Chinese out front combo mount
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
I bought one of the cheapest out front combo mounts I could find on eBay. It had no instructions, so when I figured out what went where, I took a bunch of pictures.
The mount has no branding anywhere, including on the packaging, but I bought it from the eBay seller "otohappy":
https://www.ebay.com/itm/40329745549...mis&media=COPY
It includes plates to mount Garmin computers, GoPro cameras, and, I think, Bryton computers. I've never heard of Bryton, but they're apparently a Taiwanese company that has a proprietary quarter-turn mount, similar to Garmin, but different. It does *not* include adapters I've seen in similar ads, for strapping a bike light to the GoPro mount or for mounting your phone to the Garmin mount. I was initially disappointed that it didn't include those two adapters, but I don't think I would've been happy with my current light in one of those strap-on adapters, and I'm fine with pulling over to use my phone. The battery wouldn't last through a ride if the screen was on the whole time, anyway. I do want to get a GoPro now, though.
Box front
Box side with specs
Box side with color options
Product in tray
Note hinge to fit around handlebar, and 3-piece construction
Underside of mount
L to R: Garmin plate (G3), GoPro plate (G5) (flat side), Bryton plate (B)
L to R: Garmin plate, GoPro plate (bumpy side), Bryton plate
Contents of hardware bag: (3) plates, (2) hex keys, (2) flathead screws, (2) small panhead screws, (1) medium panhead screw, (1) large panhead screw, (5) split lockwashers, (1) sheet of pre-cut self adhesive pads
Continued in next message.
Box front
Box side with specs
Product in tray
Underside of mount
Likes For RichSPK:
Quoted: 282 Post(s)
Liked 129 Times
Contents of hardware bag showing opposite side of sheet of pre-cut self adhesive pads
Note that I didn't use the self-adhesive rubber pads. I'm not sure where they're intended to be used, but I'm guessing you stick them inside the clamping jaws, between the mount and the handlebar.
Use the medium panhead screw and (1) split lockwasher here, securing it around the handlebar
The GoPro plate bolts to the underside of the mount with the (2) small panhead screws and (2) split lockwashers. The large panhead screw goes through the side of the GoPro plate.
The Garmin or Bryton plate bolts to the top of the mount using the (2) flathead screws. Don't try to use lockwashers with flathead screws. You'll have (2) spare lockwashers.
Riders view of mount
The mount is sized for larger bars than mine, so I cut up an old inner tube to shim it
Side view of mount
Front view of mount
Three quarters view of mount
At least its made out of metal. I ordered Bryton's own mount as an add-on when getting my Bryton computer. That mount snapped at the hinge when I tried to install it. Maybe I was suppose to use the micro hex wrench so I can't exert much torque, but it had a plastic adapter so it will fit onto the 25.4mm diameter bars, which made feeling when it was tight enough hard to feel. At least the aliexpress seller is willing to send a replacement for 1 cent so it can be tracked (I wasn't able to pay for the 1 cent order with paypal so I had to opt for the $1 option). I noticed yours didn't include any padding to grip the handlebar. Maybe the ability to crank down the bolt is enough for the mount to stay in place.
Personally, I got the for my other bike the out front mount that attaches to the handlebar tightening bolts. But you only have 1 stem bolt, so you couldn't use that type.
Quoted: 282 Post(s)
Liked 129 Times
Aluminum is pretty soft; you have to be careful not to over-torque the screws in this mount, too, so you don't strip the threads.
Quoted: 5224 Post(s)
Liked 3,581 Times
fwiw - I have a cpl mounts like this, different end but same design for clamping the bars. I think the design can be better. I've used soft inserts, but I don't like the movement/vibration w/ heavier objects like a gopro camera. I try to use a more firm insert to keep the movement down. mostly, I use mine for lights. I get better stability w/ my gopro mounted directed to the bars. based on looking at the thing vibrating in front of me as I ride. the camera image stabilization is good enough to work around the vibration, but it doesn't have to work as hard mounted directly to the bars
directly on bars
on accessory mount
that said, I also like mounting the camera on the front of the helmet. because then it captures what I'm looking at. but video from the bars can be fun too
directly on bars
on accessory mount
Likes For rumrunn6:
This mount did include some self-adhesive rubber pads that I didn't use. There's not much point, with all the inner tube I wrapped around the bar.
Likes For tubesocksFred:
Quoted: 282 Post(s)
Liked 129 Times
Yeah, I saw that mentioned in listings for similar mounts. I expected to need to improvise a spacer between the mount and the bar, although I didn't expect to wrap the inner tube so many times. It does allow a little bit of movement in the mount, as rumrunn6 noted, but I don't expect it to be a problem. We'll see.
