Upgrading to a Clutch Derailleur
Quoted: 14 Post(s)
I've got a low-end 3x7 mountain bike equipped with a Shimano Tourney groupset. I'd like to upgrade the derailleur to a clutch derailleur but after hours of research, I still can't find one that is 7-speed and compatible. After doing some reading here, it appears that a Shimano Deore RD-M592 might work even though it is 9-speed. Is that the case?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
Quoted: 14 Post(s)
Now I am finding some conflicting information. Bing AI says that the RD-M592 has "a stronger guide spring but no cage clutch." PerformanceBike.com says: "Chain Retention: Shadow." The Amazon page says it has Shadow and a "stronger guide spring." But I can't find anything that says straight up: this product has a clutch. And I can't find a specifications page for it. Very odd. Do you know of any other clutch derailleurs that might work?
Liked 742 Times
The bike has a KMC Z7 chain.
Likes For maddog34:
Shimano RD for gravel that have 'Shadow Plus' use the Road 11 speed cable pull spec which is also different from Road < 11 speed.
Likes For KCT1986:
Quoted: 14 Post(s)
Shimano RD with the 'clutch' is what they call 'Shadow Plus'. Don't think that there are any that compatible with less than MTB 10 speed. The cable pull of Shimano MTB 10 speed & higher have different specs than Shimano MTB less than 10 speed.
Likes For MattTriv:
Quoted: 14 Post(s)
The conclusion to this thread is that there is no upgrade path from a Shimano Tourney RD to an RD with a clutch.
At the time of this writing, no vendor has seen fit to address this market, despite the obvious widespread demand for such an upgrade. In order to get a clutch RD on a Tourney bike, you would almost certainly need to purchase additional parts such as a shifter, cassette, etc. that would end up costing as much as a Tourney-equipped bike itself. So, unless somebody creates an RD with a clutch for 7/8-speed MTBs, the only practical course of action is to shop for a bike that comes with a clutch RD.
Expired Member
Quoted: 3733 Post(s)
Liked 5,601 Times
Likes For shelbyfv:
Really Old Senior Member
If there was such a demand for 7 speed parts, Shimano wouldn't be dropping some of their 7 speed cassettes & free wheel choices.
Mad bike riding scientist
Quoted: 6250 Post(s)
Liked 4,275 Times
Stuart Black
Stuart Black
Liked 742 Times
And.. by "doing your own shopping", you've learned things along the way.. cool, huh?
something else to learn... you don't NEED a clutch-type derailleur, but they are nice to have... there's a reason that the clutch ders come with an on/off knob.... more research time, eh?
Quoted: 14 Post(s)
I think you are over estimating the demand. This is a very low end component group and few who own it will care whether the RD has a clutch or not. Don't let the absence of a clutch prevent you from riding the heck out of your bike. Folks rode every kind of MTB terrain w/o clutches for years.
As I was researching this issue, I came across numerous people posting about it on this forum and others. How many Tourney equipped bikes have sold in discount stores around the world? A million? A billion? Low-end doesn't mean low volume.
Clark W. Griswold
Quoted: 4437 Post(s)
Liked 4,089 Times
On your current bike it isn't really designed for much mountain biking so it really isn't going to need a clutch not that you need a clutch even if it was. Just ride the bike into the ground and save the money towards a bike with the parts you want. Look for a good air fork at the front and ideally on the low end a 1x10 (or 2x10) drivetrain or find something with 11 or 12 speed and keep up with the modern times.
You will be much happier with the new bike with better parts but more importantly it is the suspension components and other parts of it that will improve and that is more important but the nice thing is when you improve the quality of the front fork and the frame you generally also get better drivetrain components which will work better and last longer.
To put things in perspective 7 speed stuff came out in the 80s and into the early 90s for mountain bike parts by the late 90s which was 23+ years ago we were in 9 speed and 13 years ago 10 speed came out and then about 9 years ago 11 speed came out (on the mountain bike side at least). Unfortunately Shimano and others don't make vintage groupsets so the quality declines for the lesser gears as time goes on.
