Re-attaching carbon seat tube section
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 331 Post(s)
Liked 782 Times
I’m looking at a frame for sale locally where the previous owner shortened the carbon seat tube. He retained the cut section and the cut seems to be well done and square. Is there a method/product which it can be securely re-attached ?
Quoted: 3240 Post(s)
Liked 2,086 Times
Calfee is the company to ask as they do a lot of carbon repair, but I doubt they'd be able to re-attach a severed section of straight tubing. It sounds like the frame is too small for you if you are considering this.
Quoted: 837 Post(s)
Liked 1,061 Times
Photos, brand, year and model of bike would be helpful. As mentioned it could probably be reliably re-attached by a good CF shop and I'm assuming it's an integrated seatpost and not round? Not cheap to get it done so get some estimates before considering buying the bike. If it is integrated and needs a proprietary seat clamp I would stay away since if the clamp were ever to break you may not be able to find another.
Quoted: 6194 Post(s)
Liked 4,810 Times
Giant TCR? If your legs are longer than the original owner and outside the range of what's left, then that isn't the bike for you.
But if the owner is giving a huge deal on the bike, then check with some of the places that do carbon fiber bike repair. Seat tube above the stays and top tube probably takes a lot of different forces. I'd not be inclined to want to repair that myself, though I might do a DIY repair of a top tube, down tube or even a stay.
Quoted: 331 Post(s)
Liked 782 Times
It is a 2006? Wilier Imperiale with a seat post and clamp like this one.
Quoted: 18377 Post(s)
Liked 4,512 Times
Oh, some kind of a seatpost mast... where all the adjustment is in the mast?
There are likely two ways to repair it.
Pretty.... or Functional.
I'd probably cut a wide V-Groove all around the joint. Then wrap with carbon fiber and epoxy. Then follow up with wrapping an epoxying 2" or 3" additional of the mast.
Somewhat like what you see with the construction of a bamboo frame.
Multiple layers, thicker in the middle where the joint was.
It isn't a repair I would take lightly.
Quoted: 331 Post(s)
Liked 782 Times
Would it offer any additional strength if i filled the inside of the post say about two inches above and below the cut with an epoxy resin to form an internal “block” so to speak ?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Until a carbon fiber repair expert chimes in, this isn't really the place to go asking for assistance in mending a cut-down safety-critical component like a seatpost. The earlier advice about getting repair quotes or looking for a replacement mast is the best advice you'll get.
Liked 4,512 Times
You'd need something that can give you pressure. Perhaps a GAADI bicycle tube, although you might be able to find CF specific pressure tubes.
Quoted: 2338 Post(s)
Liked 2,822 Times
best option is to find out if you can get a replacement and if you can figure that into what you will pay for the bike otherwise any fix is going to be a kludge, at risk of failure with resultant risk to health, and probably would not ride well
the fact that calfee will not repair seat posts should be a fair warning to anyone trying to do a repair
https://calfeedesign.com/carbon-repair-faq/
What we will not repair
Rejected repairs include: aluminum-to-carbon bonding, carbon handlebars, forks, seat posts/integrated seat posts, stems, damage to carbon wheels, and metal frames.
Likes For squirtdad:
Liked 4,810 Times
I wouldn't fill it solid with resin. Especially not just a small section. You might be changing the natural flexing of the tube in a way that will cause stress points and issues later. But then again maybe not. And if you filled the whole thing, then you'd be getting rid of the flex that is supposed to be giving you a more comfortable ride.
That's why you need to ask someone in the business of repairing carbon bikes. Whether you actually use them or not, they'll provide you with information from a source you should be able to trust. And maybe they'll even tell you what they'd do and you can just DIY it from there if that's your thing.
Liked 4,512 Times
Beyond Calfee, there is also Ruckus Composites in Portland Oregon that specializes in CF repairs. Perhaps others too.
Liked 2,822 Times
We Repair it All
Top Tubes - Head Tubes - Bottom Brackets - Seat Stays - Chainstays - Downtubes - Dropouts
Quoted: 331 Post(s)
Liked 782 Times
I also contacted Ritchie to see if they make a taller clamp
Quoted: 331 Post(s)
Liked 782 Times
Ritchie does not make a taller clamp but I just found these for conversion to a round post. I assume they would have to be glued in somehow?
