Reds for water bottles/bidons that don’t make hands sticky
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,646 Times
Recs for water bottles/bidons that don’t make hands sticky
I changed to an electrolyte and carb drink whereas before I just was using electrolytes. Now I am battling sticky fingers which then transmit the stickiness to the bars and controls. Yuck!
Anyone drinking a carb based/sticky drink and using a bottle that doesn’t leak a bit? My 4 YO REI BPA free bottles need to go.
Not Reds <-thanks spell check
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 9653 Post(s)
Liked 6,365 Times
We have not had any issues with any of our bottles leaking, and some are at least three years old. They include Trek, Specialized, and Camelback Podium bottles. Have about a dozen that are informally rotated by two riders. All but one are the insulated varieties.
Likes For Mojo31:
Pennylane Splitter
Bikes: Yes
Quoted: 1804 Post(s)
Liked 1,444 Times
I'm just a plain tap water guy. I sometimes like to squirt a little on my face/arms during warm weather rides, and doing that with a mixed drink wouldn't work too well.
Likes For skidder:
Quoted: 4415 Post(s)
Liked 4,868 Times
I like the Elite Fly bottles that most pro teams use. No leaking and they flow really well too. I have a few Camelbak Podiums, but I find their nozzles hard to clean.
Liked 4,868 Times
Likes For PeteHski:
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
I have a pair of Specialized bottles that don't have the same spillage issues, but don't flow as well. Most recently, I got a pair of Polar Breakaway bottles. They flow well, don't spill, and the nozzle comes apart for cleaning. However, even when closed, the top of the nozzle still has a cavity that will collect dirt, which makes them a no-go for off-road riding.
I'm still searching for a better bottle.
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times
Any bottle like the Podium that has the one way squirt valve work well. The key for me in leak prevention is when tightening the cap good to lightly squeeze the bottle and you'll hear a little "blup" from the valve bladder. I guess that sorta pressurizes the bottle and since I do this they never leak ! I have Specialized Purist bottle also with an optional one-way squirt cap, as the ones that come with it , the mo-flow things, yeah they're mo-flow alright, the flow all over the riders face before you can get a drink ! El Sucko !
Likes For Garthr:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
I use liquid IV and REI bottles (26 ounce) and never an issue leaky tops or with sticky fingers. I do make sure I push the cap shut wit my teeth after drinking.
Grupetto Bob
Liked 5,646 Times
Likes For rsbob:
Grupetto Bob
Liked 5,646 Times
Klaatu..Verata..Necktie?
Quoted: 10437 Post(s)
Liked 11,913 Times
Did you know that some podiums are being recalled? https://www.bicycleretailer.com/reca...e-faulty-valve
I don't have sticky fingers problems with Skratch Hydration Mix, but then I've never had sticky fingers problems with any drink mix. Are you having a drinking problem?
Habitual User
Liked 8,098 Times
The Skratch Super High Carb mix gets sticky in a hurry.
Liked 11,913 Times
Before I started using Podium bottles, I used to do that... BRIEFLY! Then I put that together with my AMAZING ability to find and hit rocks and potholes, and started bumping the tops shut on my leg before putting them back in the cage. I don't want to be singing "All I want for Christmas is my two front teeth"
Liked 11,913 Times
Quoted: 117 Post(s)
Liked 209 Times
Thankfully mine are too old !
Grupetto Bob
Liked 5,646 Times
Never had problems with Skratch electrolyte either but after switching to SIS with carbs, now I have a problem. And to answer your question; yes I do. Evidently not enough!
Habitual User
Liked 8,098 Times
Absolutely. That's what it's designed for. I like it quite a lot for rides longer than 2 hours...except for the sticky problem. On road rides, I'll run a little less than the recommended dosage in my bottles. On long MTB/gravel rides, I'll run 2 full-dose bottles and a hydro pack of just water. Even with a full dose, the flavor is very mild and drinkable, not overly-sweet like you would expect. IMO, Skratch does a really good job with this product. I expect the SIS mix rsbob uses is similar.
Liked 11,913 Times
Not sure it would work for me, since my primary need for drink is because I sweat like nobody's business. I need the fluid and electrolytes more than the carbs. Supposedly Old Guys don't sweat as much, but so far that hasn't been the case. Might work on long winter rides where I don't sweat as much, and fumbling food wearing full finger gloves is a pain.
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
Maybe experiment with different liquids if it's a concern. I've noticed that Coke will give a sticky bottle and not from fizzing. Somehow it creeps past the threads. Gatorade and Liquid IV don't. Where is our chemist?
Habitual User
Liked 8,098 Times
Huh. Learn something new everyday.
Liked 11,913 Times
I base this on just how much salt deposits on my jersey, shorts, and helmet straps (not to mention my temples) on hot rides.
Likes For genejockey:
Grupetto Bob
Liked 5,646 Times
The reason I moved from only electrolytes to a carb electrolyte mix in my bottles:
Just ordered two Podiums and will give them a go. Thanks for the responses.
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I use Polar bottles with Gatorade and don't have a problem with leakage.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
Grupetto Bob
Liked 5,646 Times
