Wearing padded shorts many times without washing?...
Flying Pig
Bikes: 06 Specialized Allez Sport, '10 Trek Fuel EX 7
Hung my shorts after using it for the 4th consecutive time cuz that's my only one
Is this....uh.....normal? I don't wanna feel dirty and nasty, but hey, the insides don't smell...yet.
I'm a dude, if that helps..
Figured it's not like underwear where I'm in it entire days - now wearing those 3 days in a row in summer is nasty
Some shorts say the chamois are "anti-bacterial" but how???
of Clan Nrubso
Bikes: Cannondale F400, Surly LHT,Motobecane Le Champion Ti, Novara Veloce
Usually considered a bad idea. Bacteria turns minor chaffing into nasty saddle sores. The only thing that I can think of that might help, and I'm not recommending this as a substitute for laundering, is to use a chamois cream that has antibacterial agents in it; maybe hops or tea tree extracts.
I use a little bit of this stuff mixed in with my chamois cream-
https://www.amazon.com/Tea-Tree-Cooli...431258&sr=8-22
A little goes a long way though.
Bikes: Kona Ute, Nishiki 4130, Trek 7000, K2 Mach 1.0, Novara Randonee, Schwinn Loop, K2 Zed 1.0, Schwinn Cream, Torker Boardwalk
4 times is nasty. Wash those things! Get an extra pair to switch out in between washings.
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times
Everything I've read said it's a bad idea. I do it anyway and have had no problems. Come to think of it, I break a few other "bike rules/wisdom." Use your personal experience and some common sense. How long are your rides? Four half hour rides vs four century rides certainly take a different toll on the shorts.
You gonna eat that?
Alternately, wear cycling underwear under the shorts. I got some wicking stuff from Target that was labeled cycling underwear. They are kind of like briefs but extend down to almost mid thigh. I change those out every ride; the pants I wash maybe once a week or so. The cycling undies help everything stay where it should, if ya get my meaning.
Flying Pig
My last 4 rides averaged an hour or so. I might try out those tea tree gels, not for the pain relief but for the ummm..hair friction.
Closest sports underwear at walmart I found was https://www.walmart.com/ip/Starter-Me...horts/11026738
Wonder if people will mistake those for plain lycra if you don't wear anything over them lol.
Bikes: 2010 GT Tachyon 3.0
Quoted: 45 Post(s)
https://www.laundry-alternative.com/drying.htm
Pick one to suit your needs. The small one should work for your base layers; but the big one is awesome and you can go ahead and use it for general laundry needs to cut your power usage down, so it may be a better investment. I've found that you have to actually let it run-- you get a stream for the first 20-30 seconds, but if you shut it off there stuff comes out wet-ish. 2-3 minutes later (of drip-drip-dripping), it'll come out nearly dry--my compression shirts come out wearable o_O
Buy a bucket and a small plunger. Put in a quarter teaspoon of soap and a gallon or so of hot/cold/whatever water. Plunge for about a minute. Drain, rinse, wring dry if you want, throw in spin dryer.
The whole process should take you about 5 minutes once you've done it a few times.
Not sure on cleaning chamois, ask someone who knows about chamois if you're using that. How do you normally clean that stuff?
Bikes: litespeed, cannondale
Most shorts these days have synthetic chamois (the real kind comes from a kind of goat leather). Synthetic chamois are washable. You should not have any problem just throwing them into the washing machine on gentle cycle. They can also go in the drier at a low temperature.
If you want to be really careful, you can hand wash them with woolite or campsuds in the sink. Rinse, ring out and hang to dry. They usually dry over night.
It is a good idea to wash shorts after each and every ride.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Depending on how long your rides are, that's a recipe for saddle sores.
Modern shorts with synthetic chamois dry quickly. Buy another pair and alternate them, washing after every ride. Your butt will thank you.
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
+ 1000
Buy at least one or two more pairs and wash them between rides or be prepared for saddle sores or a similar fate.
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Unless it rains, it doesn't take much to hang dry the shorts for a few hours. Even if it's still damp, take it in at night and let it dry out overnight.
In hot humid days, its not about the length of the ride. Once the jersey and shorts get sweaty, its so easy to soak them while you wipe down the bike.
Quoted: 2952 Post(s)
Liked 3,106 Times
Nasty.
of Clan Nrubso
But you should skip the balms and spend the money on another set of shorts/skivvies. Four times is just wrong dude.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Sweat tainted with fourth ride bacteria may percolate down into the seat and anything your shorts touch. Then your bike will always faintly smell like a locker room that someone took a crap in unless you take to washing out the inside of the frame with Lysol.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
do you wear the same underwear for four days straight? gross.
Every day a winding road
What's the problem with washing your shorts??? Water is cheap. Toss them in the dryer if not dry. Better yet just buy a second pair.
Geessh!
Geessh!
Flying Pig
Lol, no worries all, tis the first time I wore 4x in a row, usually go for 2x before washing since my rides are a bit short. I'll skip the tea tree balm and get some extra shorts.
First time I heard of saddle sores, though, so good to know.
Unless it is a very cold day and it was like a 30 minute easy ride, yes I would wear them twice.
During this hot summer no way, it is simply nasty.
Twilight Requiem
Bikes: TrekFX
Each evening you need to shove that chamois pad into your face so it smothers your lips and nose. Sniff away and "take it in". Mmmmmphhhh! Mmmmmmpphhhh! Mmmmmmmmmmpppphhhhhhhh!
That's how Floyd Landis does it anyway....
Of course, huffing a pad that has been exposed to chamois cream with steroids will probably get you disqualified if you didn't ride hard enough that day.. but that's another story.
Peripheral Visionary
Liked 5 Times
It's very easy to wash them too. Get some hot water going in to the sink, seal the sink, get a handful of laundry detergent, splash kersplash, bitabang, bitabong, wrinkle out the water, 3 minutes done, set to air dry.
I wouldn't use laundry machines because that could wear them out sooner.
Bikes: Specialized Allez, Specialized Sirrus
Quoted: 17 Post(s)
My commute to work takes almost 90 minutes and I'm usually pretty sweaty. I rinse my bike shorts and jersey when I'm in the shower, roll them in a towel while I'm getting dressed, then hang them in my cube. By the time I leave for the commute home, everything is dry. They go in the washing machine after the commute home. Wash your shorts while you're in the shower if you don't want to do laundry after every ride.
Quoted: 4236 Post(s)
Liked 2,949 Times
I only have a 30-45 minute commute so I hang them to dry and wear them on the way home, but once this summer comes and it gets hotter, I'm going to be bringing a second pair for the ride home. Then they go with my other cycling gear for washing (I tend to wash with my regular laundry on the regular dark(cold) cycle, but I put it all in a washable mesh laundry bag so it's easy to separate from the rest of my clothes so I can line dry it while everything else is in the dryer.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
