Addiction 2023.2
#101
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
I wish WhyFi was around so I could tell him about my new Pirelli P Zero Race TLR tires.
#Formula1 tires for the bike
Keep the chain tight!
Likes For Trsnrtr:
#102
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Oh. Real nice! Thanks a lot! Leave me over there in the old closed thread!
#103
he said member
Bikes: yes please
Liked 1,951 Times
Likes For ls01:
#104
he said member
Bikes: yes please
Liked 1,951 Times
Still weird the 44 feels bigger but I measured from the top outside to outside.
Oh another question.
So I had a 9 spd cassette on the super teams. I had a spacer behind the cassette. I pulled the 10 spd cassette off the bontrager wheels to put on the super team wheels. I noticed it had a spacer but it was smaller than the spacer behind the 9 spd cassette. This made sense in my mind, the 10 speed is larger so smaller spacer.
Well when I mounted the wheel, it shifted like garbage, while before it was on the bontrager wheels it shifted fine. So I pulled the cassette off and put the 9 spd spacer behind the 10 spd cassette and mounted the wheel. Now it shifted better but not perfect. I adjusted the rear derailer and now it shifts almost perfectly, one cog acts weird 30 percent of the time.
Thoughts on the spacer delima?
is the shifter 10 speed or 9 speed? If you are using a cassette that doesn't match the shifter. The cable pull will be different than what is required for the cassette. By the time you shift 3 or 4 gears you will out enough to make noise.
EDIT. 6 SPEED through 9 speed is 1.7 ratio 10 speed is 1.2 ratio. Per 1mm cable travel 6 to 9 speed moves thexrear derailluer 1.7 mm. 10 speed per 1mm cable movement moves the rear derailluer 1.2mm. You are off .5 mm per shift. That's quite a bit of difference.
#105
Mostly Harmless
Bikes: Have two wheels
Quoted: 13718 Post(s)
Liked 4,532 Times
#106
Should Be More Popular
Quoted: 22606 Post(s)
Liked 8,929 Times
#107
he said member
Bikes: yes please
Liked 1,951 Times
Likes For ls01:
#108
he said member
Bikes: yes please
Liked 1,951 Times
#109
Super Modest
Liked 4,621 Times
They were very easy to install, that was nice as the 5000 TL can be a little tight. I only have 75 miles or so but they roll nice and corner nice, too. So far, I like them but they are pricey.
#110
VFL For Life
Bikes: Velo Volmobile
Quoted: 28634 Post(s)
Liked 1,858 Times
#111
VFL For Life
Liked 1,858 Times
#112
Liked 8,929 Times
#113
Liked 8,929 Times
Since I am thinking about getting a replacement for the Saturn, I have been occasionally looking online at new cars. I am leaning towards getting a civic.
Then I saw the 2023 Civic type R.
Want. But apparently impossible to get.
Likes For datlas:
#114
Quoted: 18424 Post(s)
Liked 15,582 Times
#115
Quoted: 9656 Post(s)
Liked 6,366 Times
Likes For Mojo31:
#116
VFL For Life
Liked 1,858 Times
#117
Klaatu..Verata..Necktie?
Quoted: 10442 Post(s)
Liked 11,916 Times
#118
Liked 6,366 Times
No sign of BAM.
Likes For Mojo31:
#119
he said member
Bikes: yes please
Liked 1,951 Times
#120
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12784 Post(s)
Liked 7,697 Times
#121
Quoted: 20810 Post(s)
Liked 9,456 Times
Where is WhyFi ?
BTW, tagging doesn't seem to work for me. Does it work for anyone?
#122
VFL For Life
Liked 1,858 Times
I dunno. No weirder than other 'monuments' of Belgian culture one can think of? Imagine Boonen's legs moving to the beat of ...
https://www.youtube.com/watch?v=9EcjWd-O4jI
#123
Liked 9,456 Times
Likes For WhyFi:
#124
VFL For Life
Liked 1,858 Times
#125
Liked 8,929 Times
