C&O Canal from Cumberland to DC (184 miles)
Quoted: 79 Post(s)
So here goes.
I've just recently gotten into biking and own two bikes currently. I have a Trek Mutltrek 7200 (2015) and a Raleigh c-200 (both hybrids and pretty bare).
I've recently been to Cumberland, MD and to the C&O canal visitors center and afterwards I have a strong desire to bike the entire canal (from Cumberland to DC). This would be 184 miles self-supported. I've read a few different blogs and seen a few bikes and I'm quite frankly not sure if I have the equipment to do it. I do not own a rack mount and I notice pictures of bikes with "saddle bags" on the rear and the front as well. I also want to record video of the whole thing. I have several questions.
1. Is my trek bike good enough, It's an aluminum frame with 35c tires. It has a front suspension fork, however I'm thinking of replacing it with a rigid fork due to weight and the flex a suspension fork has. I'm sure I will need to equip it with a rear rack and saddle. Not sure which ones I need to get.
2. I want to shoot video on my gopro the entire way. The problem is the battery on my gopro session 5 only gets about 1 hour total of battery at 720p. In addition I suspect I would be riding in the night depending on how much I'm willing to ride. So I was looking at a Shimano Nexus Dynamo Hub, how are things in terms of resistance. I'm concerned that it will slow me down etc. Do they generate enough for a USB to charge a gopro? I would also put a front light in the center. But likely not run both at the same time.
3. In terms of timing. I read that usually this is a 2 day trip. I also read someone doing it in roughly 11 hours. I would love to hear from someone who's done portions of the trail etc.... I believe if I get some good music going I should be able to ride for several hours in one shot.
4. Are there any bike communities or groups that concentrate on that trail etc...
5. What type of tools and parts I should bring. I imagine I should bring a few spare tubes, patch kit, muti-tool.?? The food stuff I'm going to have to find out elsewhere unless someone has some ideas.
If you are capable of doing back to back centuries on the road, then you should be able to do it in two days. A 20 hour video of trees and a dirt path would be pretty boring. Maybe consider just recording some interesting footage, rather than the entire route. As far as the bike is concerned, the wider the tires the better and fenders are a good idea for the potential mud.
I've ridden the trail twice but not with the speed you have in mind. I think a 2/3 day trip on the GA can be done with most any bike. alan s recommendation of wide tires and fenders is a wise idea. 35s are fine. You do not say if you plan to camp. If not, I would not worry about a rack. I credit card toured for many years with a handle bar bag. Something that holds a change of clothes and a few other things would be plenty. Just wash your your stuff at night.
As for recording your trip, the GA is not eventful. Having said that, I am not sure any of our torus were worth 100% recording. But, you might have something else in mind.
There are groups that take care of the trail. Here is one https://gaptrail.org/
You may also want to check out crazyguyonabike
Every day a winding road
If you have no experience riding the C&O, I would not advise doing it at night. It is hard enough to negotiate it during the day, especially if it is wet.
The bike you selected will be fine. I did it on a Trek with 32C. You will want fenders.
[QUOTE=spinnaker;20614972]If you have no experience riding the C&O, I would not advise doing it at night. It is hard enough to negotiate it during the day, especially if it is wet.
I agree with this.
I agree with this.
Quoted: 18415 Post(s)
Liked 15,543 Times
https://gaptrail.org/about-us/who-we-are
The latter is managed by the N.P.S.
mr steppen, given that you have just recently gotten into cycling are asking about if you should bring spare tubes etc, I have to say that 90 mile days, 145km + , two days in a row, is very likely not realistic for you to do given your riding experience, unless you are regularly doing this sort of mileage already and are comfortable with this.
even on nice paved roads, without any baggage, this distance two days in a row is just plain hard, and not something to be done if you are not properly prepared, and trail surfaces simply mean you cannot hold a given speed as easily as on pavement, and you will be expending more energy to go at X speed.
also, any bike fit issues, saddle position, bars position, shoe fit, will get shown up with such long long days, and could easily result in some physical issues that mess things up.
Moreover, there are places where the C&O Canal towpath is closed due to flood damage and/or construction.
I can't imagine who would want to view GoPro video of riding the entire distance of the towpath. Except for a few places, the scenery along the canal simply doesn't change all that much between Cumberland and DC.
There are people that do the whole distance from Pittsburgh to DC in 36 hours so 90 miles a day certainly is doable but you would have to be a maniac.
+1
You might not have enough light for filming on the C&O. With that canopy of trees and add the fact it is often overcast, there can be very little light on thr trail.
Quoted: 79 Post(s)
This is why I was mentioning the Shimano Dynamo and the front lamp.
Quoted: 79 Post(s)
I would not post and entire enless gopro video. I would likely edit it showing significant areas. Or I would fast-forward it etc... The end result may be 10mins or so....
Quoted: 79 Post(s)
I've done the C&O, on a hybrid bike with 35mm tires. I put on a rear rack and added rear bags but we (my wife and I, who was on a mountain bike with bigger tires, rack and rear bags) were not camping - we stayed at motels, so didn't carry tent/cooking stuff. I had one flat with those tires, I'd probably choose 38MM if I was going to do it again, but definitely doable on 35mm.