Quoted: 14 Post(s)
Shimano has a long history of bringing their advanced technologies down to the lower levels. They do that for a reason: that's where the volume is.
Quoted: 14 Post(s)
Just about any derailer compatible with up to a 9 speed drivetrain is going to work and have a stronger spring than the Tourney. That’s really all you need…a stronger spring. A clutch is only really necessary for 1x systems used in situations where you are riding mountain bikes down rough trails where you get lots of chain bounce to keep the chain from falling off the chainring. If you have a front derailer, you don’t have to worry about the chain falling off and, if you have a better derailer than the Tourney, you won’t have to worry all that much about chain bounce. The RD-M592 will work much better than the Tourney. Hell, an Acera (RD-M360) would work better than a Tourney.
Likes For Bill Kapaun:
Expired Member
Liked 5,601 Times
Yes, but how often did they have to stop and put their chains back on?
Likes For shelbyfv:
Quoted: 2026 Post(s)
Liked 1,096 Times
Yes they do but the profit is at the higher levels. Tourney is the absolute bottom rung of Shimano's group sets and they aren't going to invest in significant upgrades or new technology for it.
Liked 3,051 Times
what i think the OP is after in regards to the trickle down tech, they are hopeful that something more modern would be backwards compatible that would replace what the bicycle came with stock as a bolt-on & go ordeal.
-Oh Hey!
-Oh Hey!
Clark W. Griswold
Liked 4,089 Times
It sometimes trickles a bit but not to Tourney, Tourney is designed for one purpose to hit a price point and nothing else. It is not designed to last a long time or work very well it is designed to be cheap in all senses of the word. Some of the better tech does trickle down especially in things like Ultegra/XT or 105/SLX and then some of the stuff underneath that but once you hit the 7/8 speed stuff it had long stopped and never really hit it so much but a lot of that stuff is now 30+ years old so there is no need to trickle anything down. 10 and 11 speed stuff is still modern enough and 9 speed at least was late 90s early 2000s so at least only 20+ years old.
Quoted: 520 Post(s)
Liked 454 Times
All a clutch does is reduce chain slap when using an extraordinarily long chain for an extraordinarily wide spread of gear ratios. I've never seen a 7-speed cluster that went that wide.
Liked 4,275 Times
Chain slap can certainly occur in 7 speed drive trains. Any long in tooth mountain biker has horror stories about chain slap. The best way to avoid it is to keep the chain tight by shifting up to a larger ring in the front. 1x systems don’t allow for that so they need a stronger spring and something to dampen the bounce of the derailer.
Stuart Black
Stuart Black
Quoted: 1840 Post(s)
Liked 1,713 Times
My 3 x 9 setup was high end many years ago when I bought that bike. Clutch derailleurs had not been invented at that point. You simply learned how to deal with its limitations
Quoted: 520 Post(s)
Liked 454 Times
The solution as stated is to never use the 4 smallest cogs when using the small ring. Switching to the middle ring really reduces that problem. Derailleur clutches were a solution that came along when 1x setups became popular
Liked 742 Times
13-40 FREEWHEEL, 8 sp.
https://www.ebay.com/itm/25491715367...Bk9SR9ySwdihYg
i have a 9 sp. 14-42 FREEWHEEL here...from a Hyper CarbonX CF MTB... and yes, the axle was bent :-D The bike is now wearing a 10 sp. cassette and a nice new Deore disc hubset... it also now has a Shimano hollowtech crank, a 1 lb. weight shave.... and a Rockshox Reba fork, a 2.5 lb. weight shave......
etcetera.
not flaming, just updating your knowledge base.
Last edited by maddog34; 06-30-23 at 12:35 PM. Reason: added info, updated tooth count on 9sp.
