Outboard Bottom Bracket Bearings ?
Quoted: 380 Post(s)
Liked 541 Times
Is there anything special that I should know about replacing the bearings? Are they all the same size?
TIA
Charlie
TIA
Charlie
Quoted: 4207 Post(s)
Liked 3,872 Times
Can you not just replace with kind that you already have in hand. Or are you converting from a internal bearing BB design (and thus also are replacing the crank arms)? So little information given means my questions are many.
Many external bearing/cup designs are not made to replace the bearing separate of the cup. They are made to be easily fabricated and sold. At one time Phil Wood offered a tool and bearing for the early versions of the Shimano external bearing BBs. I don't know if this is still offered. And depending on the external BB design (brand and family of spec) the bearings can be quite different from another brand. The usual way to install new bearings with these BBs is to replace the cup/bearing unit, generally just called the BB. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1109 Post(s)
Liked 1,200 Times
[edit: I think the first question is what make and model of crankset do you have? It will clarify what you're actually looking for and if it's feasible. In spite of that, I'll leave my response below in case it helps]
I'm wondering if you're talking about the whole external cup bearing unit, not the balls or sealed bearing unit inside of it? If so, just buy a new BB of the type of bottom bracket that your crank calls for. Examples: Shimano Hollowtech type, Sram GXP or DUB type, FSA MegaExo, etc. Those bottom brackets come with bearings installed in the external cups like Andrew R Stewart explained.
On the other hand, my oldish Campy ?power torque ?ultra torque (It's been a while I can't remember which one), does have drive side bearings which are set on the crank spindle, and the external cup is separate, so you can actually replace the bearings themselves. IIRC, the non-drive side is like the above, with the bearing pre-set in the external cup. Disclaimer, I've only dealt with that BB once and it's been many years. I'm pretty sure I'm remembering the drive side situation correctly (I had to replace that sealed bearing), but not sure if the non-drive side cup has replaceable bearings or not.
Regardless, the crankset tells you which BB you need and you can find those BBs or replacement sealed bearings from the crankset company or from other sellers that sell the same type that will work - one example, Wheels Manufacturing.
PS: Steel Charlie Nice to see another Sannino!
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
have you Found replacement sealed ball bearings in the correct size? i looked around for a half hour this time, and once before...
what did the threaded aluminum Housings look like after you got the bearing assemblies out?
did you extract the plastic bore /seal parts without damaging them?
was the price per bearing, x 2 + shipping, lower than the 20 to 30 dollars per new, pre-lubed, BB assy?
did you make an installer tool then press fit them into a heated housing, or just smack them into the heated housings?
were the aluminum threads damaged by your failed attempts to install the new bearings, or did you get lucky?
what grade LocTite did you use and did you thoroughly clean the threads before applying the LocTite??
i'm all about finding bargains in my co-op shop.. i couldn't find those bearings anywhere, including from the largest bearing wholesaler in Portland. (Gxp or Hollowtech)
Let everyone know if you do find them, ok? And update us on what kinds of hoops you jumped through to rebuild a part described as non-rebuildable by most manufacturers.
the bearings are not "all the same size",.and are a special grind to achieve the correct tolerances when installed and lightly side loaded.
What MODEL BB assy are you wanting to rebuild? there are Several different styles/manufacturers.......
buy the new BB assy that will fit your crankset.
Quoted: 2026 Post(s)
Liked 1,096 Times
Assuming we are indeed discussing HTII type external cup bottom brackets. Enduro sells both replacement bearings and the tools needed to press out the old cartridges and press in their "superior" replacement bearings. Both the bearings themselves and the tools are quite expensive and, given the longevity of Shimano's HTII bottom brackets, very hard to justify.
Quoted: 804 Post(s)
Liked 2,985 Times
note the number of seals;
