BB in the correct shell width, so you don’t have to buy a 118mm and have more spindle or 113mm and have less spindle out the NDS just to fudge a mis-matched BB.
While this might be a SWAG, I would think a 113mm spindle might work for a 126mm/130mm and the 118mm for a 135mm with either a 68mm or 73mm shell.
John
John
