Silca Pump Maintenance
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
My 84 Trek road bike has the original Silca pump. It still works fine but I am wondering if there is any lube / preservative I can put inside for the seal.
Whats your thoughts, if it works don't fix it ?
Quoted: 1829 Post(s)
Liked 3,376 Times
not sure that it matters a lot, but I've used Phil Wood grease... mostly because it doesn't seem to break down over time. In contrast, I've seen white lithium grease dry up and get pretty solid over time.
Steve in Peoria
Steve in Peoria
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
Petroleum jelly (vaseline) is what many of us used a million years ago. I've found with old dry pump leathers that proofide and other leather dressings work nicely to soften them.
Brent
Brent
Quoted: 809 Post(s)
Liked 1,023 Times
+1 on Vaseline. That is because it is so available and it works. One of the things that think is that if it works well on skin, then it should work well on leather. After all leather is skin. Yes, I know there are differences, however, aside from the specialty creams, this generalization works.
Quoted: 327 Post(s)
Liked 250 Times
Thanks for the info guys. I have used Proofide on my Brooks saddles, I will try it first.
Bikes: Indeed!
Liked 3,478 Times
Brent
Quoted: 930 Post(s)
Liked 1,292 Times
In case lubing doesn't work, note that after failing to revive the pump leather on one of my three Silca Impero pumps with multiple attempts at lubing and conditioning, I decided to replace the leather. Although Silca sells leathers for their floor pumps, they don't seem to sell Impero leathers. The only place I could find them was HIGH END Used & Vintage Bike Shop! We stock Campagnolo XTR TA Suntour Parts NIB NOS
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 164 Post(s)
Liked 102 Times
The rubber seal where you insert the tire valve can also dry out, I just had to replace one.
Quoted: 569 Post(s)
Liked 582 Times
All the above will work but you should be aware Silca makes what they recommend we use, NFS leather conditioner and pump lube, it's not cheap for a 1 oz bottle but I figure the pumps are expensive and I expect my kids will be using them someday when I am not around.
Quoted: 4512 Post(s)
Liked 6,385 Times
Liked 6,385 Times
I have used mineral oil with good results both reviving and maintaining the seals, especially after cleaning the sludge off the inside of the main body tube.
Most of my ancient Silca's work just fine and some are cracked at the top as many are so they are fully retired from active duty, acting as a Talisman but would get you home if necessary.
At this point for me, they are mainly a flourish, so many C+V bikes look incomplete to me without one, especially if they have a pump peg, holder, etc.
I also carry an inflator/pump, spare tube, far too many tools, etc. so the Silca is mainly for fun and correctness style points for me.
Quoted: 569 Post(s)
Liked 582 Times
My son-in-law racer swears by Nix Frix Shun the UK outfit and I suspect this is there lube plus a leather conditioner. I rotate religiously through bikes so do a lot of pumping and add a couple drops a couple times a year and my now vintage pump feels great but can't really say that it adds life as I rebuild the pump only a couple years back and use the Silca NFS on the piston gasket and Molykote PFPE on the chuck gasket.
Likes For easyupbug:
Liked 6,385 Times
I broke down awhile back and sprung for Silca's synergetic chain lube awhile back and finally just used it when I installed a new cassette. Sort of cleaned the chain checked it for stretch and on with the new, it had been jumping around a bit before but may have mainly been my crappy adjustment.
That lube made a huge difference even if the old cassette was worn, very impressed and the bottle alone is almost worth the cost, really applies it the way I like it to, very small steady drop by drop with no dripping or wasting, not a single drop on the floor and all on the chain where I want it, all good.
Quoted: 569 Post(s)
Liked 582 Times
I come from industrial maintenance and found sometimes it is mad science and unfortunately sometimes it turns out to be mad science spin. But when it's a well established company with a reputation worth holding onto and being careful with it it is a pretty safe bet.
Liked 6,385 Times
At work, the track, on the road and everywhere in between, combine mad science with mad and practical skills and we are golden, making $$$ and delivering many azz whippins as well as receiving plenty too.
