Campagnolo cable tension adjuster - where to find replacement?
Folks, I just bought an older hand built Italian Tommasini that I am trying to rehabilitate.
I have broken cable tension barrel adjuster.
I need help finding a replacement if you can point me in the right direction.
It is from a Campagnolo Chorus rim brake gear train set.
I would like to buy two so that I can replace the other one also and have a single spare.
Since I am new, I am not allowed submit a photo. So, I can only describe it, it is 28 mm tall, has knurled head. Head is 10mm in diameter and is 9 mm tall, which leaves 19 mm for the threaded portion below the head.
Quoted: 5793 Post(s)
Liked 2,595 Times
The days of factory supported small oart service are long gone. To their credit Campagnolo was among the least to abandon their users.
I see 2 options. If you have a relationship with a shop that sells and services Campagnolo, their mechanic might scavenge one from his RD scrap bin. Most save broken parts in bins for this very purpose.
Otherwise, I'm sure the Campagnolo service center has one on a returned RD, and should help you if you ask nicely.
BTW the odds of success at a bike shop go up if you stop off and pick up a couple of Cannoli first.
brake cable adjusters?
downtube/head tube shift cable adjusters? These last are frame-specific rather than “Campag-specific”. I looked into some for my frame and going loads on eBay. Pretty sure the threads are standard, but if frame-specific, doesn’t matter if Campag /Shimano/whatever
which barrel adjusters are we talking about? It sounds like you’re talking about paired adjusters, so unlikely to be the RD adjuster (ie on the RD itself). I dont think Campag FDs have an adjuster.
The unbroken on is on the left side of the head tube and the cable that passes through it also goes down to the bottom bracket, but it terminates at the front derailleur.
Thank you for asking for more information and for trying to help.
Thank you for the suggestions.
The broken adjuster's receiver (the place it screws into) is welded to the side of the head tube (where the headset bearings are housed). There is one on the left side and one on the right side of the head tube. The broken one is on the right side of the head tube. The cable passes through it, then down under the bottom bracket and terminates at the rear derailleur.
So, the adjuster I need isn't directly attached to the read derailleur and does not look like the adjuster that is normally found there.
If I lived near a bike shop, I would follow your suggestions and see if they could help.
Quoted: 4212 Post(s)
Liked 3,883 Times
I'll second Francis's suggestion of checking out a LBS. IIRC the threading of the adjuster is M5x.8, a common thread size. If the adjuster barrel is frozen in it's base that bolts to a shift lever boss it will likely be easier to replace the entire base and adjuster as a unit. Do both sides if you want a matching look. No need to retain the Campy brand here unless you have a thing about that. These frame boss mounted cable stops with barrel adjusters were dirt common for quite a while only a decade+ ago. They were essential when converting an older frame (or a newly manufactured one that wasn't "updated" to current no frame located shift levers) to Ergo or STI levers. They came with each aftermarket pair of Shimano STI road levers for many years.
I, and likely many here, have a few pairs somewhere in my stash. If you can't find any locally (and who knows where that is, no location provided yet) get back to me and I'll take a look. Andy
AndrewRStewart
AndrewRStewart
Hello,
I don't know where you are located but you could check out the Marinoni website at store(dot)marinonicycles(dot)com. Sorry, I also cannot leave a link. When you get to the site, click on the world symbol to change to English (they are locate in Quebec). Under the menu go to Drive Train, Rear Derailleur, Parts. Look for Cable Tension Adjusters and click on it. You will see a number of examples. Click on the small pictures to get a larger version. Maybe one of these will look like the other one and work.
