Any way to expand an O-ring in a Bontrager pump?
Quoted: 206 Post(s)
Liked 38 Times
My Bontrager Turbocharger HP pump has issues, adding silicone grease only slightly improved things - pretty sure the plunger O ring is worn - getting a specific replacement looks like it's going to be problematic - are you aware of a way to swell that O- ring or do you think I'd be likely to find the right size in a typical O - ring collection at Harbor Freight, Home Depot etc.?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I seem to remember using isopropyl alcohol to expand a rubber seal in a suspension fork once. Not sure if it's the same material, but might be worth a shot.
Likes For Rolla:
SE Wis
Quoted: 2750 Post(s)
Liked 3,407 Times
Likes For dedhed:
Likes For Crankycrank:
Clark W. Griswold
Quoted: 4407 Post(s)
Liked 4,048 Times
I would recommend first checking with your local older Trek Store (that has been around long enough to have carried that pump) and see if they have any leads and if nothing else do what dedhed recommended and check your local hardware or plumbing store.
Likes For veganbikes:
Quoted: 114 Post(s)
Liked 119 Times
I'm pretty certain the o-ring is an standard industrial type oring. I can't see Trek/Bontrager making special o-rings but rather, incorporate an existing o-ring.
My local hardware store (Do It Best) has o-rings in those small parts pull out drawers. There are finite sizes, based on the cross section diameter of material and the ID of the ring. The various sizes are distinct enough that you can visually match your oring, just take it with you.
Often, shops have a measuring cone (a cone with the tip facing up) and you drop the o-ring onto the cone and where it lands, tells you the ID. Then there is a little notched, slip-in gauge at the base of the cone that indicates the diameter of the cross section.
Likes For MudPie:
Droid on a mission
Quoted: 317 Post(s)
Liked 281 Times
Likes For JoeTBM:
SE Wis
Liked 3,407 Times
An "improper size" will often even work in many applications due to the nature of the material, especially in low tolerance applications.
No manufacturer uses a custom size O ring because they are made in so many sizes
O rings are sized by ID-OD-cross section. Measure your groove it sits in to get ID and width of groove will give cross section. OD is then standardized because of the cross section.
It's a bicycle hand pump, not a high speed, high pressure application.
Likes For dedhed:
Quoted: 114 Post(s)
Liked 119 Times
The other variable about o-rings is the material. Some materials are better suited for different chemicals or environmental conditions, but for this applictin, the cheapest and most available rubber will be more than sufficient,
Likes For MudPie:
SE Wis
Liked 3,407 Times
Most hardware store/plumbing are going to be SBR or Buna N (Nitrile) and more than adequate. Auto parts may have a Viton (FKM) for fuel applications, but would be overkill for a pump.
Likes For dedhed:
Mad bike riding scientist
Quoted: 6228 Post(s)
Liked 4,231 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 6240 Post(s)
Liked 4,840 Times
Just get a new air chuck. They aren't very expensive at all. The last one I purchased was only about $4.50. And it included a hose that happened to be longer than the one on the pump.
You might have to search a little. There are $50 and higher air chucks out there for those that need the prestige and self-adoration.
Quoted: 206 Post(s)
Liked 38 Times
Liked 4,840 Times
In that case, pretty much similar advice. Get a new floor pump.
Likes For grizzly59:
Droid on a mission
Quoted: 317 Post(s)
Liked 281 Times
Found two "Trek" pages on this but nothing gives dimensions
https://www.trekbikes.com/us/en_US/e...-ring/p/26018/
https://www.trekbikes.com/us/en_US/e...ommet/p/13891/
Quoted: 569 Post(s)
Liked 595 Times
Greases are made to very slightly expand most all o-rings materials for improved fit and service life but not repair a worn o-ring, if you use them periodically your o-rings will last much longer.