These days you can buy "bikepacking" handlebar bags and expandable seat/saddle bags, you could carry enough without a rear rack.
It is an easy 3 day trip, either camping or "credit card style" touring like we did. It is a doable 2 day trip camping, but I'd first try doing a 75 mile ride on the road (or a smooth surface rail trail like the Great Allegheny Passage trail) first and see how you feel - any discomfort you feel, you should imagine it much worse if you did 90 miles on the C&O.
There is a Yahoo Group focused on the C&O Canal Towpath, but it is not very active - here. There is a more active GAP/C&O forum here.
Since the canal is a nation park, the US Park Service runs it and has a pretty good page detailing conditions and outages here.
You can also look for trip reports on sites like Crazy Old Guy on a Bike or CycleBlaze.
I also hike a lot on the towpath, at least on sections from Harper's Ferry to DC, and do frequent section rides from Williamsport to DC. Personally, I would not do a C&O Canal through ride if there had been more than 4-5 inches of rain in the previous month - there are many sections that turn into mudholes. This year has been particularly bad - we have had 20" above average rain this year - I doubt there was a 4 week period where we didn't get at least 8" of rain.
If you decide to do it after lots of rain, I'd definitely put on fenders and carry a chain cleaner brush or some other cleaning tool.
Hope that helps, John P.
Liked 15,543 Times
Up to you. How far can you ride your bike in one day for two days in a row. If two days is your goal, I think Williamsport would be about the closest to half way. There are LOOONG stretches of the canal where there is no where but up or down the canal to go so plan ahead. If you've got food and camping out, you have far more options. It's not like you can say I'm done and just get off the trail at some point and go into town, you may not even see another person or an "exit" off the trail for an hour or so even at biking speed, that exit may be nothing but a county road in the middle of nowhere. Not trying to scare you, just reality. That's touring in general. I do the C&O along with the GAP solo and love it.
Me personally. I wouldn't ride the C&O at night, I do a lot of night riding, just not there. There are times you are 12 inches of slick mud away from dropping into the canal on one side or falling over a hill towards the Potomac on the other. In my opinion the C&O is a unique type of ride. It is long and monotonous at times similar to road and rail trail riding BUT it is neither. You have to be in "MTB" awareness mode the whole time. The C&O terrain and surface changes constantly and you have to pay attention, pick your lines, dodge debris, change sides, and watch the terrain, add in a decent speed and any fall foliage masking the trail and it gets exciting. Fine if you are ready for it but chances are you a little tired, your mind was wondering, you were reaching for your bottle, looking at your chain, etc and you have 10-25lbs of crap strapped on your bike.
As for closures. Like mentioned, the NPS site is about as good as it gets. I've found official closures and detours that I ignored and had no problems and non closures where there was 12+ inches of the Potomac water on the trail and you couldn't tell what was river, trail, or canal.
If you are from the Cumberland area.. Try a day trip to PawPaw and back and get a feel for it, that section is a good mix of what to expect for the rest.
Last year I rode in the heavy rain at night for two hours from Cumberland to get to a campsite. It was challenging, but not unsafe. As far as preparation for a long ride, pick a destination 100 miles from home, ride there, spend the night, and ride back the next day. If you can do that without difficulty, you should be fine riding the entire towpath in two days. Or do a 100 mile loop from home two days in a row.
As for food, there are too many variables. Are you going to cook? Stop and eat? For a two day trip, I'd do restaurants on the road and cold food at camp to keep the gear carried and time spent cooking down. For me, I usually have at least one leisurely meal on the road at a restaurant, snack throughout the day, and maybe cook something at camp, but I'm not in a hurry.
Good luck. I hope to do this trip as well before too long, but maybe a little slower.
Quoted: 79 Post(s)
As someone has said I would probably alternate between lamp at night and video during day. Again I would probably not even run the camera the entire time.
Not sure why you would want to video the whole thing anyway. It is pretty much just trees and a muddy path. The lock houses can interesting and the aqueducts but that is it aside the pawpaw and Great Falls. What you see in the photo I posted is pretty much 90% of the trail.
Don’t forget to stop in the towns along the way. Harpers Ferry, if you’re never been there, for sure. Antietam is a short diversion, and well worth it. Brunswick, Shepherdstown, Williamsport, Hancock.
Antietam isn't exactly a short diversion. It is a pretty decent climb up there (at least from Hancock). I don't see the OP doing these side trips and still making the 2 day deadline.
Speaking of Hancock. Right before you get to Hancock (coming from Cumberland) there is the Western Maryland Rail Trail. It is a paved path that parallels the C&O that wikk allow you to make up some time.
+1. I could post three pictures and sum up 90% of the ride. One with a canal on one side, some raised up semi-gravel-dirt grass riding surface, and trees on the other side and maybe the river somewhere way off to the side. One picture with nothing but trees and thick brush on both sides of a narrow opening, two narrow gravel paths similar to tire tracks in between them, and the third picture... Similar to pic 1 or pic 2 and maybe substitute a slightly open area with a field or something on one side.
Not discouraging any filming of the trip but the C&O, would be cool to go back and remember some of it maybe but it is about as far from a sightseeing and awe inspiring visual stimulating ride as you can get. It is very quiet, very calm, very peaceful, very alone though. Just my 0.02