Good luck,
Harry
Good luck,
Harry
Liked 3,883 Times
"If I lived near a bike shop, I would follow your suggestions and see if they could help." jp185149
Well, that answers that I do have a new pair of black plastic stops with Shimano like adjusters and a single right/rear side black plastic stop with weathered grey adjuster that I can send you for the cost of shipping and a beer. This won't happen till later this week so if you're in a hurry hit up EBay or Amazon. If you're interested let me know and I'll PM you my email (IIRC you can't send a PM for another 7ish posts). Here's a pic of the pair and single stops. Now back to house duties before the wife comes back from her walk Andy
PS- Whatever you do make sure the replacement adjuster is greased before threading the cable through. I have seen dozens of bikes where the front/left side adjuster is still freely moving but the right side isn't, for easy to understand reasons... the first being no lube in the threads.
AndrewRStewart
AndrewRStewart
Quoted: 1821 Post(s)
Liked 1,697 Times
Andy
Thank you so much for the suggestions. The broken part looks like the knurled metal portion of the rightmost object in your photo. The threaded part is snapped in two. I think something hit the head of the adjuster and broken it (about 1/3 down from the head). The receptacle it screws into is welded to the head tube and looks nothing like any of the objects in your photo. I was able to unscrew the broken end out of the receptacle. I wish I could post photo...it would make this so much simpler.
Enjoy your holiday and thanks again for your help to date and hopefully for more suggestions after the holiday.
Jim P
Jim P
Liked 1,697 Times
Andy
Jim P
Jim P
As an example, I have an older Look 481SL. It has a 10 speed Campagnolo Chorus component groupset. The bike has barrel adjusters on the downtube like your bike. I built the bike up from a bare frame. The barrel adjusters were installed by Look at the factory long before I installed the derailleurs. If I had installed Shimano components, I still would have used the same adjusters
That makes a lot of sense. I will try to research what they have/use. I may contact them directly and see if they can help. I appreciate the idea.
Jim P
Jim P
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
many of these on ebay campagnolo downtube cable stops in Cycling for sale | eBay
in this application the Shimano part works fine too
/markp
/markp
Likes For mpetry912:
Likes For 13ollocks:
Liked 2,595 Times
Since it's a braze on, you have no assurance as to the thread. Most, but no all, are the same.
However you have the broken part out (or it's partner on the other side) and can measure the thread. Or post a photo of them here.
Either way, someone here can point you to a readily available part that will fit. Buy 2 so they match.
Likes For FBinNY:
I ride Campagnolo on most of my bikes, and I have a few sets with the official Campy adjusters that fit over the downtube shifter bosses. But I prefer the Shimano adjusters with the little paddle/lever for the right-hand side. Easier to make on-the-fly adjustments. I think these came with the higher-end product such as 105/Ultegra/600/Dura-Ace.
BTW: the adjusters are left and right specific. But you will probably have to buy a pair. And the adjusters are specific to your frame type. The ones that have a flat back are designed for the alu frames with big oversized tubuing. The curved back versions are made for traditional small-diameter steel frame tubing.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
I
Also, dedhed these links resolve a number of great online sellers, Golden Velo and NonStop Cycles are two good ones.
/markp
/markp
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
These are from a Campy Record rim brake set and should be able to be sourced from somewhere.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
Velo Orange has these options. They're not Campagnolo, but would work. For what it's worth, I have three Campy equipped bikes and consistently use the Shimano cable stops.
https://velo-orange.com/collections/parts
Quoted: 839 Post(s)
Liked 1,064 Times
Just pointing out that OP has mentioned at least twice that he has braze-on, headtube, threaded adjusters, NOT the downtube shifter bosses so the downtube screw-on adjusters mentioned will not work.
Likes For Crankycrank:
Just wanted to let you know that I did contact the US dealer for Tommasini and they have the correct parts in stock....you had a great idea and I thank you for pointing me in that direction.
Likes For jp185149:
Likes For wheelreason:
Parts have arrived from the Tommasini US dealer. They aren't the original ones the factory installed so many years ago, but they do fit and do work. Thank you again for that idea. At some point, I will finally reach 10 posts and finally be allowed to post a photo of my rehabilitated Tommasini fire (in Italian colors).
Likes For jp185149:
