Cutting carbon fork, and risk of Health involved.
Bikes: Roussilon Westfalen. The Flintstones Bike
Hey folks me again, with another question that may be interesting for future noobs like me .
I bough some days ago a carbon frameset I now would need to cut the carbon fork because it came stock to long. On the English website I couldnīt find much about it, but on the German side I could read a lot of advice from people warning others that carbon dust and resine is EXTREMELY cancerigene , and some other really really nasty stuff. Some forums were recommending the user attempting to cut itself that he literally wears a full painter uniform (Mask, clothes, glasses).
Now I do know in my side iīm a bit maniac for this kind of stuff, iīm myself some one subject to cancer, its on my family genes.
To make it simple I will number my questions:
1: is really that Dangerous to cut carbon fork alone at home in my cellar ? or is more on a the European side extra care?
2: I looked at some bike shops, (was searching some fine hex blade). And on the go I asked if they would do it to me, they told me the could but for 30Euros, he explained that he would than have to trow the blade away due to the powder and have to take extra measures to keep every employee far from the workshop for at least 30m the time he is sure everything is safe.
Question: Is that worth to just pay 30 bucks let the guy do it and done ? (No risk of breathing or touching + he will apply some resin on the end to make it nice. On the - side he will use a heavy Hex saw with 24 tpi, and Iīm not sure they ever saw carbon fork in their lifes...), I hate bike shops I do know they have nasty methods and do often do more damage and refuse to pay, on the other hand a painter mask with full face protection would as well cost me 30Euros and I can keep it later :/, and Iīm sure to do it proper and absolutely take my time,
3: Now about the blade. I read on internet I should use at least a 30 tpi Hex blade, Iīm absolutely struggling to find it, the finest I can is 24tpi and that's already pretty slim but Im scare to brake this 150 euros fork... (The bike shop above would aswell do with a 24tpi, BUT they say the apply resin at the end.
Thanks everybody for any answer, and sorry for my English.
Best regards see U
Best regards see U
Bikes: Look 585
Quoted: 25 Post(s)
There is no health risk. If you're concerned, work outside. There is more risk of cutting yourself on the sharp edge of the cut tube. Use some fine sandpaper to smooth the edges. Be sure to use a fine tooth saw and some kind of guide to ensure you get a clean, straight cut.
Quoted: 4208 Post(s)
Liked 3,875 Times
I have never heard of any shop taking such precautions. Sure we use very fine toothed blades (the best is an abrasive blade) and take care not to ingest any powder. But I've never used a dust mask or gloves even. Craig Calfee has said that some workers can get sensitized to the resins but simple protective gloves solve that and it doesn't happen to every worker every time. Andy,
hum ok guys, I was reading on the CDC about Carbon black, (thinks is really this one on the Bike frame) they talking about using a APF filter of 5 to 10. for finding this fine blade it has been a nightmare, I just cant find it, for guide Iīm using one hose clamp. I will maybe buy this 3M particle mask but thinking giving iīm broken... Its recommended by 3m and by CDC.
Edit: I will maybe just drop it for the mask and all I do it outside and wont breath on the process...
Now for the blade is it worth to pay 10euros and get one 32TPI ??? or a 24TPI will do more than fine ? i can only get locally the 24TPI 32 only online with high delivery costs.
Thanks again.
Thanks again.
Bikes: 2010 Felt DA, 2012/6 Felt F5, 2015 Felt AR FRD
Quoted: 27 Post(s)
you can nearly remove all chance of dust inhalation if you use a cutting fluid while you work. Using a cutting guide is a great idea, else you'll have to finish the edge. Put some water in a spray bottle, and use moderate to low downward pressure while you cut. Keep the cut wet, it'll keep the dust down and make a smoother cut. It can take a few minutes, but the finished edge will be machine smooth.
Likes For KBentley57:
Carbon black is completely different than cured carbon fiber. Carbon black is much finer than you would ever get sawing a fork.