Dow Corning Molykote 55 Oring Grease 5.3oz - DC 55
Quoted: 3547 Post(s)
Liked 2,962 Times
Disco Infiltrator
Quoted: 3130 Post(s)
Liked 2,111 Times
Speaking as an engineer who deals with o-rings pretty often... There's a lot to know about o-rings but you don't need to learn it for this.
Just take the disassembled pump to the hardware store and figure it out. You need the right thickness and it should be stretched just a little when installed on the piston so it's not loose, and then when you put it into the pump cylinder you should have a little but not too much trouble. If you have a choice on hardness just try to get one that feels about the same. Buy a couple of them in case you tear it when you install it. Clean everything really well and grease it before you put it back together for good. It's possible the cylinder has gotten scratched or rusted as the thing was deteriorating so don't get your hopes up it'll be good as new for just as long.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 569 Post(s)
Liked 595 Times
Yes, i get very good life, does not take much. There are a lot possible failure modes for o-rings and bushings in industry but in a pump plunger or a chuck the likely failure mechanism I would say is abrasion with the plunger wall and the presta and/or schrader, this friction can be helped with a lubricant. In the plunger I would also expect over time another failure mode would be compression set as the walls flatten the circular o-ring and it takes a permanent flattened set, this is where a very slight expansion of the o-ring material could help.
Liked 4,231 Times
Lubricant will reduce friction and, thus, wear on the o-ring but no lubricant should change the characteristics of an o-ring. Having swollen many o-rings because of chemical incompatibility, I can tell you that a swollen o-ring is not something you want. Any change to the physical characteristics of the o-ring from swelling to softening to hardening will result in improper performance of the o-ring. The result may be only a slight decrease in performance or it could be disastrous.
Stuart Black
Stuart Black
Likes For MyRedTrek:
Quoted: 569 Post(s)
Liked 595 Times
I have been clear in the OP's case he needs a new seal, a lubricant will not help him. That said in my discussion with smd4 on preventative maintenance, not repair, or chemical incompatibility, you can read from the Dupont Resource Center "MOLYKOTE® 55 O-Ring Grease is a silicone-based material that helps ensure positive lubrication and sealing by slightly swelling rubber O-rings and seals" which is standard industrial preventative maintenance practice that enhances the sealing and life.
Liked 4,231 Times
DESCRIPTION
MOLYKOTE® 55 O-Ring Grease is a silicone-based material that helps ensure positive lubrication and sealing by slightly swelling rubber O-rings and seals. This product is heat-stable and oxidation-resistant and is serviceable from approximately
-65 to 175°C (-85 to 347°F).
How to use
MOLYKOTE® 55 O-Ring Grease should be applied using brush, grease gun, or automatic lubrication system. MOLYKOTE® 55 O- Ring Grease can be used in centralized lubrication systems. Do not mix with other greases.
MOLYKOTE® 55 O-Ring Grease has been shown to swell natural rubber. However, compatibility of the lubricant may vary with the plasticizer content of specific materials (especially elastomers). Small-scale compatibility testing should be conducted prior to the use of this product in any application.
MOLYKOTE® 55 O-Ring Grease should not be used with the following materials unless thoroughly tested for your specific application:
• Silicone rubber (SR)
• Polycarbonate (PC)
• Acrylonitrile-butadiene- styrene (ABS)
How to use
Stuart Black
Stuart Black
Quoted: 206 Post(s)
Liked 38 Times
Btw, the reason I think the original O-ring got worn down in the first place is some corrosion developed at the bottom of the tube. Not sure how that happened but I began to feel this rough spot at the bottom of the plunger travel. Before putting the new O-ring in I attached varying grades of wet-dry sandpaper to the end of a dowel with doubled over duct tape and worked it against the rough area until it disappeared. 320, 800, 2000, 3000 grit. Wiped it out with paper towels also attached to the end of the dowel and shot aerosol parts cleaner down there until the towels came out with no more residue, then re-lubed with Sil-Glyde.
The whole travel feels buttery smooth and the pump really moves some air now all the way from the top of its travel.
