Grease for freehub body threads when installing cassette
When installing my cassette, is it ok if I just use any grease thats on the market to lube the lockring and freehub threads? Or do I have to specifically use an anti-seize ?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Whatever you have handy, I wouldn't use anything expensive though. Save that for loose ball hubs and the like.
Likes For cxwrench:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I just use Park grease, and that's if I think there isn't enough left on the parts from last time. Perhaps if you plan to leave the lockring on for a really long time or in a salty environment you might use anti-seize...
Likes For ThermionicScott:
Quoted: 114 Post(s)
Liked 119 Times
Any grease is fine. In fact, I dribble a bit of oil/chain lube onto the threads instead of smearing grease.. It's easier to apply than grease, and is fine for that application. Note, I usually remove that lockring a couple times a year and never experienced any issues.
Likes For MudPie:
Quoted: 1562 Post(s)
Liked 1,734 Times
Has anyone ever had a problem with the cassette lockring seizing? The run-off from your chain lube is probably good enough to keep this area permanently gunked up in grease.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
-Ken
