Black Tubing That Covers Exposed Cable?
I have a bike where on the bare cable, between cable stops, has a fine plastic black tubing or sheath on it - like a straw.
What’s this tubing called and where do I get some? Bike shop? Is it cable housing liner? Most of that I’ve seen is clear.
Thanks.
Thanks.
Quoted: 5791 Post(s)
Liked 2,581 Times
FB
Chain-L site
FB
Chain-L site
Bikes: 2012 Giant Escape, 199? Specialized HardRock
Quoted: 40 Post(s)
I think the OP is talking about this stuff.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I just found some for my Hardrock rebuild, runs along the top tube and worked perfectly but mine was white
Quoted: 1438 Post(s)
Liked 1,092 Times
Any kind of plastic tubing will work; its main purpose is to keep the wire from tapping on the top tube. There are also little rubber "donuts" available for the same purpose.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
I prefer the donuts for top tube cables.
Thanks all! I did think about non shrink tubing. I actually like clear heat shrink instead of cable tips!
The bike in question is a Bacchetta Giro 20 - a long monotube recumbent, and although I’ve got the rubber “donuts” I prefer to use the tubing to protect a long run of exposed cable. The current tubing is “ok”, but 7 years old and sort of grungy in appearance.
You all rock! Thanks.
@DEW21 - yourHard Rock Sport is outstanding. Is that new powder coat & decals? Just perfect. Thank you for sharing.
Quoted: 2338 Post(s)
Liked 2,827 Times
I would make sure that what ever I used did not add a lot of friction......my understanding is that the idea behind the open cable runs was to reduce friction that was there from long runs of cable in housing. The little donuts don't add friction.
Quoted: 40 Post(s)
https://www.bikeforums.net/bicycle-m...rdrock-bb.html
Liked 2,581 Times
The secret to preventing friction with a full coverage sleeve is to cut it short by the amount of cable travel, ie. something close to 1/2" shorter than the gap between the stops. That way it will move with the cable, and not cause any friction.
FB
Chain-L site
FB
Chain-L site
Way back, brake cable housing used a separate liner, now , its fused inside..
Even if loose , it still will prevent the slotted stops from letting the housing out of the stop, if needed... without that shorter length..
the stops meant the amount of housing subject to compression was shorter than running it full length .
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 711 Times
https://www.universalcycles.com/shop...&category=4384
Want to split the cost and the roll? Maybe Gugie would like some, too...
Jeff Wills
Jeff Wills
@Jeff Wills - I was gonna look at that. Splitting the cost could be nice since I’ll never need that much.
Someone I know who fishes said to go to a fishing supply place and they’d have something quite similar. Not sure what it’s called. I was just going to go over and see what they have.
Quoted: 3376 Post(s)
Liked 5,518 Times
On my Ti bike, (which has the rear brake cable on the underside of the top tube), I went to a local auto-parts store and bought thin black rubber tubing to slip over the bare cable. It is the tubing commonly used for vacuum lines under the hood.
Quoted: 1858 Post(s)
Liked 606 Times
Quoted: 336 Post(s)
Liked 309 Times
This tubing is also nice if you use bikepacking bags, bento boxes, "jerrycans", gas tank bags, etc. on tubes with exposed cables. The velcro straps push the cables into the paint and cable action rubs both the strap and the paint.
+1 for the roll at Universal.
Quoted: 90 Post(s)
Liked 137 Times
I just called my boss and asked him and it drew a blank lol, then he said spaghetti but not sure. I went and grabbed mine and it has no name on it lol, cost me $2.25 a roll when I got it
Glenn
Liked 2,581 Times
OTOH - if you use a more rigid tube with a larger ID, then the wire will move freely within it, so you don't need to cut it shorter. That said, I still prefer to leave some gap at the ends to ensure that it can't trap water.
So, there's no right or best way, it's more about the specific details.
FB
Chain-L site
FB
Chain-L site
I used some on the shift cable on the down tube , spiraled the tail light wire around it, under the BB, under the mudguard,
to where the tail light was..
then I just got a battery powered LED mudguard tail light and removed the wiring..
Quoted: 90 Post(s)
Liked 137 Times
It depends on the kind of tubing and how it's used. I use a tube with a fairly snug fit on the wire, so it would add friction if it couldn't move with the wire. Of course if you heat shrink the tube onto the wire, it must move with the wire.
Glenn
UPDATE: I went to Universal Cycles in Portland, where I’m a “regular” to pick up an order. They offered to just give me what I needed (the black tubing we’ve been discussing) since they use it in the shop and get it in bulk. They use and gave me Jagwire Cable Housing Liner in black. As far as I can tell, it’s exactly like what I’m replacing.
I’m set and didn’t have to buy an entire roll.
Quoted: 2112 Post(s)
Liked 663 Times
Well, maybe it’s a helpful reply if you are wondering what Bucatini all’Amartriciana is.
-mr. bill
Liked 2,581 Times
I can imagine the blank stare you'd get if your walked into an electonics store and asked for bucatini. (or the singular)
FB
Chain-L site
FB
Chain-L site
