Play in new MKS Allways pedals
The description on MKS Sylvan Touring Next pedals says that dustcap can be used to fine tune the preload on cartridge bearings to reduce play:
"The dust seal cap also functions as the bearing adjuster. If you loosen the cap, it may cause play and premature wear",
but there is nothing like that said about Allways pedals.
As always was expecting a bit higher quality for such a price.
Hard to avoid any cognitive biases but it seems like frequently running into defective products for some reason.
https://www.mkspedal.com/?q=en/product/node/308
Liked 2,962 Times
You don't offer details about your problem.
It seems that MKS doesn't want people to fool with the pedals, which I understand because it's so easy to axially overload radial bearings.
However, if you have play, you might reach out to MKS. Or, you might see if you can open the end cap, under which you'll find a nut to take up axial play. If you decide to adjust them, be careful to only take up play, but not to create preload.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Clark W. Griswold
Liked 4,272 Times
Like FBinNY said there is no details on the problem. It could be something not the pedals is causing issues or it could be the pedals in which case the authorized dealer you purchased them from can start a warranty and get you new pedals.
MKS makes excellent pedals I have had two pairs of them and I have abused them and truthfully never maintained them (which I probably should eventually do) and one of my mechanics had Lambdas for years and years and years and years and I eventually bought him the Gammas because he had foot slippage and I don't think he installed them for a long time because his old pedals refused to wear out and he rode that bike everywhere for everything nearly everyday of his life and he probably had the pedals for at least a decade if not more.
If you keep running into "defective" products I would think maybe the products are fine and the person installing them or using them is the actual issue or it is possible you are just an unlucky lightning rod.
Looks like there is no preload tube which means that adjustment affects only the outboard bearing.
Liked 4,001 Times
I believe the version of these pedals that the OP has are of the "no tool release" design. If so there could be some play in that part of the axle, between the part that threads into the crank arm and the axle end that is inserted into the first part.
I would also not use the "defective" term when describing bearing preloads not being what the OP thinks they should be. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 2,962 Times
How can you have angular play without axial or radial play?
OTOH if as Andy suggests, you have a quick disconnect pedal, play at the link is common, and can be considered a trade off for the feature.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
If there is no preload tube between smallest outboard bearing and two bigger inboard bearings then the adjustment will affect only the outboard bearing.
The radial play is felt only around inboard bearings but not around outboard bearing.
Liked 5,020 Times
Maybe the product isn't defective. Maybe it's functions at the level of performance that it needs too. Maybe you are making mountains out of molehills.
Likes For Iride01:
I haven't found clear explanation how much play there should be in general or reports from other users (except: "the pedal keeps spinning for ages") so it's too early to tell.
Liked 2,962 Times
It's not a quick disconnect model. After repeated testing there is also some axial play.
Angular bearings require preload to eliminate play. In radial bearings that's achieved in the bearing itself. These bearings cannot tolerate axial preload, which leads to rapid bearing failure. Radial bearings are used where no meaningful axial loads are expected, so one adjusts to minimize axial play, short of adding an axial preload.
I suspect the pedals are fine, and the issue is your misconceptions and expectations.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
First of all, you need to understand a critical difference between the adjustable angular bearings classic to bicycle.
Liked 2,962 Times
But they're your pedals, so feel free to ignore my attempt to help you, and continue to complain.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Strangely in the factory video they show those two bearings being pressed in with a press.
Liked 2,962 Times
I can't say, since I don't have the pedals to examine.
OTOH - Have you subjected them to the acid test, namely installed them to see how they actually work? Otherwise, I've no stake in MKS, though I did import them some time ago.
You're clearly dissatisfied, and hint that this isn't the first time, so maybe your best option is to return them, and not buy MKS going forward.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
I looked at the pedal drawing in the link OP provided and don't understand all this talk about preloading the bearings. Not needed. As for the wording of the instructions the OP also provided, I have a better way of phrasing it, "Don't mess with the bearings. They are set up correctly by the factory for the service life of the pedals."
