Ebike Suggestions 2024
I would appreciate suggestions for a first time ebike that I can transport on my light trailer hitch.I don't need an aggressive position type bike. My scenario: USA, Honda Fit, Trailer Hitch, light off road, Types of riding, light gravel roads and trails, Mickelson Trail (Black Hills),Katy Trail (Missouri), lower Wisconsin and Michigan. Nothing too challenging, fire roads.
I am 72, 210 pounds.
Something that can carry enough for water, overnight camping. rear rack, panniers, or frame bags, etc.
Local dealers are limited to central Illinois. They seem to cater to commuters. Which makes sense.
TIA!
TIA!
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 138 Post(s)
Liked 309 Times
Budget, budget, budget.
I'd consider a Gazelle if you can pay the freight. Beautifully made, known reliable components, belt drives, serviceable.
Example:
https://mikesbikes.com/collections/g...-c380-mid-step
I'd think a hardtail with suspension fork will handle conditions you describe. I have a gravel ebike but it's not outfitted for racks and such. It would handle the roads/less challenging trails but not cargo.
Happy shopping!
Example:
Happy shopping!
Thanks, Rick. That is an excellent bike, but a bit pricey for my first endeavor. I do like the mid-motor, and the belt drive.
I will be visiting friends in Salt Lake this month, and will see many different models.
Clark W. Griswold
Quoted: 4432 Post(s)
Liked 4,076 Times
A +1 for Gazelle. Spend the money now and get the bike you want now, the less you spend the more you spend. A lot of people will buy a bike they are less happy with to "save" money and then end up going for the bike they want after that so they are buying two bikes but not two bikes to own at the same time like many people on this forum would do but one after the other.
Belt Drives are super low maintenance and last a long time and an Enviolo hub is even less maintenance (aside from occasionally replacing cables and housing like you would on anything) and with a Bosch motor they are extremely well supported with little you have to do so in the end. They seem a little expensive at the front end but in the back end they are low cost bikes to own. You are buying parts with good support from a brand that also has good support so you really are spending less overall.
Try and find a local shop or try one when you travel and you will be happy. If you don't have a lot of great shops near you then Bosch is your friend where a lot of shops don't have any interest in servicing bikes with random no-name motors most shops will support Bosch or can easily get support for Bosch without having a ton of knowledge so it is a good way to go.
Quoted: 889 Post(s)
Liked 840 Times
I agree with the above and have a friend who rides her Gazelle "e" daily and loves it. The other consideration which may be valid is this is a 50 pound bike AFAICT, and you'll need a good bike rack (I recommend 1 UP).
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 126 Post(s)
Liked 69 Times
TIA!
TIA!
Cheers, Mike
Cheers, Mike
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 284 Post(s)
Liked 381 Times
You never said what your budget is, except that Gazelles are too expensive. (understandable; they're a nice Dutch brand)
Also, what's the story on your trailer hitch? How much weight can it handle and how big is the square?
I will recommend the Ride1Up Portola. With this bike and a Honda Fit, the trailer hitch is optional; you just fold it up, put it in a big Rubbermaid tote and slide it into your hatch. (if you can lift 60 lbs or so) I have an ongoing review thread on the bike here:
https://ebikesforum.com/threads/ride...a-thread.5915/
Even if you won't be lifting it, you might find the folding aspect to be nice when it's time for winter storage: just fold it up, remove the battery to inside your house and stick it in a corner of the garage or basement.
Aventon makes quality eBikes these days. Their Pace 500 model might fit the bill. They have local dealers but are not priced like Treks. Not quite the same quality, but I don't think you'll be disappointed, either.
You seem to be in central IL. I'm in SE WI. If you want to make a road trip up here, I'll offer you test rides on my fleet of eBikes:
We'll ride downtown and get coffee or something. Drop me a line by personal message if interested.
- Ride1Up Portola: 60 lb, multi-gear folder
- Lectric XP Lite: 45 lb, single gear folder
- Juiced HyperScrambler 2: 120 lb. eMoped
- Electra Townie GO! 7D: 55 lb. beach cruiser
- Aventon Level.2: 70 lb. commuter
Likes For Smaug1:
Jazz Aficionado
I’m taking a very good look at the Gazelle Eclipse Ultimate C380+, it’s got most of what I’m looking for, price is on the higher side but doable. Haven’t decided whether to go with the chain or belt for here in Colorado.
Likes For Climb14er:
Clark W. Griswold
Liked 4,076 Times
I think you will enjoy the bike.
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
it's all about budget. an ebike in the 1500 range is about the bare minimum sorry to say. The "best cheap" off AMZN will just disappoint you.
The Gazelle as mentioned, or the Tern in various models, are very good choices and the Bosch motor / BMS are well supported.
one of the problems with the low end bikes is that if the electronics fail, they are not easily repairable.
Pro tip: You don't need to strain your back lifting your ebike onto a rear rack. Lock the rear wheel with the brake, pop a "wheelie" and put the front wheel into the tray, then lift the rear of the bike onto the rack. much easier.
/markp
/markp
Clark W. Griswold
Liked 4,076 Times
[QUOTE=mpetry912;23213541
/markp[/QUOTE]
You don't have to even strain for anything, just get a Thule EasyFold or their new one or the Yakima or Küat rack with the ramp and just use the walk assist feature which most of the quality e-bikes have. The EasyFold ramp just makes it super duper easy or if you want it even easier Saris makes the Door Country which is an electric lift rack for your hitch but honestly I haven't played with one yet so I cannot recommend it from seeing it or using it but knowing Saris racks are cheap but generally pretty decent and if nothing else had good customer service (though it has been a while since I have had to reach out to them)
/markp[/QUOTE]
Check out the Ride1Up Prodigy V2 - it has components like you'd normally find on bikes that are twice the price - Brose mid-drive motor with torque sensor, air-spring suspension fork, 4-piston hydraulic brakes, and options for Gates belt drive and Enviolo CVT shifting. Plus for an e-bike with kickstand, lights, suspension fork, fenders and rear rack, it's pretty light at 58-61lb.
https://ride1up.com/product/prodigy-v2/
Ride more, eat less
Quoted: 723 Post(s)
Liked 758 Times
Lectric XPress e-bike launched as $999 torque sensor commuter electric bike
https://electrek.co/2024/04/16/lectr...electric-bike/
Here are the best electric bikes you can buy at every price level in April 2024
https://electrek.co/2024/04/08/here-...y-price-level/
Likes For cat0020:
Quoted: 138 Post(s)
Liked 309 Times
Quoted: 117 Post(s)
Liked 73 Times
I am a month and about 250 miles into owning a Salsa Confluence; a great value if the either dropped or flat bars can be made to work for you. Weighs @ 33 lbs un-accessorized. I flat out love this bike and I'm very spoiled from 55 years of road cycling and the other machines I have owned!
Likes For Feldman:
Quoted: 341 Post(s)
Liked 280 Times
I've been to those places, Mickelson. Wisconsin, Iowa, Minnesota, gravel roads, etc, with my beater ebike conversions. Poking along at 12 mph, I don't need much power. Rail Trails were intended for regular bikes, so ebikes can easily handle the grades. I doubt I would want to ride on a fire road.
I would recommend a torque sense mid drive bike, because it makes flat tires easier to fix in the field. Also more fun to pedal and should be easier to pedal w/o battery. The above lower cost models should work fine.
Likes For Doc_Wui:
