best compact double for crit racing?
One speed: FAST !
Bikes: Ebay Bikes... =)
Just wondering... what is the best double crankset for crit racing?
I'm looking for lowest price + stiffness.
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
Shimano R700
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Best compact double for crit racing, particularly in South Florida is an oxymoron.
Admittedly 50x11 is a big enough gear for just about any mortal.
However if the stated purpose is crit racing, you certainly don't need a compact, particularly in Florida.
You could get lost and die.
You could hit a tree and die.
One speed: FAST !
50x12 = 112.5 inches 105 rpms.
53x12 = 119.2 inches 99 rpms.
50x11 = 122.7 inches 96 rpms.
53x11 = 130 inches 90 rpms.
One thing is likely certain, I will not be in the top gear for the final sprint.. lol I'm not strong enough to turn a big gear like that... It is more likely that I'll be in the 50x15/14/13 or something more manageable.
Bikes: 2010 Trek Madone 5.5 CAAD9
You should be spinning higher rpms when sprinting. Last crit I did I averaged 102 rpms for the race and it had 2 hills in it.
Why do you want a compact if you live in florida???
One speed: FAST !
It makes it a bit easier to do the Vista View races... it is a circuit race that goes over two old garbage dumps... climbing is nasty!
pan y agua
Liked 727 Times
I get what you are saying, but if we look at the actual differences in gearing for a weak sprinter like me we have this: (assuming 35 mph top speed on a flat without a leadout)...
The downside to the compact is that common cruising speeds put you right at the crossover point between the big ring and the small ring, so you end up shifting a lot back and forth, or cross chaining.
For example with a 50/34 11-23 setup, 50x19 (as far over as you want to go) at 90rpm is 19mph, and 34x13 (again as far over as you want to go) is 18.9mph. So as your speed goes up or down around 19mph
(as terrain, wind, or desired effort changes) you'll be going back and forth between the big and small ring.
For alot of people the compact puts the cross over point at an awkward point.
Admittedly it's not a big deal. But when you have zero need for a compact, why not just avoid the problem.
Carpe Diem
then you're looking at two bumps that hardly qualify as climbs.
pan y agua
Liked 727 Times
With the possible exception of Sugarloaf Mountain Road Race if your not in the big ring the entire race in Florida, you're OTB anyway.
I'm pretty certain, there is not a climb in Florida that requires anything lower than a 39x23, for a rider that has the fitness to begin to be competitive.
Checked the course profile for Vista View. It's about 80 feet of climbing. The max grade is 6% for about 30 vertical feet.
https://www.mapmyride.com/ride/united...avie/483724898
Sorry, but if you need a compact for that, you're not ready to race.
Bikes: Dawes Kalahari, Puch Prima Super Sport, Graham Weigh 853
Campagnolo Centaur: if you buy the alloy ones, you get really high quality chain rings. They are light, pretty cheap, and seem to be reliable. Other than that, the best one is one that used to be on one of your other bikes
He is right, I don't think anyone on here is busting your stones, just being realistic. You should really consider not getting a compact, get a 12-25 or 12-27 cassette if you are concerned, but hey do what you want.
My idea of fun
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times
Vista View is about your ability to put out sustained power for 2 minutes and then recover. Nothing else.
If you are sprinting at 105-110 RPMs you are doing it wrong. I hit my max power when im spinning 140+
One speed: FAST !
Agreed, my comment may have suggested that I would be sprinting in that gear but it was not intended to lead to that conclusion.
I was only illustrating the maximum gear ratios and rpms at the given speed of 35 mph... Sorry for the confusion.
With a standard, a heavy headwind or long slope might force me down into the 39, where in the same conditions on the compact I can stay in the big ring. I suppose it depends on terrain, wind, rider condition, but in my experience, compact = less changes at the front.
This isn't to say there aren't other arguments against compacts...
