The dominance of the narrow racing tire on bikes is over
#51
my new used road bike had 23's on it when purchased. Rode twice and I put on 25's .
Huge benefit was I can run 80PSI ft and rr no problem. The roads are bad , and I'm just 132lbs . Having had the experience of the lower pressure and love it, will not go back down to 23's again.
#52
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
I've got new 30mm tubulars coming to go on these:
Weinmann Carrera tubular rims on Zeus hubs
Who says I'm living in the past?
Likes For Fredo76:
#54
Quoted: 2495 Post(s)
Liked 738 Times
#55
Liked 738 Times
I did try to read every post and I'm hanged if I could find the one that mentioned the fact that often the bike decides how big a tire you can use. How the eff am I supposed to get any bigger tires in 'Little Red'?* Those are 25's and 23's are what she came with. There isn't anything bigger fitting, period, and since I have plenty of other bikes, some with 28, some with 32. One with 2" and the cargo bike has 2.4 I simply don't feel the urge to have my race replica roadbike have 40 or even 32 tires because on asphalt there is no real need for big section tires and if your roads are that bad that you need 40 section tires ... maybe a full carbon racebike replica isn't the best kind of bike for those conditions? Really? 50+ posts ... ...
Oh, as long as y'all got me bothered enough to jump in ... an interesting observation I made last year that is germane to the discussion. It was a windyish day. Nothing I really noticed prior to the 'event', but I had stopped to get a couple of items at a Trader Joe's and I had the racebike. I leaned it against a wall while I was putting my purchases away and getting my gloves on the bike started moving off without me. It took me a moment to realize that the bike was facing into the wind and the tiny frontal area of tire and headtube were catching enough air to move a 20lb bike in less than 10mph of wind. The ground was level and I conducted a full scientific experiment reversing the bike and noting that it went the other way just as easily, completely cancelling out any ground effects. This was purely the result of the frontal area of the bike being significant enough to generate enough force to move a riderless bike.
So, if 25mm tires have that much frontal area, then those of you rocking 40's should think about that when you are feeling superior about how much speed you are getting out of them. Rene Herse had a lot of things but I don't think a wind tunnel was one of them. And with that I am going to grab that bucket o' popcorn and enjoy the rest of the discussion. Do go on.
*Just in case you wanted to see 'Big Red'.
#56
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
As for bike determining tire width, absolutely correct. My 2015 Giant Propel barely can fit 25s and my 2014 CoMotion Supremo tandem is limited to 28s. My 2021 Colnago can run 30+ widths but through trial and error, I've found the 25s to still be my personal preference.
The opinions for and against wider tires are as varied as the number of users on this board.
Keep the chain tight!
#57
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
It doesn't really matter what the science says or what the pros are doing. Three of my four bikes won't fit anything bigger than a 23, so I mostly ride 23s. I like the bikes, so I hope availability doesn't become an issue.
#58
Firm but gentle
When you go fast, I mean really fast, narrower is faster than wider. Now let me zip up my flame proof suit.
Likes For venturi95:
#59
Quoted: 514 Post(s)
Liked 448 Times
Depends on the surface being ridden upon. These days, for general road racing, 25 mm is the norm, with wider tires used for rougher roads (like Paris-Roubaix) and gravel (like Strade Bianche). The larger contact patch reduces friction between the tread and the road, and the lower pressures let the tire roll rather than bounce over the texture of the pavement.
#60
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
there's a tire size for everyone these daze. experiment or don't. mess with tire pressure or don't. u b u. if the body feels better riding skinnier tires, rock on. if the body feels better riding fatter tires, roll on.
if you like them both, you're obviously completely insane and already under surveillance 24/7.
Likes For diphthong:
#61
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
Pros are heading to 26mm now, for example Remco recently won the worlds on 26mm. That might be as big as it gets for the pros, it is harder to make things aero with 28+mm.. the rim depth needs to increase by a square factor to keep the flow attached.
#62
Quoted: 514 Post(s)
Liked 448 Times
There was a run of Specialized Roubaixs from 2008 that were hard-pressed to take anything fatter that 24 because of the rear brake bridge, and my Giant TCR C0 never saw 25s because of the small gap to the fared seat tube. It seems that with fatter tires race bikes are returning to the more practical and versatile geometries of the '70s and '80s.
One thing about wider tires is that at some point you need wider rims. After trying 28s on my 10 year-old Madone, I'll either back off to 26s or 25s or rebuild the wheels with wider rims.
#63
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,987 Times
25 seems the optimal size for me. I have tried wider but generally do not like the mushiness of the ride, particularly if out of the saddle.
Another factor almost never mentioned is that the wider the tire the more mass. Not your best friend when climbing. I realize that modern technology has reduced wheel and tire weight considerably. It also adds to the complexity.
I am somewhat of a Luddite when it comes to such things. Rim brakes, aluminum 32 spoke handmade wheels, cup and cone bearings are for me. Simple things I can repair and ride! I guess that leaves me in the minority and a bit out of touch. At my age, it’s just fine.
Initially, I rode 28s, because I started on a touring bike and that is what they had. I went to thinner tires (23) as I transitioned to a road bike, and was OK with it. If you asked me, I probably would have guessed there was a small speed benefit, but not much.