Disclaimer: Cartridge bearing pedals may be different than the below instructions, which are for loose ball bearings.
EDIT: FBinNY has looked at the pedal schematic and convinced me that my normal procedures below for much older pedals might be damaging to the MKS. So disregard the instructions below and follow the manufacturer instructions.
EDIT: Below is only for old style pedal spindles:
I've rebuilt loose ball (angular contact) pedal bearings for decades. I've found I get much better bearing life with just a touch of preload, as the balls are very small and just the right preload spreads load over almost 180 degrees of the bearing balls under radial load instead of just a couple at a given time, and if the pedal housing is sufficiently stiff, you will engage even more bearings and the shaft rigidity will be increased as a result, providing better cone alignment under load.
With pedals off the bike and rotating spindle in fingers:
- with slack, easy rotation, but too loose.
- no slack, easy rotation, but not spreading load as evenly on the bearings as could be.
- very slight preload, you feel the slightest bit of greater "engagement" of the bearings, I call it when the bearing "sings". This is the goal.
- too much preload, the spindle feels "notchy", back off a tad until not notchy, slight preload.
Just my experience, based on bearing adjustment in other applications. I used to adjust all bearings with just the tiniest bit of slack; Dad used to say, better a little too loose than too tight. He was wrong, I learned, once I learned more.
YMMV.
YMMV.
Liked 2,962 Times
Most cartridge bearings used on bikes are deep groove radial bearings, which can only handle rsdial loads, plus very light axial loads, more about staying located, than handling any thrust.
Unless you can expand the inner race, there's no way to change the radial preload, which is already built into them.
Axially loading them only pushes the elements sideways, forcing the balls to ride the sides of the grooves, and will rapidly destroy the bearing.
There are also angular contact cartridge bearings, which work the same as bike cup/cone systems, and therefore need proper axial preload. However, offhand, I don't know if any bike parts use these.
If you look at the MKS schematic, you'll see a pair of low profile radial bearings which carry most of the load, and a deep groove radial bearing at the end that keeps the pedal from sliding off the spindle.
This design simply cannot tolerate preload, and I'm not surprised that MKS doesn't want folks "fixing" them.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
The issue isn't whether they're loose type or cartridge, but the configuration of the rolling elements.
Liked 2,962 Times
You might shop for pedals with classic cup/cone bearings. These will meet your need for zero play adjustability.
MKS still has offerings of this type, though you may be turned off to the brand.
So did you try actually using the pedals? Some that I use have only a small ball bearing at the outer end to locate the body on the spindle - the main load is taken by a plastic bushing and it feels fine even with wear, despite the fact I can rattle it by hand. The double cartridge bearings in yours will probably last forever as long as they're not abused.
Could it be that MKS is actually avoiding any interference fit on those two inboard bearings since otherwise it's impossible to share the load equally between them?
Liked 2,962 Times
You might take a basic mechanical engineering course, focused on bearing design.
Double bearings are SOP in countless applications where space requirements preclude using a single larger bearing.
I don't know why you can't find pedals, but FWIW my cup/cone pedals by Campagnolo and Sun Tour have 10s of thousands miles behind them and NEVER developed any play, or excess wear. I also own various radial bearing pedals which do have trace play, but it's totally undetectable when riding.
So, I wish you luck finding something you like, but I don't think I can help you get there.
Likes For FBinNY:
With cup and cone you never know when they are perfectly adjusted. They are usually perfect at the beginning after overhaul but then after 100km they are loose again even with sufficient locknut adjustment while trying to avoid stripping the threads even with Deore level of precision. If you leave them tighter intentionally then they sometimes continue to self tighten.
Again, as FBinNY has said, the MKS design is not like cup-and-cone, so the above is not recommended, in that case follow manufacturer's instructions; I haven't seen it, but it's very easy for me to visualize a design where one bearing manages axial play in addition to taking half the radial load, and the other bearing handles just radial load. This is similar to a "full-floating" axle design on trucks, which allows the axle driveshaft to expand and contract axially without affecting the bearing adjustment. It's a smarter design.
