Cycling on 'rough' and 'bumpy' roads, which approach to take?
Hey. As I have been getting better on the bike I have been expanding my route selection and going on a few of the bigger A roads. Only downside I have noticed compared to rural riding is that some of these main roads are so rough and you are bouncing around and your chain flapping around. It's not that the roads have holes in them, they are just like microscopic cobbles and make it a rough and bumpy ride. I also find it tough keeping speed on these kinds of roads, and would actually prefer ascending a smoother road. You are putting your best effort in and can’t break a decent speed.
So, should you try and power through these rough roads, or should you try and take it steady? Does cadence play a role in how easy these roads are?
Thx
_______________
Chris
Thx
_______________
Chris
I've seen concrete roads like this where the concrete has been eaten away by acid-rain and only the large peebles about 2-4cm in size are exposed. It's a neat finish if you want it for a driveway, but for a road to ride on, it's punishing.
I'd recommend getting the largest tyres you can fit on your bike and running them at the lowest pressure you can. Just barely enough to avoid pinched flats.
Or you can pick up a used MTB for $50-75 and put 26x2.125 tyres on it at 25-30psi.
Quoted: 15 Post(s)
Liked 27 Times
these are cobbles:
this is a rough road (with "small holes or raised portions where the road has been worn and the top layer has been slowly broken down").
they're two separate things.
just sayin'
just sayin'
沒有腳踏車的居民
Bikes: Mericier Kilo TT Pro
microscopic
adj.
a. Too small to be seen by the unaided eye but large enough to be studied under a microscope.
b. Of, relating to, or concerned with a microscope.
adj.
It seems you forgot to add the photo of you two, the forum security and control guys.
Thanks for clarifying the correct term and posting something that was no help whatsoever. Keep up the great work Smartasses are always such a useful kind.
Living Notoriously Well
Bikes: 06 Felt F80
If possible I would avoid the roads that are in poor condition, or at least plan routs that only include short sections of these roads.
Rough roads are a pain in the butt... pun intended.
沒有腳踏車的居民
Depending on how long the roads are, you can post up and pedal out of the seat for a bit. If they are a long stretch, I would recommend avoiding them if you can.
Bikes: Turner Czar, Eddy Merckx Corsa Extra
Main Entry: ped·ant
Pronunciation: \ˈpe-dənt\
Function: noun
Etymology: Middle French, from Italian pedante
Date: 1588
1 obsolete : a male schoolteacher
2 a : one who makes a show of knowledge b : one who is unimaginative or who unduly emphasizes minutiae in the presentation or use of knowledge c : a formalist or precisionist in teaching
Chepooka
Bikes: 1990 Trek 1400 7spd; 2001 Litespeed Arenberg 10 speed
Quoted: 1110 Post(s)
Liked 1,085 Times
Did you see how far I strayed off the question while staying on topic?
^ This. Try something like the Vittoria Open Pave's - 24mm clincher version of the tubs that many use on the cobbles. They only come in green. It ain't easy being green.
Stand and Deliver
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
Sounds like you are talking about chip seal paving. Try to find smoother roads if it bothers you.
They've been chip sealing roads out here too. I'm okay with it, for 10 miles and no more. It just wears on me.
I'm hoping that this winter will take care of it on the roads. I assume the shoulders will never improve.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
FTFY. There's a section of road here where I'm struggling on a slight downhill in the middle of my small chainring, then I turn onto the main road and suddenly I'm flying in the middle of my large chainring on a slight uphill. That or I have serious motivation issues on the first road somehow.
Quoted: 242 Post(s)
Liked 456 Times
Ride harder...sheesh it's not rocket science.
Lose the death grip on the bars...ride lightly...keep elbows bent...
Bikes: 2007 Trek 1600
Headset-press carrier
Bikes: Kona with Campy 8, Lynskey Ti with Rival, Bianchi pista, Raleigh Team Frame with SRAM Red, Specialized Stump Jumper, Surley Big Dummy
This road tuns into gravel and I can only climb a bit from where the chip seal ends. I walk up from where I sink to the little driveway beneath the first house and then finish the climb most days. A sinking and tractionless 23 mm tire on a 16% grade is tough. This one of the finger climbs I do off of Loma Larga Rd in Corrales. A test of my bike handling skills for sure.
Bikes: 19 Look 765 Gravel RS, 18 Cervelo C5, 13 Niner Jet9 RDO, 08 Surly Crosscheck, 05 Serotta Fierte
Get a cross bike and fill it up to 32 tires with 70 lbs of air. No issues
On some roads, you just need to push through it. Siu and botto's picture are very common for all roads where I'm at. But at the same time, I've met with rougher. Once I vibrated (and I do mean that - very consistently bumpy) down about 3 miles worth of road. I don't have a picture of it (too bad Google doesn't either), but let's just say I won't be going that way any time soon.
shaken, not stirred.
Bikes: I've lost count.
Quoted: 1412 Post(s)
Liked 971 Times
correct. not enough heavy traffic on the shoulders to wear the gravel smooth. oh and you wouldn't like riding here then, chip-seal is the predominate sealed surface. you get used to it. bigger tyres at slightly lower pressures help.
vBulletin: snafu
