Your advice on a groupset
Quoted: 19 Post(s)
Hello all!
Have not been here for quite awhile
I would like to (buy and) install a new 11 spd group on an old cyclocross bike (of 9 speeds).
1. The current setup of 50/34 and 11-34 works alright for me.
2. in the new build, I prefer to use a 50/34 Dura Ace 9000 11spd crank that I have.
3. I am told that a long cage XT RD (have a long XTR one now) is not going to work with 105 sifters, and was advised to get a GRX group
My question is, please, what 11spd shifters, derailleurs should I buy so that they will work well with the above crank?
I'd be happy to have a cassette with even bigger cogs (36..40)
Thanks!!
J
Thanks!!
J
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Xt/XTR are mountain pull and 105 is road pull. What you need is a Wolftooth TanPan or a Jtek Shiftmate to translate the pull ratio between the two.
Car dependency is a tax.
https://bikepacking.com/gear/guide-t...t-drivetrains/
Search for Mullet Drivetrain on Google and you'll get many more results.
Base2 is correct above.
Quoted: 19 Post(s)
in the new components, this is not going to work, that is known. This is why I am trying to learn how to do it right
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
GRX would be your better bet for using STI levers with wider range cassettes or move to Gevenalle GX levers (assuming mechanical short pull braking) and then you can use an XT or XTR derailleur.
Likes For veganbikes:
Quoted: 19 Post(s)
Yes you may have because 9 speed the pull ratios were the same and didn't change till 10 speed which they diverged and continued that trend because why not.
Thank you. Will GRX work with the Dura Ace 9000 50/34 crank ?
Quoted: 6193 Post(s)
Liked 4,809 Times
Depends on which specific GRX components you are talking about. If a GRX FDR, then I'd check the specs. But for a rear DR, probably not an issue. What matters for that crank is what the Chain Line of the rear is. And to a lesser extent that the front DR can work with the Chain Line that the crank is. Your DuraAce road crank is probably a 43.5mm chain line. So what is your rear wheel's cassette set up to handle? Probably about 43.5 on that old a frame. But I'm guessing.
You can check the compatibility between current Shimano components here....
https://productinfo.shimano.com/#/com
and find most everything else here...
https://si.shimano.com/en/#/
Likes For Iride01:
Quoted: 1819 Post(s)
Liked 1,693 Times
As far as I know, GRX shifters are only available for hydraulic disc brakes. Does your bike have disc brakes? However 105 11 speed shifters will work with a GRX rear derailleur. A GRX front derailleur will not work with your Dura ace crank, due to chainline issues, but a 105 front derailleur will work with it. So, what you need is a pair of 105 11 speed shifters, a 105 front derailleur and a GRX rear derailleur
Quoted: 19 Post(s)
Thanks!!
Quoted: 19 Post(s)
https://bike.shimano.com/en-EU/produ...-R7000-GS.html
Likes For Hondo6:
Quoted: 19 Post(s)
I'd be happy to have a 36 cog and even a bigger one. I guess a longer cage is required
Should choose a rear D that will handle an 11-40T cassette
Thanks!
Thanks!
Quoted: 2338 Post(s)
Liked 2,822 Times
Hello all!
Thanks!!
J
Thanks!!
J
https://www.rei.com/product/131427/s...B&gclsrc=aw.ds
I am potato.
Liked 1,629 Times
All this talk of new derailleurs, GRX, etc...
I still don't understand why the $45 Wolftooth TanPan I suggested that works with his current and more capable parts inventory is being skipped over.
https://productinfo.shimano.com/#/sp...r%20Derailleur
Quoted: 19 Post(s)
Hi base2,
The XTR RD currently on the bike was used (not new) when I got this bike in Jan 2006 - it is 16-20 years old with not a single problem
I prefer to stick with shimano especially considering that I am not in the US and this Woiftooth product is unknown here, not to mention parts if needed
Liked 4,809 Times
Shimano also says that RD-RX812 is only to be used with their ST-RX810 or ST-RX600 shifters. So take that into consideration too.
https://productinfo.shimano.com/#/co...453&acid=C-454
Quoted: 19 Post(s)
Liked 2,822 Times
Liked 2,822 Times
per shimano specs this is not for 2X setups
