Steel Frameset suggestion
Any suggestion on a steel frameset/bike that can be used as kind of a beater to learn some tricks on and probably fall but not too heavy and can be used on chill rides or climbs. 32c tire clearance
Thanks
Thanks
Quoted: 586 Post(s)
Liked 612 Times
Personally, if that is what you want it for I'd be looking at a "vintage" steel mountain bike as a base. There are any number of models of older Treks or Specialized that would be perfect for what you want. They are robust, reasonably light and certainly can handle larger tires. Don't go for one with a suspension fork, there are plenty around that will have cro-mo forks.
Likes For TugaDude:
Maxway Ltd TW is the big contract manufacturer many well known brands use to build their bikes at a competitive price.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
70s or 80s 10 speed and change parts as desired. Could also check bikesdirect.com to see what fits your needs.
If you go the bikesdirect route, have it looked over and adjusted by the local bike shop. It will be worth the money.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Clark W. Griswold
Quoted: 4363 Post(s)
Liked 4,006 Times
A Surly Steamroller could be a good bike for that. I wouldn't call it a beater but certainly plenty of people beat on their frames.
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
What geometry do you want?
Kilo WT
Gitane City Link
Steel road or MTB conversion
All city nature boy
Motobecane fantom Uno disc
Surly steam roller
Pake rum runner/Soma rush (I think)
Tons of options. Figure out geometry, and budget for more specific suggestions.
Kilo WT
Gitane City Link
All city nature boy
Surly steam roller
4130 double butted tubing frame, that's one will last rides forever. And there a tons of them. Just make sure its write 4130 butted. No fancy thin wall steel tubes like Reynold 7x 9x or whatever, those is super nice riding and expensive. One heavy crash probably send you to nearby LBS to get it fix.
I try looking in Retrogression shop for you, these probably suit you. Pake Rum Runner, All City Big Block, Soma Rush. But be aware, these frame is quite aggressive.
If you want more road friendly, try looking at Surly Steamroller, that steel frame is more road geometry, forgiving riding.
Quoted: 823 Post(s)
Liked 1,395 Times
How far are you from Asheville NC? There’s a 58cm Surly Steamroller for sale on CL for $350 ....
Quoted: 823 Post(s)
Liked 1,395 Times
Ignore, double post!
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
check out the Milwaukee Beltline. their website seems to be down at the moment but I saw it the other day and it sounds like close to what you want. I think Ben's Cycle is associated with Milwaukee Bikes. https://www.benscycle.com/milwaukee-...p?skuId=682369
some BMX companies made stuff like that recently. Poseidon has the FX Tracklocross frameset, but it's aluminum.
Quoted: 94 Post(s)
Liked 72 Times
https://www.benscycle.com/milwaukee-...uiser2-20834/p
n00b
Quoted: 428 Post(s)
Liked 466 Times
The Milwaukee Bruiser from Ben's is also a decent option, just not belt drive. And the above poster is correct, Ben's is the only place that sells MKE branded bikes (made by Waterford).
