Nitto Mini-Bullhorn Bar???
bironi
Quoted: 98 Post(s)
Liked 291 Times
Does anyone here have one?
I would like to know a few measurements.
Is the 34cm width c-t-c or os-os?
What is the outside diameter at the bar ends?
What is the length of the straight grip section at bar ends?
Thanks in advance for any useful responses.
Byron
Byron
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
No, I don't own one, however, based on this link >>> https://www.bike-components.de/en/NI...lebars-p67072/
1) Width measurement is C-C
2) The OD could be either 22.2mm or 23.8mm
3) The reach is 112mm
bironi
Quoted: 98 Post(s)
Liked 291 Times
I went ahead and ordered one, crossing my fingers for the 23.8mm OD.
Likes For Bianchi pc:
Quixote
Bikes: Bianchi Pista Concept 05, Level 2014
Quoted: 44 Post(s)
Liked 78 Times
Nitto Rb 030 (38cm) Nitto b 264 (34cm) Unauthorized reproduction of Scott 100k bar
Nitto b 264
Some context and the measurements asked for.
bironi
Quoted: 98 Post(s)
Liked 291 Times
Thanks again Bianchi PC.
I ended up with bars that look similar to your hall shot.
I'm no where near to your slammed stem, but that's what works for me.
70 yrs here, and you?
Quixote
Quoted: 44 Post(s)
Liked 78 Times
No problem
I'm 52
I liked them on top of the stack of spacers too. Where they are in the pic pulls me a little forward and puts a little more weight on my hands.
- both positions work for me now but from looking at the Bike forums c&v threads I suspect that like most people there will be a point for me where either the bike goes up on a wall to look at and not use or... the stem gets raised.
cheers
I'm 52
cheers
bironi
Quoted: 98 Post(s)
Liked 291 Times
One more question if I may,
The reverse brake levers I have currently are Tekro RX 4.1
They have an adjustment hex screw to adjust the lever distance from the bar to accommodate different hand sizes.
What I don't like is that there is no nub extension beyond the lever for out of saddle climbing.
I climb on my road bars with my index fingers in front of the levers.
I see that the Cane Creek 2000TT reverse brake levers provide an extending nub that would allow for my index fingers to pull up on to add to overall climbing strength.
I hope that translates?
Has anyone used this Cane Creek model?
If so, do they have the same adjustability hex screw set up?
I like the Tekro's, but want the Cane Creek nub.
Thanks in advance.
Byron
Thanks in advance.
Byron
Fxxxxr
Quoted: 2671 Post(s)
Liked 1,151 Times
the bars are compatable with most anything and are as comfy as a flat bar
Likes For jack pot:
bironi
Quoted: 98 Post(s)
Liked 291 Times
What brand is your fixed gear?
Are these the same bars I recently installed?
I like the look of your crank.
Thanks much!
Thanks much!
