Getting closer to my grail Trek 720
A bonus of my search for another Voyageur last fall was bikemig letting me know he had a 1983 Trek 720 frame he was willing to part with. Since they came out the 1984 720 was my grail bike and this was a seat tube set of bottle bosses away from it so I couldn’t resist.
The plan was to build it up with spare parts I had. The rear triangle had been spread so I just needed to add a couple 9 speed items.
I had it powder coated and today was the first opportunity I’ve had to start the project. So far everything has come together without any issues other than I failed to tell the powder coater to mask off the cantilever studs. It took some work to scrape, file, and sand it off but the brake set adjusted to the 700 c wheels fine. At least that process left me with good confidence in the toughness of the finish.
I’ll follow up as I move along but here are the results of day one.
Original frame
Original frame
Nothing compares to the simple pleasure of a bike ride - JFK
Likes For badger_biker:
Likes For nesteel:
Quoted: 838 Post(s)
Liked 1,082 Times
Excited to follow along. I also was looking for an (86) Voyageur and (85) 720 simultaneously, with no strong preference one way or the other. Ended up with the Voyageur and always happy to see threads of either bike
Likes For polymorphself:
Quoted: 5888 Post(s)
Liked 3,471 Times
Pretty sure @bikemig grows these things in his garage. I got my 60cm '83 720 frameset from him several years ago.
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
Looks fun. Keep sharing.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Liked 3,471 Times
I like the workshop with the Dutch sign, verboten fietsen, and the gravel tractor ad. All very appropriate for a bike shop.
Likes For bikemig:
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
!!!! cant wait to read the updates! what model brakes???
(esp. since i've recently acquired a tatty 60cm 1984 that is now hanging around as frame and fork, waiting for inspiration about what brakes to try for 700 rims)
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Likes For dedhed:
Quoted: 457 Post(s)
Liked 462 Times
I have a 1982 720 that will get built up at some point, looking forward to your finished build! Its looking great so far!
Mine does not have canti studs though :-(
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Wow that thing is headed exactly in the right direction so far!!!. Who did your powder? Great job whomever.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
What else do you have planned for it- part wise?
Commence to jigglin’ huh?!?!
Sorry no pics of the 720 today as it was a somewhat frustrating day. Added a Brooks Pro and then tackled the brakes. I’m using a pair of early 90’s vintage Dia Comp aero levers. I had to improvise some ferrule stops and can’t figure out how they worked when I previously had them on on my Specialized Expedition. Maybe bigger cable end stops? Anyway setting up the brakes did not get completed. Not sure of the Shimano model (I’ll post a pic tomorrow) but they have a Y yoke where the cable passes through a disk to the cable anchor arm. Not a lot of motion range but I got the rear one set up. There is minimal clearance to the rim but the brake lever nearly bottoms out when you activate them so I’m skeptical on the stopping power.
The front set set seems to have a weak spring on the non anchor arm and are pretty much a fail with that Y yoke limiting how far the lever will spring back from the rim. My next attempt will be to make a standard arched yoke and see if that helps. If not I may need to hunt down some different cantilevers😩. This was supposed to be a build to use up some spare components so I don’t need to add to the list my wife thinks are spare parts😃
A local metal fabrication shop was powder coating the deck cable railing posts I had made and I happened to ask him if they ever did bikes. Mostly motorcycles but he said they would blast and coat it for $70 so I figured it was worth a try for that cheap of price. I wound up buying my own powder because I wanted a good metallic and it was from a company he hadn’t dealt with. That cost me about $45 but there is enough left to do another frame. They don’t have the equipment to keep the metallic flakes mixed as they spray but didn’t figure it would be an issue on something without any large surface areas where you might notice an uneven pattern and it turned out just fine and even.
I’ll get a list together and post it. Mainly try to keep it on the lighter side for a touring bike and comfortable for some longer unloading rides. More of a rando bike than loaded touring I guess.
Here’s an up to date picture and a shot of the brakes I’m using.
Logic told me to try and wind the spring tighter in the weak front cantilever arm but after several fails I tried opening up the spring more and bingo! So I used my last Shimano QR cable hanger and my own straddle cable and have decent front brakes now. If I ever find another QR hanger I may replace the Y set up on the rear with a normal straddle cable too.
More garage “bike corner” background Miguel😊
I have a similar set on my Expedition that work wonderfully with 700 C wheels.
Shimano 600 tricolor hubs laced to Wolber GTX 2 rims. 28mm Specialized Nimbus tires for now. 9 speed cassette.
Straight alloy seat post with Brompton adjusting clamp and Brooks pro with copper rivets.
Stronglight A9 roller bearing headset.
Suntour XCM FD.
Nitto Technimic stem.
Miche pedals.
Parts my wife thinks I had:
Nitto Randoneur bars.
Deore 48-38-24 crank.
Deore XT 9 spd RD
Ultegra 9 spd bar ends
Took a break tonight and rode my Voyageur to a bike shop/brewery combo to have a brew and hear a little live music. Very cool place.
Liked 3,471 Times
Looking good. Yeah the spring tension in the canti is key. Sheldon Brown has a good write up on the y yokes. They speed up installation but they limit adjustability. You can hunt around for the right length. Personally I tend to avoid the y yokes in setting up cantilevers.
Do you ride the dairyland dare? I like the course. I think I may miss it it this year but I’d like to start riding it again. It has a whole lot of hills.
sheldon brown likes the y yokes
https://www.sheldonbrown.com/canti-trad.html
Quoted: 217 Post(s)
Liked 198 Times
Likes For niliraga:
Yes I rode the DD in 2010. My son and I did the 66 mile route. I did it on my 87 Trek Elance but this build should have better gears for the hills if I ever ride it again.
Liked 1,700 Times
Do you, by chance, happen to live near Athens?
Let me know what brake set works for you. I’m not super confident these will be the ultimate answer for me.
Quoted: 1858 Post(s)
Liked 664 Times
