last rides before ice
Quoted: 5224 Post(s)
Liked 3,584 Times
if you ride winter studs, what are your last rides before they go on?
took the bike out, so I guess I'm going for a ride today. mid-December snow is a blink away, the ice too
edit: got back before the next storm, someone is getting the white stuff ...
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times
I have a dedicated winter bike (Cannondale H600) which the studs stay on. I use the road bike when I can during the winter here in Minnesota, but the hybrid sees the bulk of the miles Dec-Feb. So in short, there is no final annual studless ride. Last year the hybrid saw action in Oct as we got 8" of that white stuff mid-month that messed up the roads for the road bike a couple of days.
Likes For MNBikeCommuter:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4392 Post(s)
Liked 3,016 Times
also, as to studded tires, they are so hard to mount that they go on once and stay on until the end of winter (or really, until early spring). I haven't mounted them yet. I was riding in pretty icy conditions on Sunday on the gravel bike with 42 mm Teravails at low pressure (35 psi) and I stayed rubber-side-down, so all good.
Likes For MinnMan:
Liked 3,584 Times
Liked 3,016 Times
Yeah, true enough. I go down at least once each winter. I've never been injured during a winter ride, though, beyond maybe a bruise on my hip. The ice is your enemy until you go down, at which point it is your friend. I went down at speed some years ago, riding that Trek road bike with skinny tires, when I hit a patch of black ice. Fortunately, it was.a looong patch of black ice and I just slid along the road on my side - no road rash or anything like it. It helped that it was cold and therefore I was wearing well-padded clothes, too.
Liked 3,584 Times
Quoted: 590 Post(s)
Liked 445 Times
I don't mess around with swapping tires and possibly compromising the beads with frequent swaps. I have a dedicated winter wheelset with studded tires that I can swap out with the non-studded wheelset in ~60 seconds, based on the conditions.
Quoted: 1364 Post(s)
Liked 1,678 Times
+1 Second wheel set. Have to adjust rim brakes, so just under 10 minutes to swap both wheels, top off psi and adjust brakes.
Liked 3,016 Times
A dedicated studded tire wheelset sounds like a good idea. No reason that it has to be expensive - after all, the tires are so heavy that "light" wheels would be pointless- something bomb proof with a high spoke count and, if possible, rims that happen to make mounting the tires not so nearly impossible.
But it is a good idea to at least break the seal of the bead on your studded tires now and again. They do take on water, somehow.
Likes For MinnMan:
Liked 3,016 Times
Liked 3,584 Times
Liked 3,584 Times
So, while I'm on the subject.....apart from trial and error, has anybody got a rule of thumb about rims that mount tires easily? Definitely some rim/tire combinations are easier than others, but apart from empirical experience, I haven't noticed any rules. I would guess that wider rims are easier, but some of my wider rims are still a bear with particular tire combinations.
https://www.bikeforums.net/bicycle-m...ce-needed.html
https://www.bikeforums.net/bicycle-m...orn-tires.html
https://www.bikeforums.net/bicycle-m...its-worth.html
https://www.bikeforums.net/bicycle-m...born-tire.html
https://www.bikeforums.net/bicycle-m...res-video.html
https://www.bikeforums.net/bicycle-m...-mounting.html
Liked 3,584 Times
A dedicated studded tire wheelset sounds like a good idea. No reason that it has to be expensive - after all, the tires are so heavy that "light" wheels would be pointless- something bomb proof with a high spoke count and, if possible, rims that happen to make mounting the tires not so nearly impossible. But it is a good idea to at least break the seal of the bead on your studded tires now and again. They do take on water, somehow.
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
My last ride without studs is typically the ride where I fall on an icy patch because I was overconfident in my ability to ride without them (that and a fair amount of procrastination).
My winter bike (drop-bar Pugsley) does double-duty as my adventure/gravel bike in the summer, so I need to make the tire transitions every autumn/spring ... and my summer tires (Fat B Nimble) at totally worthless on snow and ice.
