What's the most common reason front shifter won't grab 2nd gear?
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times
I tried to clean it per many youtube suggestions to no avail. I don't think it has to do with the "pawls" not catching.
youtu.be/LLzSLiv8wak(if ya wanna look at my vid)
Maybe I didn't clean it enough? I used vinegar. Thought I'd flush it out then lube it after determining crud in there was causing problems. I really don't know but it doesn't feel like a dirt issue.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Incorrect adjustment is likely the most common reason. Then come gummed up and broken.
Quoted: 839 Post(s)
Liked 1,061 Times
Vinegar isn't a good cleaner for this. Try some solvent of some type. WD-40 works good and most people have some on hand. Spray it in there real well and keep trying to work it through the gears a bunch of times. Try this and report back. Here's juntjoo's video.
Likes For Crankycrank:
Quoted: 6196 Post(s)
Liked 4,810 Times
You say in your video it won't grab the second position. However we watched you shift from the 1st position to the second. Also not convinced I saw you shift each direction fully+1 or 2 extra pulls while keeping tension on the cable.
I can only assume this is a 3x shifter and you have a 3x crank on the front of your bike. However I can imagine that some shifter manufacturer might use a 3x indicator for a 2x shifter if you aren't going to see the 3 on the indicator during use.
So what other components do you have that the shifter is connecting too?
Quoted: 506 Post(s)
Liked 639 Times
Quoted: 103 Post(s)
Liked 8 Times
So what are you saying? They might have made it for 2 only but for cheaper manufacturing just made it look like the 3 shifter?
Liked 4,810 Times
If your bike is only 2x, then you only need one click. 3x and you get two clicks.
