Is my left crank arm on enough?
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
So I wasn’t expecting any issues here but I’m worried that the left crank arm on my 5800 105 set isn’t on the spindle enough.
The bike has 68mm BB shell, I fit in a Shimano BBR60 bracket, and when I slide the spindle through and put the left arm on, it’s only on about half-ish way. This seems not good to me.
Yes the drive side is in as far as it can go - I used a mallet to lightly tap it in as far as I could.
Everything I read said the BBR60 and FC-5800 were compatible…
Is this normal or am I screwed?
Quoted: 2026 Post(s)
Liked 1,096 Times
There should be a plastic "bolt" that threads into the crank arm and is torqued lightly (say 10 inch-pounds) by hand that fills in that gap before the clamping bolts are tightened.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
What Hillrider said. It sets the torque before tightening clamping bolts.
Is that not a silver spacer that is between the crank and bottom bracket? I don't have the same 105 BB but my 105 crank extends through the BB a bit more.
Licensed Bike Geek
I don’t recall Shimano calling for a spacer between the NDS crank arm and bottom bracket.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
That silver washer, "ring" as it's referred to in the Shimano instructions, came with the crankset and there is one that sits between the BB and the crankset parts on both sides. I'd gain some mm back if I took them out, but as far as I know they are both supposed to be there....?
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
unless I'm interpreting the manual wrong?
https://dassets.shimano.com/content/...5000-3966A.pdf
Happy to take them out if it's OK for the crank to be right up against the BB
Likes For the sci guy:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I believe this is not the same crank set as the 5800.
Quoted: 114 Post(s)
Liked 119 Times
Does the item -4 (plate) shown in either of the above diagrams interface into the hole in the spindle. From your photos, it looks like it does, but want to verify.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
it's possible those "spacers" are left over from when a shop installed this crank on my 2016 specialized roubaix - and it required some funky wedge shapey adapters to work. when we took it off before I sold the bike I just grabbed everything that was with it. hmmm
Quoted: 839 Post(s)
Liked 1,062 Times
Quoted: 114 Post(s)
Liked 119 Times
I view that clip as a visual go/no-go gauge. If the metal pin that protrudes from the clip fits into the hole in the spindle, then you're good to go. I the metal pin does not fit into the hole and clip is not flush with the crank arm, then something is wrong.
Likes For MudPie:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The silver spacer(s) should NOT be there. Remove it(them) and use the plastic screw to draw the crank arm on to the axle, then engage the safety plate and tighten the crank bolts.
Likes For cxwrench:
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
The more I think about it, the more likely I think this is happening:
So yes,
I will indeed do this.
Thanks everyone. So nice to have a sounding board. I tried googling it and google was like wtf are you even talking about?
Quoted: 6196 Post(s)
Liked 4,810 Times
Do you know what that little plate is between the pinch bolts on the crank arm? That's the stopper plate. It'll let you be able to tell when the arm is on far enough. However in the pic, it looks like you'd get a false positive. That arm needs to go way further.
This is the manual you should be using if the exploded diagram you linked and called a manual is correct for your crankset.
https://si.shimano.com/api/publish/s...001-01-ENG.pdf
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
Thanks - yeah I removed the spacers are it went on much better, and the left arm slid way more onto the spindle, and everything looks 100% better. mm's matter!