Super thank you very much, I will do it. I will as well buy a proper Hex blade with 32TPi 24 its really a barbar job, i will just cut it under a unused kitchen sink and constantly let it flow, thanks again for all your patience and answer
Edit: I took as well a proper guide for cutting my carbon frame I will use a gasket holder to fix it under a water sink and pray for the best.
Quoted: 2026 Post(s)
Liked 1,096 Times
You are wasting your time. Cut it with a fine tooth hacksaw and be done with it. A wrap of masking tape around the cut line will prevent splintering of the carbon but that's all you need. Look up the MSDS for carbon composites and you will see there is no indication of carcinogenic problems.
I cut my carbon fork steerer in my basement with a fine tooth hacksaw. No issues, and I am not dead.
Hahahahaha ok I will take care of it but for having a nicer cut using cuting fluids can really make it nicer.
Liked 1,096 Times
hhahaha ok than thank you, I will probably not giving all my missing components are coming in one package and in the day I will be so anxious to make my first ever ride on a carbon frame that I will skip those steps
US shops would not care about Employee health , the fine fibers of carbon lodge in your lungs like Asbestos , evermore to be there. an irritant, ... At best.
can you make a 100% square Cut of a round tube, freehand with a hacksaw? you are better than 99% of humanity then.
Quoted: 1438 Post(s)
Liked 1,092 Times
The hazards (or not) of carbon aside, be VERY sure that you measure at least twice lest you cut your expensive steerer too short.
Quoted: 5791 Post(s)
Liked 2,581 Times
Like with just about anything the dose makes the poison. If you worked in a CF factory and were cutting forks day in and day out, then there are serious health risks that need to be managed. But you're cutting only one fork, and won't be cutting another for years, so the totl exposure is insignificant. Cut the fork, drrss the end with a file or sanding block, then vacuum the dust and move on with your life.
The biggest risk in cutting carbon forks is to your head. From banging it against the wall because you measured wrong and now have a $300 ork that's too short for your bike.
FB
Chain-L site
One accurate measurement is worth a thousand expert opinions - Adm Grace Murray Hopper - USN
FB
Chain-L site
Likes For FBinNY:
HAhahaahhah thank you very much guys,
Thanks fietsbob I do thrust on your thinking, I will than just see on the day what its best to do.
FBinNY would you maybe have a good guide, (Ar any one else) telling me how to measure and mark where to cut the perfect way . I do have the pressure plug, does it change the technique from a star nut ???,
The way I know is: I should assemble the whole frame put the comfortable amount of spacers and the stem for me, mark as close as possible the fork from the spacer or stem (if I wonīt have any top spacers) remove the fork and from my mark use a 4mm spacers and trace another mark lower.
thanks
If I got it right the pressure plug (Expanding inside the fork) comes first, and than there should be an "empty space" from about 3-4mm from the Stem or a top spacer and the top cap closing everything and compressing the whole mechanism together. ?
thanks
Liked 1,096 Times
Ask Dr. Science https://www.youtube.com/watch?v=Elpbs6kb8Ys
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Today, I believe my jurisdiction ends here...
Quoted: 38 Post(s)
Liked 11 Times
Disposable hazmat suits are not that much.Wouldn't want you to get cancer from cutting 1 fork....
I measured my carbon steerer 3 times, and then still ended up cutting it.... too long! Thankfully that was easily fixed.
Likes For dr_lha:
Quoted: 38 Post(s)
Liked 11 Times
Are you still with us?....
My buddy used to work with carbon fiber....Grew a 3rd leg in the middle of his forehead....Couldn't see it though,the balls were in his eyes.....
Hahahahahah you guys made me laugh so much...
fietsbob
by this are you meaning My thinking was right and its totally obvious, or simply I should try to use a magic place called GooooooGle ?
Booger1 I will do my best to avoid growing a third member in my body
fietsbob
Liked 7 Times
I recommend that you put an extra 5 mm spacer above the stem. This will allow you to place the expansion plug behind the stem for better support. Cut the stem 2 or 3 mm below the top of the upper spacer. When tightening the stem pinch bolts do not exceed 5 nm (44 inch pounds) of torque. I use 40 inch pounds.
