Which canti do I have, no fine adjustment
Got a 2nd hand bike,10 year old Soma frame with Shimano Ultegra, and shimano canti brakes, but there is no way to adjust the brake cable, anything that I am missing? If I tighten the cable at the allen, I will not be able to remove the wheel!
I replaced the pads, and check contact, but it is still not performing as well as my older bike.
thank you for your responses
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
You can add a barrel adjuster where your cable housing enters the cable stop on the seat stays. Probably any bike shop will have one. As for removing the wheel, pop the cable out of the nds canti arm.
Likes For shelbyfv:
Quoted: 2952 Post(s)
Liked 3,106 Times
What shelbyfv said.
I would say get some of these if your levers don't have built in releases.
https://bike.shimano.com/en-EU/produ...0/SM-CB90.html
So what do you mean by performance? Lever feel? Mushiness? Stopping distance? Sound?
IMHO braking isn't about the caliper or types of canti's, it is about whatever adjustment they have, the cable feel and the pad. I have always replaced my pads with Scott Mathauser pads and never been disappointed in braking power.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Likes For canopus:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
+1 on the barrel adjuster. Jagwire makes a mickey adjuster that fits into the TT stop instead of the rear stop.
Likes For Unca_Sam:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I suggest reading the Sheldon Brown article on canti adjustment: https://www.sheldonbrown.com/cantilever-geometry.html
Likes For andrewclaus:
IMHO braking isn't about the caliper or types of canti's, it is about whatever adjustment they have, the cable fell and the pad. I have always replaced my pads with Scott Mathauser pads and never been disappointed in braking power.
Quoted: 1438 Post(s)
Liked 1,092 Times
For better adjustability I would suggest getting rid of the link wire system and using a straddle wire and carrier instead. You will need to provide a means of catching the straddle wire if the main brake cable parts, to prevent the straddle wire from fouling the tire and locking the wheel, but that can be as simple as a reflector bracket or a loop of twine.
Thank you, that was my first stop, to the LBS, was handed the Scott Mathauser pads, not too much change, no sounds, but stopping distance is too long, I not will do the Conzelman grade in the Headland until the brakes are good , not mushy... wheels are true, pad wear is even.
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Likes For AeroGut:
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 85 Times
jsut to make sure, you don't have V-brake only levers on? They don't have enough leverage. The cable sits differently than in canti or sidepull levers (unless you have drop bars, of course)
Likes For restlessswind:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
It looks like the return spring adjustment screw on the pictured brake arm is threaded all the way in. While not necessarily wrong, it is atypical and could indicate other issues with brake adjustment. I generally keep all return springs adjusted as loose as possible but as tight as necessary. This generally improves brake lever feel and is a good foundation for the rest of the brake system adjustment.
In addition to checking out the Sheldon Brown link above, I'd thread the return spring adjustment screws all the way out and even verify that the spring pins are in the middle hole in the cantilever bosses (if multiple holes are present). Once you've verified the spring pins are in the middle hole, use the return spring adjustment screws only as necessary to center the brake arms on the rim.
Likes For hokiefyd:
Also, to answer your original question, I believe the shimano model number for those brakes is BR-R550. Instruction manual is here if you want it.
I will do the front later.
Yes I have drop bars
Thank you all for the infos, yes for the adjustment screws... I observed that and found it odd, good pick ... will correct
The other glitch
Took care of the glitch and set up the concave washers properly , one on each side... a lot easier. Brakes are much better, did a quick 20 mile ride .
The Scott/Mathauser pads are the Yokozuna brand.
Thanks again for the support
Post edit: with all the hardware set properly, it does not seem that I will need that cable adjuster hardware!
