Disc discoloration on brand new bike
Quoted: 2700 Post(s)
Liked 486 Times
Hey guys, I just bought my first dentist bike a couple days ago, so I want to take better care of it than most of my bikes because it’s 10x more than I’ve ever paid for a bike. The front disc brake has some discoloration on it, and I wonder if that is normal. I am very paranoid about disc brakes rubbing and getting out of alignment, almost didn’t buy the bike because of ‘em but the owner was convincing that I wouldn’t have issues like I do with cheap disc brakes. Needed something to get to work the next day so I pulled the trigger.
I’ve ridden it a couple times, and the disc brake is rubbing slightly (wtf!) but it’s not slowing the bike down much. I think most people wouldn’t care or even notice the amount of disc rub, but I am intolerant of any. I wonder if this very slight misalignment could be responsible for the photo.
my buddy says the discoloration is some paint or something, but I think it’s heat. The bike is brand spanking new though. I live on the top of a hill and am like 240-250 lbs now. Kind of unhappy with the stopping power too, but I tend to ask a lot from my front brake
Quoted: 6974 Post(s)
Liked 10,975 Times
Your bigger concern should be sliding right off that saddle and over the handlebar.
Likes For Koyote:
Quoted: 242 Post(s)
Liked 456 Times
meh, no longer care...
Likes For Kai Winters:
Did you buy new, or used? If it’s new, have the shop take care of it. If it’s used and it’s bothering you, a fresh rotor is about $60.
Mind you, a fresh rotor is no guarantee. I have Shimano XT rotors on my bike, and the front rotor not only came slightly out of true, but one of the floating rivets occasionally gets stuck after prolonged braking, resulting in more rotor noise until I soft-press the brakes again to get the rotor to realign. I’ve mitigated the warping using a big pair of pliers to bend it into place (so no more rotor rub under normal circumstances), but that may have aggravated the sticky rivet. It’s not enough to be bothersome, but definitely enough to be noticeable.
Btw, if you do decide to use pliers to correct any warping, make sure to clean them with rubbing alcohol first to prevent contamination.
A discolored rotor usually indicates heavy use, such as hard braking for a longer period of time as when descending a mountain pass. It is possible the dragging brake will cause this, but it needs to be dragging fairly heavily on the rotor.
Likes For TiHabanero:
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
I have discoloration just like that on my front rotor. Mind you, the bike's got >2500 road miles on it and I weigh just North of 200#.The braking surface doesn't get discolored because you keep wearing off the surface
I'm also a little confused - you say it's "brand spanking new", but then refer to "the owner", which sounds more like you bought it used. Compared to your other bikes, any bike less than 10 years old. This bike could easily have a thousand or two miles on it and still look pretty new. And if the owner does much climbing (and thus descending), there's no reason the rotor wouldn't have gotten heated up a bit.
Quoted: 682 Post(s)
Liked 453 Times
That post above by Kai is outstanding. Often amazed by the effort people on here will go to to help other cyclists.
The bike and brakes are both excellent so I don’t think you’ll have any long term problems. Take a look down the face of the rotor between the calipers with a light or white paper behind, as you rotate fhe front wheel and you should be able to see whats causing that rub. it’s fairly easy to realign the calipers if they are a little out of whack. I also don’t tolerate any brake rub at all.
I didn’t know Wilier made rotors. Suspect they get someone else to make them and put their logo on.
and yeah, your saddle needs to be horizontal
If that heat effect is from heavy sustained braking, perhaps intermittent, earlier braking down your hill from home will help. Gives the rotor a chance to cool slightly between pulls on the brake rather than constantly building heat.
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
If it over-heats, it will discolor. Try an XT/Ultegra rotor for better heat dissipation.
Congratulations on the new (even if just to you) bike. Don't let the pessimistic naysayers and incorrigible vultures of ill-omen be off-putting.
Some people advocate aiming the nose at the center of the handlebars, exactly as it seems to be done on that bike. If it creates problems, or you just want cheap effective birth control, tip it up.
Liked 11,923 Times
Easiest way to stop brake rub: get one of those thick business cards. Fold it in half. Take the wheel out, put the folded card over the disc. Re-install the wheel, sliding the card and rotor in between the pads. Loosen the caliper mounting screws enough that the caliper moves freely. Squeeze the brake lever and hold it while you tighten the caliper mounting bolts down. Remove the wheel and card and tighten the mounting bolts to spec (usually 5-6 Nm). Reinstall wheel and spin. Rub should be gone. If you do choddo's paper trick you should see white on either side of the rotor.
Liked 486 Times
Liked 486 Times
Y’all don’t micromanage my saddle tilt, it’s like that deliberately, and I ride a lot. Don’t own a car.
bike has like 15 miles on it I’ve had it for like 2 days
Liked 486 Times
Are you suggesting that the discoloration is an oxide layer or something similar, and the reason it is only on the inside is because it’s being worn away by the braking? I think you are wrong, but that is an interesting idea that I hadn’t considered.
Quoted: 3957 Post(s)
Liked 7,310 Times
Likes For tomato coupe:
Quoted: 242 Post(s)
Liked 456 Times
I'm done here...
Liked 486 Times
I do appreciate your post btw, might reference it if I get around to fixing a couple of bikes whose disc brakes are useless and shops keep fixing them and the adjustment going bad quickly.
Likes For LarrySellerz:
Quoted: 682 Post(s)
Liked 453 Times
https://cyclepal.co.uk/products/cycl...41198340800675
There are cheaper versions too.
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
There's no way to spin that saddle misalignment. It's just wrong. Ride a century or even a metric like that and report back.
Likes For shelbyfv:
Quoted: 4420 Post(s)
Liked 4,873 Times
I’ve never heard of a bike fitter advocating that approach to setting saddle tilt! 😂
Likes For PeteHski:
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 158 Post(s)
Liked 146 Times
https://www.bikeforums.net/15364878-post8.html
I'd look for warp in the discs showing this coloration, may be why pads are rubbing. Heat could also come from pad friction if they're improperly adjusted, something you have some control over. If they're warped from excessive heating you may want to source replacements before riding – and braking hard – over too many more miles.
Quoted: 682 Post(s)
Liked 453 Times
it’s just obnoxious to hear “your saddle is angled wrong” as if I didn’t deliberately set it there. Said y’all because there were 3 commenters. The guy who fit my bike didn’t complain when I asked for it to be angled down twice.
Some problems tend to only show up after fatigue sets in a bit. I did 65 miles this morning (151 this week) and the load that saddle tilt would put on my shoulders holding me from sliding forward would definitely be painful over that kind of distance.
Likes For njkayaker:
Liked 7,310 Times