Liked 3,016 Times
re: tires (not wheels) might get flamed but I'm leaning toward folders are easier, wire beads are more difficult (especially any Schwalbe Marathon product). just warm them up & research technique, there must be a thousand bikeforum threads on mounting tough tires
Studded tires last for years if the studs don't pop off, and so I was just thinking of trying to find some rims that match better those Marathons.
Yes, folding tires are easier. But are you suggesting that there are studded folding tires? I've only encountered studded tires with wire beads.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Now is about the time of year that I make the swap. When the overnight temperatures go below freezing, I can no longer trust that there aren't any ice patches hiding out in the shade when I ride to work in the morning. So the studs go on and I put up with the noise and increased rolling resistance until spring.
The commuting bike being a fixed-gear, I have 18T and 16T cogs mounted on the flip-flop hub, and flip the wheel to the 18T when the studs go on. Lower gearing helps since I'll be going slower anyway.
I used to have dedicated front wheels, one with the studded tire, and the other with my nice 3-seasons tire, but since going to dyno lighting, I'm back to swapping both tires. Thankfully, it's not too difficult on my wheels, otherwise I'd seriously consider another wheelset. (Hmm, maybe something lighter and sportier for the summer? )
Likes For ThermionicScott:
Liked 3,584 Times
Now is about the time of year that I make the swap. When the overnight temperatures go below freezing, I can no longer trust that there aren't any ice patches hiding out in the shade when I ride to work in the morning. So the studs go on and I put up with the noise and increased rolling resistance until spring.The commuting bike being a fixed-gear, I have 18T and 16T cogs mounted on the flip-flop hub, and flip the wheel to the 18T when the studs go on. Lower gearing helps since I'll be going slower anyway.
Liked 3,584 Times
My last ride without studs is typically the ride where I fall on an icy patch because I was overconfident in my ability to ride without them (that and a fair amount of procrastination).My winter bike (drop-bar Pugsley) does double-duty as my adventure/gravel bike in the summer, so I need to make the tire transitions every autumn/spring ... and my summer tires (Fat B Nimble) at totally worth on snow and ice.
Likes For rumrunn6:
Likes For Hypno Toad:
Liked 3,584 Times
I could have a YouTube channel about the dumb things I do and end up falling off my bikes
https://youtu.be/6jlFrMVEsnE
Likes For rumrunn6:
I put the studded tires back on my mountain bike last weekend. I broke a tire lever while removing the super tight cheap Kenda tires I had on it. Those tires are awful and will not be going back on, hard ride and slow rolling due to the thick rigid sidewalls.
After one studded mountain bike ride we had a mid-week storm that ushered in fat bike season with the grooming of the first 8 km of trails in the main park. We were able to lay the entire trail down in just over an hour with 17 people working in 6 groups. Unfortunately the forecast has the temperature going above freezing several days this week, there is already more than enough ice around.
I decided to order a new battery for my old Edge 800 so I can use its glove friendly touchscreen this winter. I already replaced the battery in it once but retired it a few years later when it started fading again.
Likes For gecho:
Liked 3,016 Times
We've had a respite from icy conditions. It's cold and windy in Minnesota, but road bikes and skinny tires are still OK.
I've been thinking about the idea of a spare tire set for studded tires. But it occurs to me that I haven' 100% decided which bike I'm going to ride in the full-on winter. I used to ride my steel Masi, but maybe it will be the CF Warbird this year?
Does anybody ride CF gravel/cross bikes in full winter conditions? On the one hand, it's a rather nice bike to subject to all that salt. On the other hand, there are folks out there riding CF fatbikes and all....
The thing is, I actually already have a spare wheelset for the Warbird, though I'd need to get a set of brake rotors for it.
Liked 2,568 Times
Liked 3,016 Times
For those who don't know...
https://www.vice.com/en/article/gqwe...kest-bike-race
Likes For MinnMan:
