Lyotard Berthet spindle compatibility
Hi. Just bought a 9/16 model 23 pedals but the seller sent me a 1/2 instead. Since I'm from the opposite side of the globe from him I just opted instead for a partial refund. Anyway. From searching around, the spindle of 45ca will work according to others. Problem is the price on ebay is more than $100. I'm looking for tried alternatives if you guys know any.
Quoted: 3813 Post(s)
Liked 3,343 Times
hello vlaint and welcome to the forum!
have no idea as to conditions in the archipelago
if you have access to one, a great resource would be a bicycle co-op charity
they always have one or more bins for broken and/or unmated pedals
at such a venue an enthusiast can find a spindle for next to no cost
another possibility might be that someone such as ELDI may make a helicoil to mount a 1/2" spindle in a 9/16" crank arm
you could also post a wanted notice in the C&V for sale/trade section here at the forum; a member may have a dead or unmated Berthet, or 45CA, which could help you out for a whole lot less than $100
Quoted: 1106 Post(s)
Liked 1,328 Times
Quoted: 4512 Post(s)
Liked 6,385 Times
Unfortunately my LBS here don't really have spare vintage parts on the side as the market for those seems low. I also don't have access to a machine shop or know any locally, just my ignorance maybe lol. I'll try looking for adapters. I didn't know there were adapters for different sizes. I would assume it would offset the pedal to the side a bit? I'm concerned since I'll use it on a 70's roadbike that I converted to a fixie.
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
If I understand you correctly, you're looking for these?:
https://www.ebay.com/itm/284178942556
$20, shipped
$20, shipped
I am looking for spindles that would work as replacement for the Berthets. I saw that listing before but I noticed that the spindles looked longer and of a different shape than the Berthets so I didn't want to risk spending $20 more if it wasn't proven 100% that it would work.
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
Ultimately, I ended up going another route, and sold my French-threaded Berthets for a much lighter MKS pedal (the Berthets are steel). The MKS platform pedals are very nice, btw.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
As I recall, there are Lyotard spindles that are interchangeable on a couple of models, but can't recall which ones work for the Berthet pedals. I ran into the same issue a few years back: had Berthets that were French-threaded, needed 9/16". Someone here suggested swapping the spindles with the ones off of the cheaper model 45, I believe.
Likes For JohnDThompson:
It would seem that only the model 45 is compatible. Problem is its very expensive in ebay right now. I guess my only choice is to buy a cheaper worn down berthet and use the spindle or buy those adapter thingy. Any way, thank you for all your inputs
Liked 1,328 Times
Don't pull a trigger yet. I have a two pair of Berthets to refurbish (no you can't have them) but also an unbranded junk quill pedal with an axle that looks to be about the same length. Today I'll see if the junk pedals axle fits the 23.
Do let me know how it works out. I'm currently eyeing a $40 used berthet seeing that its only $20 more than those 1/2 to 9/16 adapters.
