Something disc brakes need
Hi guys. I recently bought a bike with disc brakes. In my case, I have to remove the front wheel to get it in my car. The little plastic piece that I have to put in between the calipers when I do is a terrible solution IMHO. Surely, with all those brilliant engineers designing all this amazing technology these days, they could come up with a way to lock them when there is no disc inserted, no? I sure wish they would, even if it did add a couple of grams. It's just a matter of time before I loose that little plastic thing.
Likes For Jklotz:
Quoted: 5224 Post(s)
Liked 3,585 Times
??? plastic? I'm thinking the things between the calipers are brake pads, which are not plastic. regardless, yeah you have to keep aye on a cpl things when putting the wheel back on ...
No, I'm talking about the thing you have to put between the brake pads to keep the brakes from seizing if you accidentally hit the brake lever with no disc in there.
Likes For Jklotz:
Quoted: 20810 Post(s)
Liked 9,456 Times
Another solution, at least for Shimano, are the yellow lever locks that many (all?) levers ship with; they keep you from shifting and from actuating the brakes. That's what I use when I travel with the bike. If you go down to your local bike shop and ask for some, they probably have dozens that they throw away every week. They are left and right specific, though, so be sure to get a pair. They may also be model-specific, I don't know.
Edit: these are what I'm talking about -
Likes For WhyFi:
Quoted: 1461 Post(s)
Liked 1,486 Times
I've never used a pad spacer/block when transporting my bike and this has never been a problem. Just don't squeeze the brake lever with the wheel removed and it'll be fine.
Even if you do squeeze the brake lever for some reason, all you have to do is use a plastic tire lever to push the pads back into the caliper before re-inserting the wheel.
The problem with having some kind of lockout on the brakes is... what happens if you re-insert the wheel and go riding off and forget to unlock it?
Likes For msu2001la:
Quoted: 8287 Post(s)
Liked 9,062 Times
I didn't know this was a thing. I've been putting disc braked mtb's in the car since 2008 and never had a problem.
Likes For big john:
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
I got a couple of those thingies, in a bag, along with sundry hydraulic parts, with one of my bikes. I don't use them and if I did squeeze my pads together inadvertently, I'd just pry them apart with a tire lever or something, as mentioned above.
Liked 9,456 Times
Yeah, I think that it's mostly a non-issue, but I could see how it might be problematic as pads near end-of-life. When I travel with the bike, it's 1500 miles on the road, so I'll take the 30 seconds of popping on the lever locks as insurance.
Quoted: 9656 Post(s)
Liked 6,366 Times
Old business cards are good for that purpose - fold one in half and shove it between the pads. If you lose one, just grab another from the old box of cards you never give out anymore.
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
What CAN happen is if the lever gets squeezed you can pop the pistons out of the calipers and it's just about impossible to put them back in.
and it's a mess
I know some "expert mechanics" will claim this is no problem but then you are faced with the prospect of re-bleeding the brakes.
so I use the blocks, mostly in the stand, to prevent such an occurrence
/markp
and it's a mess
/markp
Likes For mpetry912:
Quoted: 4417 Post(s)
Liked 4,873 Times
Once you have a few bikes with disc brakes you soon accumulate a stock of the plastic spacers. I have at least half a dozen of them in my toolbox. Can’t say I lose them very easily. I just keep one in the car and one next to my direct drive trainer.
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
It's not a requirement. Just don't squeeze the lever.
I think it would have to only be able to work if the disc was not between the calipers. In other words, only operable when the wheel was not on the bike.
Quoted: 2976 Post(s)
Liked 1,182 Times
and it's a mess
/markp
and it's a mess
/markp
Like others said. It's not a thing.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2586 Post(s)
Liked 5,648 Times
My first gen Campy Ergo brifters had a button which when pushed would open the brakes to ease tire/wheel removal. They would stay locked open until the button was pushed again. Thought it was a cool feature which could be applicable here.
With my first disc bike (MTB) removing the bike from the back of the car, I inadvertently pressed the front brake lever which caused some scrambling to figure out how to move the pistons back. A screwdriver took care of it, but accidents do happen. Learned my lesson the hard way and am now super cautious.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Liked 1,486 Times
and it's a mess
/markp
and it's a mess
/markp
With pads installed, I don’t see how the pistons would extend far enough to come out. This definitely can’t happen on my Shimano GRX brakes.
If I were boxing/bagging up a bike for a flight I’d probably use the blocks. I frequently load my bike on a fork mounted roof rack with the front wheel off, and don’t do anything- and have never had a problem even on multi-state drives.
I think this is a non-issue
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I’m on board, but how would you do it? Rim brakes put them in the caliper, which you could do with cable disks but maybe not hydraulic. Perhaps a latch or safety in the lever. It would not be automatic. The hydraulic system basically can’t “know” if the disc is present. Anything that actuated or sensed that would interfere with the free spinning of the wheel. I can imagine some kind of interlock with the axle but those components don’t normally talk to one another
Genesis 49:16-17
Genesis 49:16-17
Disco Infiltrator
Liked 2,105 Times
it would be nice if they were all the same, wouldn’t it?
Genesis 49:16-17
Genesis 49:16-17
Liked 1,182 Times
How much lever squeezing are we talking about here?
You are are right. It's a non-issue.
Liked 4,873 Times
Liked 4,873 Times
and it's a mess
/markp
and it's a mess
/markp
Likes For PeteHski:
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I'm pretty much with the OP here. It's not terrible. It's just a nuisance we could do without. I put the plastic tab in when I remove the wheel just to prevent something bad from happening. It's recommended. The last time I traveled, I forgot to put the tab in. Nothing bad happened. But I'm still going to use the tab as a preventive measure. It's not that much trouble, but it is some trouble, and it's recommended to prevent more trouble.
Quoted: 18424 Post(s)
Liked 15,581 Times
Liked 11,914 Times
I got 250 business cards.
Then they changed one digit of the phone number. So I got 250 NEW business cards.
Now we've moved.
I'll be able to center my calipers for the rest of my natural life.
Now we've moved.
Likes For genejockey:
