WTB/WTT a couple Italian threaded bottom brackets
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
I've grown tired of banging my head on a couple Italian frames in my basement (Conti Special and Atala Super Pro) and decided I should at least build them up so I can begin tripping on them instead, and maybe ride them every now and then. I started on the Conti and got to the point where I needed to install the drivetrain, only to realize I have no Italian threaded bottom brackets in my stash.
The Conti is going to be an "eclectic" build, basically whatever I have that fits. It will have Galli derailleurs and brakes, Modolo Corsa levers, not sure about the cranks yet. I'd be happy with your basic a Italian threaded cartridge bottom bracket (Tange, Shimano, whatever) with spindle length of 113-115mm.
I'll try to make the Atala more true to its probable Campagnolo heritage, so a Campy bb with 70-SS spindle would be nice.
I can purchase or trade. Hunting for non-existent Italian threaded parts, I discovered a number of British threaded bottom brackets. I'd be happy to sacrifice some of them on the Italian altar.
I think I have a Superbe Italian BB tucked away.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Quoted: 964 Post(s)
Liked 1,451 Times
I have an Italian threaded Campy cartridge BB in my BB box. I think it is Chorus or similar level. I will have to measure the length. Will get back to you tomorrow morning with that information!
Likes For shoota:
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
I probably have a few more than a few...
Bikes: many
Liked 1,392 Times
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
I have a 111mm spindle ITA Chorus or Croce level BB somewhere that should fit the late 80s/early 90s Campy cranks that need the 111 length. Shoot me a PM if that’s the direction you want to go. I may also have an ITA Triomphe around 115, so mid 80s.
Again on the taper I think you only want to match certain Campy spindles to the appropriate era cranks. Was looking all this up like two years ago so I’ve slept a few times since and forgotten more than I originally knew. If you’re using JIS taper cranks (most everyone else) best to stick with JIS BBs. Best of luck!
Quoted: 964 Post(s)
Liked 1,451 Times
Mine is 102mm. Probably too narrow!
If anyone else wants it, let me know!
Bikes: many
Liked 1,392 Times
I have one of these and if I remember correctly it gave me a good chainline on my circa 1990 Athena crank. I plan to be building up the Bianchi again in the near future and will try to remember to let you know when I get it back on. I’m drawing a blank on the taper but I think this is the pre-ISO Campy taper if anyone more knowledgeable can chime in? And I think it was the Veloce level cartridge BB for the mid 90s lower road groups.
Edumacator
Liked 3,128 Times
Didn’t get a chance to look yesterday. Will try tonight.
Bikes: many
Liked 1,392 Times
Okay, I took a look at what I have. It's an odd bunchL Galli arms, 3- and 5-arm Campy GS (both have chainrings), early SunTour Superbe, and various Sugino Mighty (or Mighty Comp, could never figure out the diff). I also have an orphan 1974 Campy Record drive-side arm which I decided not to sell some time ago because of cracks in the spider. I just filed them out and tossed it up on the Pay It Forward thread.
Back to bottom brackets. Looks like something Campy-ish (at least in dimensions) would be best. I think I'll put the Galli crank on the Conti to go along with the derailleurs and brale calipers, and maybe the 5-arm GS on the Atala unless something better comes along.
I've got a Dura Ace 7400 BB with caged bearings, the original sleeve, and matched crank bolts, Italian thread. 113mm. $50 shipped.
I've also got a set of new, unmarked chrome steel Italian thread cups (DS & NDS) with Shimano-style splines and rubber dust seals. Yours for $10 plus shipping.
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Bikes: many
Liked 1,392 Times
If you install an ISO crank on a J.I.S. spindle, it will sit about 4.5 mm farther out than it would on an ISO spindle of the same length.
Bikes: many
Liked 1,392 Times
Some older Shimano Dura Ace used a shorter taper than most other cranks. Most modern cranks will bottom out on the spindles from these cranks
I'm afraid the Italian cups won't help, as I don't have a suitable spindle for a 70mm shell either.
Quoted: 359 Post(s)
Liked 582 Times
I have an Italian 114.5mm OmniRacer square taper, Ti spindle.
Mounted but too wide for Racing T. Very light, but new, is a $95 wallop.
Negotiable.
Negotiable.
Edumacator
Liked 3,128 Times
Here are the cups and spindle. 70 SS ~114mm
