Changing 1x 40 to 44
Bikes: Tommasini, Sampson, Merlin
I'm thinking of changing my SRAM Force 1x 40T to 44T. Will I need to change the chain to a longer length? I can't find anything that references the diameter of the different chainrings. If the chain needs to be longer and idea of how many extra links?
Bikes: 1974 PX-10E steep angles, sold, 1977 Witcomb stolen, 1980 Roberts 1 speed, 1987 Cyclops 3 x 6 friction triple crank, 2010 Masi Commuter 1 speed, 2017 Ribble 525 2 x 10 with Ergos
Liked 32 Times
Think of chainring circumference in links, not chainring diameter. The chain engages only half your chainring, so the new chainring will want only two more links, the smallest unit you can normally add or remove.
Will you need to add links? Maybe not. Try pinching a couple of links together with the bike in bottom gear, to see if there is two links worth of slack available without stressing the derailler. As for the advisability of just adding a link pair, that will depend on the wear state of the current chain. Also, two "quick link" master links just a link apart may not be a good idea - others will advise I am sure, I have no data/experience on that.
Depends how it was set up - if it's already as short as it will go then you'll need to add an inch i.e. one inner and one outer link, to compensate for the approximate two teeth more that the chain wraps around the chainring. To check, split the quick link and wrap the chain around the largest sprocket and the 40t chainring, not through the derailleur, so the ends overlap on the chainring - if it only overlaps 4 or 5 links you'll need to add a couple more. Rear suspension and you may need another couple more - it's important that the chain can easily shift to the largest sprocket without binding up, even in the tightest position of the swing arm.
Really Old Senior Member
Put it on the largest cog and see if you have an EXTRA inch of slack.
Thank you for your thorough response. It's a gravel bike so I don't need to worry about rear suspension.
Even if I don't change the chainring, your explanation will come in handy anytime I replace a chain. It's a nice check rather than just match the old chain.
Thanks again. Mark
Thanks again. Mark
I really like your description of "Think of chainring circumference in links, not chainring diameter."
I got around to looking at the bike and chain and I now think there isn't space to add a bigger chainring. The bike is an Cervelo Aspero and the chain stay bows out leaving very little of any space. (I can't post a picture due to not having made 10+ post)
Oh well.. But I did learn a lot from everyone's advice and comments.
Divide by PI and you have the diameter increase. Divide that by 2 and you have the radius increase.
Assuming you have an 11T smallest cog, can you actually spin a 40T ring?
Also note that the above is not "maximum cog size", that is a different value and a function of how low the rear derailleur jockey pulley hangs below the cassette, and/or the "slope" of the derailleur pantograph linkage and how well that matches the slope of the cassette.
Yes, thinking of only about 180 degrees of chain wrap around the chainring is completely accurate. Just realize that, in terms of the rear derailleur "maximum capacity", to make matters easier for mechanics, that rating is based on "whole" chainrings and cogs, not halves. So for example, my 50/34 crank (16 tooth difference) plus 11-30 cassette (19 tooth difference), total is 35 tooth difference, and requires a rear derailleur with a minimum of that capacity, if I use all gear combinations.
It would only be "completely accurate" if both sprockets are IDENTICAL in size.
The main question is where does your post show any connection to what the OP said?
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Liked 438 Times
Well, that wasn't the OP's question, but that isn't really that big of a gear (smaller than the 52x13 back in the day). I can easily spin out a 42x11, and I'm not a spring chicken.
Cheers, Mike
-Stupid hurts....ride safe
Cheers, Mike
"The bike is an Cervelo Aspero and the chain stay bows out leaving very little of any space."
I was showing how to tell how much larger the ring would be.
I don't give a rats if you can spin that big of a gear. I was asking the OP.
Liked 438 Times
I was referring to the OP's statement-
Wrong, but it's certainly close enough. Think of a bike with extremely short chain stays, very large ring & tiny cog. The large ring will have more than 180 and the tiny cog will have less.
Cheers, Mike
Cheers, Mike
