Non-Standard BB Shell?
Old 03-13-23, 11:20 AM
VtwinVince
Quoted: 167 Post(s)
Liked 252 Times in 146 Posts
I recently picked up an '85 (I think) Rocky Mountain Giro road bike which I've taken apart. When I went to install a different BB, I found that the diameter of this shell was slightly bigger than normal. I've never seen this before. Has anyone had a similar experience?
VtwinVince is offline
Old 03-13-23, 11:24 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,695 Times in 976 Posts
If by some chance that the frame was built in Italy it might have an Italian threaded bottom bracket shell. What is the width of the bottom bracket shell? If it is 70 mm that would be a clue
alcjphil is offline
Likes For alcjphil:
Old 03-13-23, 01:26 PM
Iride01
Iride01's Avatar
Quoted: 6195 Post(s)
Liked 4,810 Times in 3,318 Posts
Maybe it had a Ashtabula one piece crank in it originally. Those are way bigger shells IIRC. But it's been over a dozen years since I had anything with a Ashtabula crank?
What did you take out of it? Or was it with no cranks?
Iride01 is offline
Old 03-13-23, 04:53 PM
VtwinVince
Quoted: 167 Post(s)
Looks like it's an Italian BB shell on a Canadian frame, and the dropouts are Campy, guess I just got confused. That happens a lot.
Old 03-14-23, 05:52 AM
Germany_chris
I’m a little Surly
Germany_chris's Avatar
Quoted: 699 Post(s)
Liked 1,294 Times in 647 Posts
Some mountain bike BB shells are 73mm vs the 70mm IT or 68mm BSA
Germany_chris is offline
Old 03-14-23, 09:42 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
What is the inside diameter of the shell? Are there any markings on the bottom bracket cups or cartridge that would indicate thread spec? Italian thread is 36mm x 24tpi; English thread is slightly smaller at 1.37" (34.8mm) x 24tpi.
JohnDThompson is offline
Old 03-14-23, 09:45 AM
JohnDThompson
Old fart
And some Japanese built, English thread frames have 70mm shells, and some Italian made, Italian thread frames have 65mm shells. Bottom line: shell width is an unreliable indicator of thread spec.
Old 03-14-23, 08:44 PM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
Good reason to pick up an inexpensive Vernier caliper for the home mechanic.
Camilo is offline
Old 03-15-23, 09:39 AM
alcjphil
alcjphil's Avatar
When you removed the old bottom bracket was the cup right hand threaded on the drive side? If so, along with the shell being too big for the replacement cups you would have a good indication that the shell is Italian threaded
alcjphil is offline
Old 03-15-23, 02:45 PM
pdlamb
Quoted: 2604 Post(s)
Liked 1,933 Times in 1,213 Posts
The cynic in me says there can't be any non-standard BBs. If you took a bear's claw and stuck it through a piece of metal, it would surely be within tolerance for at least one of the many BB standards!
pdlamb is offline
