Searching for a non-tapered full carbon fork with 25c clearance!
My titanium bike has an uber-lightweight Easton fork with full carbon parallel (non-tapered) 1-1/8" steerer with external headset bearings.
The only thing that stops this bike being perfect is the tyre capacity of the fork is 23c. The rear takes a 25.
The only non-tapered forks I've found with 25c capacity are alloy steerer type which I'm not interested in, partly because I'm a weight weenie and partly because I like that a ti bike with full carbon fork has zero potential corrosion issues.
Do any of you fine folks know where I can buy this elusive component? Many thanks!
Expired Member
Quoted: 3708 Post(s)
Liked 5,545 Times
Maybe this?
Likes For shelbyfv:
Likes For Groasters:
Sunshine
Quoted: 11019 Post(s)
Liked 7,566 Times
3T Funda
Ritchey WCS
Columbus Grammy Slim
Columbus Futura
Enve 2.0
All these are road forks with 1 1/8 carbon steerers and caliper brake mount.
Ritchey WCS
Columbus Futura
Enve 2.0
Likes For mstateglfr:
Likes For MidTNBrad:
Likes For smashndash:
Quoted: 442 Post(s)
Liked 472 Times
Is this based on a spec sheet or did you actually try a 25mm tire and find that it did not fit? Reason I ask is because usually the clearance limitations are on the rear, and I've not seen a carbon road fork that actually cannot accommodate at least a 25mm or 28mm tire.
Rim is Kinlin XR22T, internal 19mm external 24mm, tyre is GP4000SII.
The 25c comes to within 1mm of inside faces of fork and occasionally touches - so it's too wide!. 23c has around 2mm clearance left and right. Actual measured width of the 23c with a Vernier is 26mm. No typo, it's 26mm. Assuming I keep the fork, I'll move to a 23c GP5000 when the GP4000 is worn. The 23c GP5000 is around 1mm narrower than the 23c GP4000 on that rim, I know this because I have the same width rim on another bike.
Contrary to your comment, the rear clearance is no issue, in fact the underside of the brake (SRAM Force, quite a tight geometry) is the limiting factor here, which allows only a 25c tyre. If I change the brake to a "taller" one (eg Ultegra) I would possibly get a 28c in there.