What I find interesting is that despite the obvious ride benefits of a larger tire (IMHO, pretty much known for decades), 20 years ago, all of the effort in improving ride was focused on frame materials and geometry. Then, elastic inserts and the like. Not the low lying fruit of larger tires and lower pressures.
Until, that is. we started seeing reports that wider tires were actually faster in most common circumstances. They gained broad acceptance pretty quickly once that was demonstrated.
As for me, the widest tires my bikes will reasonably handle are 25s. And that's fine.
#64
Thanks for sharing that , my Scott Speedster 60 which I acquired in July had 23's and needed replacement -just ordered some Fincci tires on amazon . they are 25's and am able to run 80PSI no problem . So much nicer ride than the 23's at 90-100 PSI . ( I'm 130 Lbs wet , in cycling shoes )
Bike looks to be able to take bigger yet , wont happen anytime soon. Yes I am still running tubes.
#65
Quoted: 1591 Post(s)
Liked 1,018 Times
Am I the only one who doesn't really notice much difference between 80 and 110 on 25s? I generally ride on pretty good roads so perhaps it matters less.
#66
Quoted: 1950 Post(s)
Liked 2,011 Times
Must be nice roads in Tallahassee. 80 to 110 is huge.
Modern race bikes are harsher than vintage Columbus or Reynolds with low tension low profile wheels. Wider tires at lower pressure can smooth the modern race bike’s ride. I don’t have any carbon or aluminum bikes but I do notice a difference between vintage steel and modern OS and OOS ceteris paribus.
#67
Quoted: 514 Post(s)
Liked 448 Times
#68
"Am I the only one who doesn't really notice much difference between 80 and 110 on 25s? I generally ride on pretty good roads so perhaps it matters less."
I do notice a huge difference , the roads are bad here. Lots of em have gone decades some much longer without a new surface. At that ,a new surface might be considered slurry seal over gravel on the old miserable road.- not an actually paved & rolled asphalt surface.
Biggest notice of lower pressure is less impact running over the grooves crosswise in the road where a motorbike was laid down or in business driveways where a trailer has gouged the surface . Catches me by surprise sometime - like hitting the rumble strip.
#69
Quoted: 514 Post(s)
Liked 448 Times
Must be.At 80 I worry about bottoming out. 115 feels like a jackhammer under my perineum. 90-95 feels just right.
#70
That quote was from Jon C on post #65, I just don't have good editing skills. My comment post # 68 following the quote actually says the opposite about whether notice a difference . Just to clear that up .
#71
Quoted: 4806 Post(s)
Liked 3,929 Times
And yes, narrow is the rule on older race bikes. My Pro Miyata ('83) takes 24 max. Never measured the Fuji Pro I raced in the '70s but I could not get a finger between the tire and seattube, even with Criterium Setas. Of course, non of us knew what width tires we were riding. I could, with full contact with the seattube, just get my cotton training tubular wheels in the horizontal dropout inflated. Rides on both of those bikes were/are superb with decent tubulars that are way too skinny for this age.
#72
Quoted: 514 Post(s)
Liked 448 Times
Minor point - they never go really fast at Paris-Roubaix, even on the pavement. The route is essentially flat. Now I did some descents in Cycle Oregon three weeks ago that were fast enough for tire width to make a big difference. Close to 50 mph. Aero rules at those speeds.
As for tire clearances, much depends on the nationality of the builder. In the mid- and early '70s I rode Charles Roberts frames. These easily took 26s, which at the time were the girthiest tubulars available. One Roberts had fastback chainstays, which meant 26 was the absolute limit. At the end of 1979 I started riding a Gios, made in Italy, that easily took 26s, although it was a bit of a pinch to get a fully inflated one past the chainstay bridge. The same goes for my '80 California Masi.
American builders were producing a mixed bag. They were building a lot of special purpose geometries in the '70s, with steep angles, tight clearances, and vertical dropouts. Ben Serotta was doing a lot of this before he got the 7-11 contract. And his 7-11 bikes showed his early tendencies, like relieved fork crowns and seat lugs--the reason Eddy Merckx got the contracts for the following years. A lot of us Cat 3s believed fancy frames would unlock the door to placing high and getting upgraded. Eventually we saw that the guys who were winning, the true all-arounders, were riding standard Italian road bikes, or British, American, Spanish, and French bikes that emulated the Italian all-arounders.
I started to see special Paris-Roubaix builds toward the end of the '80s. These had slightly slacker angles and more fork offset. And Pinarello may have led the way in eliminating the chainstay bridge to facilitate wheel changes. Going into the '90s with alternative materials and sloping top tubes, geometries generally appeared to become more specialized.
#73
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
Note: the forum list for bicycle racing and the equipment that dominates that activity is farther down the menu.
#74
Quoted: 514 Post(s)
Liked 448 Times
A couple years ago I bought 23s for my fixie, because I thought they looked better. That was a mistake.
#75
I like bike
Quoted: 267 Post(s)
Liked 283 Times
I'm not suggesting anyone get a new bike just to run wider tires. I ran 23s up until a few years ago and I don't feel like anything life-changing happened when I bumped up to 30s. But I'm definitely happier there.
Likes For scottfsmith:
