Freehub for 120 or 126 spacing?
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
Long shot, I know. Any modern freehubs made that fit or can be adapted for 120/126 spacing? I know there was a brief period when Shimano's top group (?) had this, but these were never common & are scarce & expensive used, last time I looked.
Have a ~1987ish Schwinn Cruiser Supreme (tig-welded hi-ten, probably Giant-made) & I've made a decent city/commuter/utility bike out of it. Main problem is bending freewheel axles, I'm 250 lbs. Would rather get a robust wheel than start over with a new bike.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Ok if I address the axle bending? When you're big, with no suspension, it's rough on your axles every time you hit a bump.
You have to make it a habit to get your rear off the seat when you hit a bump or go off of a curb, then your axle bending woes will stop.
At one point in my life I was 300+, you're not alone.
I'm not big into the modern equipment, so one of the others here will have to help you there, but axle bending I know quite well.
Likes For Schweinhund:
Quoted: 1163 Post(s)
Liked 442 Times
Look for a Shimano 7 speed cassette hub that has the uniglide/HG combo freehub body. These can be mountain spec (135mm spacing) or road spec (130mm spacing). Shimano 105, Ultegra 6208, Deore LX, Deore XT, etc.
You can obtain a 7 speed HG cassette easily then and you can cut the axle down or get a replacement axle from wheels manufacturing for your 126 mm frame spacing (I want to say axle should be 134 - take your 126 locknut to locknut dimension and add 4.5mm or 4mm per side that gives you a 134 or 135mm length hollow axle you will need.) The wheel will be perfectly strong for your use. Dura Ace 7400 7-speed cassette hubs are more scarce and are not Hyperglide compatible but sometimes you can find a clean one with the Dura Ace Uniglide cassette cheap. These have great finishes with nickel plated cassette cogs and high polish clear ano hub. These are super pretty and can be rebuilt practically forever if cared for.
Likes For masi61:
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
SunXCD makes a 120mm modern rear hub freehub body. They also make/modify the appropriately sized cassette. Unfortunately, they don't offer a 126mm spaced version.
What diameter size wheel are you running? Standard 26" MTB or something else? If so, here's a rather crusty candidate on ebay. The purchase price is on target. Shipping, not so much!
Bob
Bob
Likes For pastorbobnlnh:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
My 'spare' wheels have Shimano RX100 hubs on Mavic MA2 rims and an SRAM PG-850 8 speed cassette (11-32).Rear hub is FH-A551 which is RX100 8 speed, 7 speed version is FH-A550.
All that fits in 127mm so just fits in my 126 OLD frame, but I was building the wheels myself so I just dished it right.
You can fit 10 speed in 126mm, see https://www.bikeforums.net/classic-v...b-success.html
I think the way it works is that if you can fit an 8 speed cassete then the 9 or 10 are the same width with the cogs closer together.
Likes For Aardwolf:
Likes For Steel Charlie:
Another option: NOS Shimano Exage-level hubs. These are still available from a vendor in France on eBay. Hubsets are HB-RM50 front, FH-HG20 rear. Cost is around $45 including shipping to the US (does not include local sales taxes) if I recall correctly
Not world-beaters, but eminently serviceable and reliable. And since they're NOS, there's far less to worry about re: trashed cones/cups than used.
The hubsets still available are 100mm OLD front, 135mm OLD rear. But the rear axle can be cut down and drive-side spacers removed to yield 126mm OLD spacing (not sure 120mm is do-able). Or the axle can be replaced with a NOS Shimano 10x1x137mm axle - those are still available on eBay as well.
The rear hubs are 7-speed HG-only, but appear to be the original HG-only freehub that only accepts a 12T or larger smallest rear sprocket. Per the late Sheldon Brown, a 1mm spacer behind the cassette will allow use of an 11T smallest rear sprocket.
Likes For Hondo6:
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
Shimano rear hubs with 126 spacing and hyperglide compatible 7 speed freehubs are around. A 1055 105 hub would be a good example.
Likes For BradH:
Quoted: 360 Post(s)
Liked 328 Times
Andy
Andy
Likes For beicster:
Quoted: 1303 Post(s)
Liked 1,911 Times
dufffer1960,
As I work through the pile of parts on my work bench, you are in luck! You may have all four of these hubs for the cost of shipping to you. The three on the left are 135, and fourth is 130. Cut the axle down a few mm and perhaps respace the hub and you should be just fine. Cost of shipping should be about $15. PM me. Smiles, MH
These are all available should duffer not want them. Hubs have been claimed 12-3-22 MH
Likes For Mad Honk:
Quoted: 3241 Post(s)
Liked 2,512 Times
Quoted: 1088 Post(s)
Liked 1,205 Times
dufffer1960,
Quoted: 1562 Post(s)
Liked 1,734 Times
3 options:
1. buy a 7 speed freehub body and 137mm axle from Ebay:
And swap it onto your typical 8 speed Shimano 600, 105, RX100, RSX, etc hub.
2. Find the 7 speed versions of the above hubs: FH6401, FH1055, FHA550, FHA410
3. If your primary concern is bending axles, you could stick with freewheels but switch to a hub with sealed bearings and thicker tubular axles: Mavic 500, 501, 550 (probably a few more in that 5** series); American Classic, Phil Wood, Hi-E, Bullseye, Kingsbery
They basically look like this:
You are not going to bend this axle.
Likes For icemilkcoffee:
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
dufffer1960,
The far right hub is a 126
OP can have it if it suits his needs.
The 126 hub I have is an FH-HG20, not an Exage. and it's lightly used
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
Spend $5 on an 8 foot 2x4 and spread your frame to 135mm. It’s not complicated and for sure it’s less work than lacing up a wheel with a 126mm cassette hub.
Likes For C9H13N:
Quoted: 1858 Post(s)
Liked 664 Times
Likes For Road Fan:
Bikes: 1985 Roberts SLX, Mercian 531, 1984 Torpado SLX,1981/82 Peugeot PSV-10, 1978 Charlie Roberts full touring, 1970 Charlie Roberts 531 road.
Quoted: 79 Post(s)
Liked 164 Times
The freewheel hub
120,126,130 cassette hubs.
120,126,130 freewheel hubs, might be expensive, they seem to made to order.
Likes For santa fe 2926:
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
26"/Mountain wheels. Frame is heavy hi-ten w/ 120 spacing. I force it apart to 126 so I can have 6 speeds... much improved vs 5 speeds. Single chainring, so 6 is all I get.
Wow! Quick note to Thank you all. Multiple ways to go... gotta think on this one.
