5 bolt Chainrings for MTB.
Old 10-07-10, 12:04 PM
kralizec
I have a white industries crankset. It doesn't have any chainring bolts or chainrings, but I want to use it on a giant cadex.
Is there anyplace I might find chainrings for this or would I just have to steal them from another older crankset?
These are the older style, and when I looked around all i found new was 4 bolt chainrings for MTBs.
kralizec is offline
Old 10-07-10, 08:10 PM
Thor29
Thor29's Avatar
Your question doesn't make any sense. Current model White Industries cranks attach the chainring in a totally different way that doesn't use chainring bolts. You can only use chainrings that are made by White Industries.
However, if older White Industries cranks did in fact use 5 bolt chainrings, just measure the bolt circle diameter to determine what chainrings you need to buy or swap. Once you have the bolt circle diameter, try Universal cycles: www.universalcycles.com
Thor29 is offline
Old 10-07-10, 09:32 PM
lubes17319
Chronic 1st-timer
lubes17319's Avatar
Bikes: ...take me places.
If you have something like this, you need a tool to remove the old ring & replace with this.
To help find your B.C.D. on 4- or 5-bolt rings, print & use this ez chart.
lubes17319 is offline
Old 10-11-10, 10:43 AM
kralizec
it is indeed 5 bolt, with BCD of 110, 74. But when I looked on ebay it seems like all the mtb cranksets are 4 bolt now and no one seems to be selling the older 5 bolt which have the 44 33 22 teeth count rings.
Or if they do have them they are like $100... so why even bother with the older stuff?
kralizec is offline
jezmellors
Bicycle Mechanics
4
04-26-14 03:26 PM
tsappenfield
Classic & Vintage
3
11-26-13 08:16 AM
clearcastle04
Bicycle Mechanics
2
12-18-10 12:00 AM
illdthedj
Singlespeed & Fixed Gear
20
10-07-10 03:13 PM
illdthedj
Classic & Vintage
4
10-04-10 05:40 PM
