Gloves for numbness in hand
Vibration dampening gloves on Amazon. Haven't tried them. Not cycling specific but several reviews mention cycling and that they would buy again. Maybe worth a try for $16 plus change.
https://www.amazon.com/dp/B00BHMLJUK...v_ov_lig_dp_it
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,639 Times
In a similar vein, pull on the handlebars. Parking weight on the ‘bar will always cause problems. If you must rest weight on hands change hand positions frequently. Mix up those position changes with episodes of pulling on the bars. Parking weight compresses joints and nerves. Pulling on the bars opens up space in the joints.
Another person said its a matter of fitness, don’t quite see how having strong abs would help me here either. Adopt a more upright less forward position so I can pull myself upright with my abs alone. Perhaps I am doing it all wrong. Is the guy below doing it wrong too?
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
This is not me (I wish it were) but it shows my typical body/ arm/ hand position. Don’t see how pulling up will work using this position. What you say makes sense.
With stronger abs (and stronger spinal erectors) theoretically it would be possible to assume the position in that photo and not even touch the bars. Cyclists in general have underdeveloped abs and anything that makes them stronger helps in multiple ways.
Quoted: 7652 Post(s)
Liked 3,473 Times
Any gloves will work for numbness of the hands, just tighten them enough around the wrist.
Quoted: 426 Post(s)
Liked 274 Times
I find gloves help with vibration on the road or if you crash for protection. They wont' help you if you are dumping your weight into your hands and wrist. For that you just need to use your core strength to hold yourself up a little bit.
Likes For sean.hwy:
I'm surprised nobody's mentioned this earlier post about numb hands. Should be required reading for anyone dealing with this issue.
https://www.bikeforums.net/road-cycl...umb-hands.html
