Play In Rear Hub
Play In Rear Hub
Old 06-23-22, 03:08 PM
daniell
Quoted: 200 Post(s)
Liked 65 Times in 42 Posts
Play In Rear Hub
This is an eight speed Deore hub.
I removed the cassette to adjust the cones.
This is the problem.
I can discern no play in the non drive side.
Yet the drive side has significant play.
The freehub also has some play.
daniell is offline
Old 06-24-22, 06:32 AM
daniell
Quoted: 200 Post(s)
I think that I need a new freehub. It may be better to buy a new hub.
daniell is offline
Old 06-24-22, 07:07 AM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 264 Post(s)
Liked 122 Times in 101 Posts
Open it up and see what's going on first.
blamester is offline
Likes For blamester:
Old 06-24-22, 07:25 AM
daniell
Quoted: 200 Post(s)
The cassette is off. There is considerable amount of play in the freehub. When I try to wiggle the non drive side axle, I have no play.
daniell is offline
Old 06-24-22, 07:42 AM
bboy314
bboy314's Avatar
Quoted: 332 Post(s)
Liked 740 Times in 385 Posts
Have you tried tightening or removing the freehub?
bboy314 is offline
Old 06-24-22, 07:46 AM
Crankycrank
Quoted: 837 Post(s)
Liked 1,061 Times in 745 Posts
As blamester mentioned, you have to take it apart in order to know what's going on. Wiggling things around won't give you, or us, any insight as to why it's loose. You may have a damaged bearing ball, pitted hub races and cones, needs a cleaning and lube, etc., etc.
Crankycrank is offline
Old 06-24-22, 08:26 AM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
I guess the first question is did you try to put pressure on the end of the DS axle, or pull toward the NDS, to see if the play does move from DS to NDS. I've adjusted cones and find that sometimes I can feel play on one side, but if I try to put pressure the other way I can feel the play on the other side. The only word in your post that is concerning is the word significant.
I'm no freehub body assemble expert, but basically you have a inner core, with pawls, and an outer shell. A simplistic view the inner core gets attached to the hub, and the hub bearing cup is threaded tightly onto the inner core. The outer shell just rotates and any freehub body shell play doesn't impact the play in the hub bearings.
You can see in the image from Park Tool, the bearing cone threads onto the inner race/pawls core and is tightened against the adjustment washers:
If the freehub body is not firmly attached to the rear hub, there can be play. Or if the bearing race is not tight and it moves there can be play.
John
70sSanO is online now
Old 06-24-22, 08:32 AM
daniell
Quoted: 200 Post(s)
I took the hub apart and tightened the freehub with a 10mm Alan wrench. I made it as tight as I could get it. It did help somewhat.
daniell is offline
Old 06-25-22, 03:02 AM
daniell
Quoted: 200 Post(s)
I just assembled the hub. The tightening of the freehub bolt solved the problem. Now I must assemble the cassette.
daniell is offline
Old 06-25-22, 06:08 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times in 430 Posts
If that freehub bolt was loose, you may still have problems. That shouldn't have happened, and it may be damaged. Keep a close eye on it. If it reoccurs and a new freehub and bolt doesn't fix it, the threads in the hub are damaged and you'll need a new hub or wheel.
The last time I needed to replace that style freehub, I bought a NOS hub pretty cheap on eBay and stripped it. If there's a bike co-op near you, you'll probably find salvaged parts there.
andrewclaus is offline
Old 06-25-22, 10:13 AM
daniell
Quoted: 200 Post(s)
Thanks for the input. I think that any problem that develops will be gradual.
daniell is offline
Old 06-26-22, 05:23 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
I have had that same problem with a Shimano freehub in the past and my solution was the same as yours. Problem never came back
alcjphil is offline
